Go Back   IH8MUD.com > General Tech Forums > Expedition Builds
LinkBack (27) Thread Tools Display Modes
Old 07-15-09, 10:18 AM   #361 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Originally Posted by ntsqd View Post
Since you're getting the whole center section, yeah, should be just plug it into your existing turbine and compressor scrolls and off you go. The only hiccup in the plan would be if your scrolls are different trims than the wheels on the new center section. If they spin freely inside the scrolls you're good to go!
I'm buying it from the same company I bought the turbo from originally so i'd hope the trims were the same...!
thanks! I'll post up my progress....
Hello. My name is VTCruiser and I am an addict.
Project Overland Build - Updated 9/28/09
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
VTCruiser is offline   Reply With Quote
Old 07-15-09, 10:03 PM   #362 (permalink)
89s rule's Avatar
TLCA# 14198
That stinks. I was looking forward to another TT article from you and JP. I hope you get it back together and going well.
'93 FZJ 39K miles - 850/860, Bilies, LED tails, sliders, & 285 MTRs Lightforce 240s waiting on a bumper.
'97 4Runner SR5 - 4x4, leather, Toyo AT, TJM T15, LF 240s.
'63 Biscayne Wgn - Kandy Green & Tweed. Family Wagon 3rd row in the garage.
'89 FJ62 & '83 fj60 SOLD
Erskine College Upstate Cruisers
89s rule is offline   Reply With Quote
Old 07-16-09, 08:27 PM   #363 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
That sux Gehn.
On another not have you thought about installing a few dummy lights for turbo and engine oil pressures?
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
"What fits your busy schedule better, exercising 1 hour a day or being dead 24 hours a day?"
Old 07-17-09, 05:43 AM   #364 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Originally Posted by Trollhole View Post
That sux Gehn.
yeah, even thought about hooking it up to the fuel cut-off so it would automatically shut the engine down. I have also decided to move the bypass filter to after the turbo to minimize any future leaks or failures that would starve the turbo.
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 07-29-09, 06:40 AM   #365 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Parts should be here next week...a new bearing assy or "CHRA", new gaskets, hardware/manifold studs, and a new air box lid since the one originally sent was damaged in shipment.
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 07-29-09, 08:27 AM   #366 (permalink)
If you want to pursue the low oil pressure interlock, see if you can still get the oil pressure switch for a GM Vega's fuel pump. They used to hang on the peg-boards, but when was the last time anyone even saw a Vega?
Anyway, Vega's never had a mechanical fuel pump so the low oil pressure switch was GM's non-computer safety measure. The switch has a third terminal on it for starting. Wire the third terminal to the trigger terminal on the starter solenoid so that the IP will work normally while cranking. I've used them on a couple carb'd engines with electric fuel pumps with great success.
My opinion is worth what you paid me for it.
ntsqd is offline   Reply With Quote
Old 07-29-09, 08:40 AM   #367 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Hmmm, I wonder if NAPA still has them. I'll find out next time I'm in there.
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 07-29-09, 09:17 AM   #368 (permalink)
I do not know what the cut-out pressure is, but it is fairly low. So it shouldn't ever cut fuel during extremely hot oil conditions, but it will shut down the engine if you miss the gauge/light's warning.
I'm wondering if it should be on the engine, or on the pressure line to the turbo? Maybe it doesn't matter?
Old 08-03-09, 06:35 AM   #369 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
The turbo feed takes pressure from the gauge sender port, so I don't think it will matter.
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-07-09, 12:24 PM   #370 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
I am finally back in the states....
The new turbo parts have arrived as well as a new ARB. I am waiting for new oil and filters this week and am hoping to work on it this weekend. I also installed the split rear bench, the locker cables and dual batteries before the Turbo blew up, so I'll post up those updates as well.
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-14-09, 08:59 AM   #371 (permalink)
Willman's Avatar
13 pages of sweet cruiser love!
Very nice VTCruise! Your one lucky dude!
Can't wait to see the RTT and ARB/winch all mounted up!
Did you ever hot dip galv. your frame?
Keep it coming!
Cheers!!!
Nic
TLC....Coming soon....40..60/62 Eh?
Sierra Expeditions
Slightly Modified 2001 Dbl Cab Tacoma
Bantam BT3-C Expedition Trailer
Willman is offline   Reply With Quote
Old 09-20-09, 07:45 AM   #372 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Keep it coming!
Nope, I didn't galv the frame. I just ran out of time and $$, and figured I'd continue with modifications to the frame as I outfit it with skid plates, perhaps on board propane etc. It may be something I go back and do later when I know I'm done welding on the frame.
I rebuilt the turbo and installed the ARB last weekend and so far so good. It runs just a well as it did before it blew up so I am feeling confident about the condition of the engine bearings. Time will tell though....I'll get some pics.
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-20-09, 08:21 AM   #373 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Here are some pics of the split bench installed...
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-20-09, 08:27 AM   #374 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Dual blue top optimas on stainless trays...
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-20-09, 08:31 AM   #375 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
The locker cable linkage need to be lengthened for LHD. I just cut the rods, made extensions from tubing and relocated one of the tabs for the lever linkage. Mounting the controls was just drilling holes and using a couple rivet nuts.
more later...!
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-20-09, 11:10 AM   #376 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
I hate you and your cable lockers
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is offline   Reply With Quote
Old 09-20-09, 07:49 PM   #377 (permalink)
GIGGIDY!!!
eventhough's Avatar
TLCA# 17492
Very nice Gehn!
76 FJ55 SOA dubbed "The Beast"
BUILD A CRUISER FOR A FALLEN SOLDIER
I cling to "guns and religion"
eventhough is offline   Reply With Quote
Old 09-21-09, 06:09 AM   #378 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Some pics of new turbo...
old CHRA...
New CHRA...
My "bench" (I need a proper shop...badly...)
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-21-09, 06:12 AM   #379 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
And finally the ARB installed...
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-21-09, 05:55 PM   #380 (permalink)
rutbeer's Avatar
Cool! I had no idea the 60 series cable locker linkage was so different from the 70 series stuff. Mine looks NOTHING like that....more like a standard parking brake. So do those handles of your pivot or do you just pull straight up on them?
78FJ40 13B-T, 5speed, split, full floater 70 series, cable lockers,4 disk, a/c, 60 pwr steering, all toyota except the a/c.
www.importpurist.com
Oh, and a bitchin FJ45 that may or may not be for sale.
"Much like a cat or hot buttered toast, the correct side will always try to land down. If the bezel is on upside down, then the force of it trying to right itself may cause you to roll your cruiser unexpectedly."
rutbeer is offline   Reply With Quote
Old 09-22-09, 06:31 AM   #381 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
yeah, you pull straight up on them.
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-23-09, 11:16 AM   #382 (permalink)
AGreekBoy's Avatar
TLCA# 18699
hey gehn, the truck looks great. one question, on the split rear does the bottom fold up like before still?
1970 FJ40 work in progress
2008 FJ Cruiser
AGreekBoy is offline   Reply With Quote
Old 09-23-09, 11:37 AM   #383 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Nope, the back flips down and then both hinge at the front against the back of the front seats.
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 09-28-09, 09:28 AM   #384 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
I've got about 500 miles on the new new turbo now and it's running better than ever. It seemed a little down on power and I was having some hesitations at high RPM until I realized I forgot to change the fuel filter for the push pump back at the tank. About $5 and 10 minutes later the hesitation is gone and it pulls like a turbo diesel should. I am thinking about upping the boost a little after a few more break-in miles...
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 10-23-09, 01:06 AM   #385 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
Well, I am back in Afghanistan for work so the cruiser has been put to bed for a couple months. I put the snow tires on before I left and tracked down an annoying squeak from an exhaust hanger, so it'll be winter ready when I get home. I'll be back in December for a few weeks, but back out here in January, so it'll probably be a slow winter. On the bright side, I get around Kabul in a armored HZJ105 which helps keep my cruiser withdrawals at bay.
Upcoming plans for the HJ include tuning the boost compensator for some more low end response, which I can probably do while I'm home in December. But a rear recovery bumper with tire swing out, a winch, sliders, some proper lift springs and a new cargo system will likely have to wait until spring. I wish I had heated garage to work in... *sigh*
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 10-23-09, 01:15 AM   #386 (permalink)
Rando-kurūzā
Spike Strip's Avatar
TLCA# 17876
Sorry, small hi-jack...
I've got a co-worker heading to Afghanistan next week (Kabul) ... He's gonna be there 5 weeks teaching the Afgan kids how to skateboard... Well, at least he'll blend in with the local pop. I told him I want pix of Land Cruisers and he thought I was crazy...
5/85 FJ60 -- A whole lotta crap and $$ that took 2 years of my life and pissed off the
6-86 FJ60 - current project - gonna stay stock.
Support MUD Vendors: www.marksoffroad.net
BEST WWII STORY EVER WRITTEN
Spike Strip is offline   Reply With Quote
Old 10-23-09, 02:05 AM   #387 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
haha, cruisers are definitely the vehicle of choice for internationals. They're everywhere. There are some badass 110's and g-wagons too, but I would love to bring home one of these...
VDJ76
or a VDJ78
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 10-23-09, 02:14 AM   #388 (permalink)
Rando-kurūzā
TLCA# 17876
Man, if Toyo would only offer either of those in the U.S. with a turbo Diesel... It'd be the last vehicle I'd own... (maybe that's why they don't sell 'em here!)
Old 10-23-09, 02:20 AM   #389 (permalink)
VTCruiser's Avatar
TLCA# 15472
Garage
hell yeah!
ROTM - May 2009
UpstateCruisers.net
GSMTR'09
Old 10-23-09, 04:19 AM   #390 (permalink)
HJ47's Avatar
Location: Adelaide, South Australia- originally from Santa Fe, New Mexico USA
TLCA# 2344
The wreckers in Adelaide where your rear split bench seats came from have another set. If you know of anyone who wants it, have them ring Rod and he can ship it. 61 8 8359 4499.
Cheers,
Josh
CU '93
Indecision may or may not be my problem.
4/1984 HJ47 'Patches' OME, H55, p/s, a/c The Vortec Vixen. 'Tengo una pieza que a la vez'
7/1984 FJ40 LX 'Lexie' OME, H55, p/s, a/c The Petrol Piglet
Troopy Registry:
http://forum.ih8mud.com/fj45-owners-...-registry.html
HJ47 is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/expedition-builds/167721-project-overland.html
Posted By For Type Date
How early is this 80 series Cruiser / whats it worth?? - Expedition Portal Forum This thread Refback 09-09-09 03:29 PM
FS: Camping Lab RTT - NEW! $700, VT - Expedition Portal Forum This thread Refback 07-17-09 10:56 AM
Finally RTT! - Page 2 - Expedition Portal Forum This thread Refback 06-21-09 05:32 AM
Mac-based GPS Advise? - Expedition Portal Forum This thread Refback 06-09-09 12:40 AM
Random dog shots - Page 51 - Expedition Portal Forum This thread Refback 05-14-09 09:55 AM
M 422 Jeep For Sale, Lyrics To Fast Cars And Freedomrascal Flatts, M Series Freightliner Corporation - Honda350X This thread Refback 03-08-09 03:43 AM
Wrap Jeep Header, Wrangler Original Cargo Pants, Wrecked 1997 Nissan Sentra For Sale - Victory8Ball This thread Refback 03-06-09 02:08 AM
Self Portraits? - Page 28 - Expedition Portal Forum This thread Refback 02-17-09 11:43 PM
60 Owners - Expedition Portal Forum This thread Refback 02-12-09 11:35 PM
Show Your Ironic Photos - Page 4 - Expedition Portal Forum This thread Refback 02-11-09 01:14 PM
Please Recommend an Expo Quality Laptop Bag - Page 2 - Expedition Portal Forum This thread Refback 02-04-09 07:30 AM
Random Scenic Shots.... - Page 3 - Expedition Portal Forum This thread Refback 01-24-09 08:19 PM
Random RIG Shots.... .... .... - Page 83 - Expedition Portal Forum This thread Refback 01-17-09 02:50 PM
New England Members Register - Page 13 - Expedition Portal Forums This thread Refback 12-19-08 10:46 AM
Eastern States ExPo members, say hello here! - Page 13 - Expedition Portal Forums This thread Refback 12-19-08 06:58 AM
People and portraits. - Page 2 - Expedition Portal Forums This thread Refback 12-01-08 09:51 AM
Lets see the Expo Cruisers! - Page 9 - Expedition Portal Forums This thread Refback 11-26-08 06:09 AM
My 60 mods thread - Page 6 - Expedition Portal Forums Post #0 Refback 10-26-08 12:07 PM
It's done! 3.0-liter turbo-diesel FJ60 from TLC - Page 3 - Expedition Portal Forums This thread Refback 10-03-08 02:18 PM
Upstate Cruisers Tech Archive This thread Refback 10-01-08 07:22 AM
My 60 mods thread - Page 5 - Expedition Portal Forums This thread Refback 09-25-08 03:12 PM
Latest Photo? - Page 22 - Expedition Portal Forums This thread Refback 09-12-08 03:05 PM
FJ60 Sway bars - Page 2 - Expedition Portal Forums This thread Refback 09-12-08 10:37 AM
newb intro - Page 2 - Expedition Portal Forums This thread Refback 05-19-08 06:51 PM
Diesel Swap in Overland Journal... What are costs??? - Expedition Portal Forums This thread Refback 05-19-08 02:58 PM
newb intro - Page 2 - Expedition Portal Forums This thread Refback 05-18-08 03:41 PM
Upstate Cruisers This thread Refback 01-26-08 11:59 AM
