#61 |
Ante up to an 80 series!
I can say that there have been times I wish I had a selective brake traction control. Off the top of my head, a steep hill climb with the front locked is scary when it starts to slide laterally. Traction control can keep this from happening while still providing traction since all tires are on the ground. If the 80series had a driver selectable TRAC it would be the greatest 4x4 ever imagined.
For thread relavance, do the 80series. Rides fabulous stock and just fine lifted/outiftted on the street. The SFA kicks ass and takes names off-road. I know you guys don't have such a tender ass that you really need the smoothness of a 100series.....be a man and buy an 80series. |
#62 |
Depends on how you look at it Bear. One might say:
"Buy a 100, show off your driving skill, and be a man and take that thing where the 80's roam to show them the 100's can do it too"
__________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/az-arizona-land-cruiser-association/150735-100-series-modification-differences-evaluations-john-shotts.html Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#63 |
Central Scrutinizer
So what was wrong with your 450????
__________________ Mine: 1993 FZJ80, Classic White. ARB Commercial, Warn 8274, Hanna Sliders, CDL, P7, JD HIRs, Slee harness, Dual Batteries,850/863, Slee 25mm spacers, SS brake hoses. 1965 M416 Trailer. Hers: 1988 FJ62, Red, Stock "El Rojo Grande" Copper State Cruisers Member #85 "I would remind you that extremism in the defense of liberty is no vice. Let me remind you also that moderation in the pursuit of justice is no virtue." Barry Goldwater |
#64 |
Nothing. It's rebuilt. Well...I still have some vibes which we'll find the culprit of. It's my 100 that needs TLC. It's that time.
__________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#65 | |
Central Scrutinizer
Sorry, I meant the thread starter.
#66 | |
The New Avocado
Having been out with a good driver in a 100 series with locker(s) and 285's on OME, they have just a bit less clearance than the 80 for rock crawling so you are going to get hung up just a bit more. SFA is great, but the 80's doesn't flex much more than IFS if at all, so it isn't a major advantage except in the simplicity department. The big differentiator between the 100 series and the 80 series is that you can run 35" tires on the 80 on a small lift, and you can't on a 100 without trimming the fenders unless I am missing something. That is a major difference in rock crawling, but not for so called expedition use. So outside of cost of vehicle, your looks preference, and comfort, the biggest question is whether or not you want to run 35's. If you want to run 35's, the 80 is a no-brainer and the 100 shouldn't even be on your list unless you love your sawzall. If you only want to run 33's, then cost of vehicle, looks preference, and comfort are the only things that are going to much matter for extended camping trips. If I was going on an Alaska trek, I wouldn't even want selectable lockers. You get hundreds of miles away from civilization and you better be able to fix your junk on the spot. Nay __________________ 1995 FZJ80 - F.O.R. 3.5" lift - 35" trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted |
#67 | |
1. True...TRAC is no substitute for triple lockers, HOWEVER...there are plenty of off-road situations where lockers slide you and TRAC does not. On a 100 with TRAC and lockers you have the best of every situation. This is not possible in an 80. I've been in many situations where 80's were in the ditch when my 100 with TRAC was not. Then figure in ice and snow where TRAC and VSC just dwarfs lockers. 2. Clearance...right on. Man, that extra inch can sure help ya. As far as overall flex? I have to disagree. The standard OME 100 suspension vs the standard OME 80 L-suspension...the 80 has much more flex (front and rear). It's only if you combine OME 80 suspension gear (863 and N74L) that a 100 will flex similar to an 80. Even so, the 80 front has another 3-inches travel than the 100. That helps...though locked it isn't usually a deal stopper. 3. No cutting is needed to fit 315s on a 100. Only a couple extra EZ steps are required. 35's is a no brainer on either Series. __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#68 |
IH8MUD Lifer - No Appeal
I got my 80 after owning a 40 and a 60. They all have their strong points, but I needed a long distance driver that would go the last 50 miles of really bad roads without issues. The 80 is close to the ideal compromise between comfort and luxury and hard core expedition rig. This truck has OME suspension and 33" Revos and tracks down the road like it's on rails. Comfortable for my little 1000 to 1500 mile jaunts. This is mainly a hunting, fishing and camping rig.
I also have a Ford Expedition that has the power, and roadability of a 100 series, and much more tow capacity, but without the luxury SUV price. Sucks off the road. __________________ '96 FZJ80, locked, Hanna sliders, ARB bumper, Kaymar rear with spare carrier, 45 gallon Longranger aux fuel tank, OBA, Hella 4000's, OME lift, 285/75/R16 Revos & AutoHome Maggiolina rooftop tent, etc. Custom Cruiser trailer with OverLand tent www.AutoHomeUS.com TLCA Member #14874 |
#69 | |
You must have missed my posts on that "lift thread"? My comments about my recent "rock crawl" trip that I've done in both trucks. The 100 met it's match there. It made it with only a bent rear arm and dented rear drive shaft but it was just a whale. TOO BIG...TOO HEAVY...TOO SOFT A FRONT SUSPENSION for this type of trail. Don't get me wrong. It did awesome. This was a DIFFICULT trail that's hurt 80's (and my LX) before. But massaging the huge 100 through took the trip from PARTY to WORK WORK WORK. When I wheel I wanna PARTY! For these rock crawl trails the 80 rules! __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#70 |
just wondering here, i have heard mention about the engines in both ther 80 and 100 and how many or few problems they have in the 200k area....is that really all these engines will go for?! its 200-250k? i realize that these vehicles are reasonably new and wont have the same number of k's my '74 FJ40 has but my engine still runs strong and i dont even want to think about how many times the odomiter has been rolled....or for example my moms old celica that had 280+k on it before we flipped (sold) it cause it needed to be re-built and i didnt have time or energy to re-build it.....the point of this post is are these engines really only expected to last for 200k or so? or do i have the wrong impression
__________________ in my driveway.... '74 FJ40- disc brakes, saginaw,8274. SM420 sitten in the shop just waiting '78 FJ45 project rig x2 '81 BJ42 '86 HJ60 |
#71 |
Amongst friends.
And to the next post by yotawheeler: Many reports of 80s and 100s above the 200K mark. More 80s obviously as they're older. I plan on having my Cruisers to the 250K mark minimum. __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#72 | |
I Solve Problems...
did I get that right? __________________ a couple pairs of pink panties... Another convert to the Church of Latter Day Swank, a sub-cult of Shahrislam "...Opportunity doesn't knock, you have to kick the fuckin door in and drag the bitch out screamin." -- Ullr "I have more respect for people who change their views after acquiring new information than for those who cling to views they held thirty years ago. The world changes. Ideologues and zealots don't." - Michael Crichton Buy TEQ Bottle Openers
#73 | |||
The New Avocado
The 80 does have one key benefit that the 100 may or may not have: AWD in low range with CDL switch. While I am not a huge believer in being open in low traction situations because breaking traction with wheelspin is not something I believe helps you, low range gearing with nothing locked including the center is an incredibly flexible platform that is mechanically in the driver's control. Quote:
My guess is that your post about the 80 handling your hardcore trip better than the 100 was more about clearance than it was about suspension. I think we split hairs somewhat comparing big huge Land Cruisers vs. comparing the 80/100 to other smaller rigs that would also make very competent "expedition" vehicles. To say it another way, money aside, you could easily make a 100 more capable than 95% of the 80's on this board, including mine. If you just have to have a SFA it wouldn't be that difficult given you'd just need to copy the 105 rather than starting from engineering scratch. Yes, you gotta pay to play, but you are going to have those kind of costs to get an 80 way out of the box, too. Quote:
. We can laugh all we want about comfort, but after a day of being in the 80 my backside just hurts. The idea of an "expedition" rig is something you can drive all day long in comfort, and the 80 needs aftermarket seats to fit that bill. Those will come for me before I even regear, because my arse hurts a lot more than my "OD Off" thumb. __________________ 1995 FZJ80 - F.O.R. 3.5" lift - 35" trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted Last edited by Nay; 12-06-06 at 04:20 PM. |
#74 | |
Dang....my site's down. I can't get the link. I'll post tomorrow. __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#75 |
http://shottscruisers.smugmug.com/gallery/984600
You don't NEED to bump-stop the rear. I did...didn't want the rubbing. If you add N74L then you gain back your articulation plus 0.6" despite the bump-stop addition. __________________ NEW! My 100-series Step-by-Step 5-year buildup: http://forum.ih8mud.com/showthread.php?t=150735 Four-Wheeling Website: http://shottscruisers.smugmug.com/ |
#76 | |
You want to do what...?
tech content: I'm building my 80 for exped.... Will do all I want / need. 100 maybe later when it has come down a bit from its stratospheric price range.... __________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD souped up DR650 |
#77 |
well
after reading 4 pages of that i`ve come to the conclusion that no one has driven the 100 series with DIESEL POWER!
1hd-fte is intoxicating and is the only part i would put in my 80`but they still have problems too,just today i changed out a injection pump because of a crook spool valve,and the weak front diff issue,also torque converter not unlocking
__________________ HDJ81 Daily driver 78 FJ55R-KC under construction 84 FJ40 NASTY RUSTY BUSH TRUK |
#78 | |
The quick brown fox .....
There have been a few engine rebuilds/replacements that we are aware of. Many were a result of a failed HG. (Junk, Robbie, Dave) while a few have been a result of lean fuel conditions (S/C, wiring) IMHO, your assumption is incorrect. -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#79 | |
You could go with either and be happy. Both are extremely modifiable, and rugged. It's personal choice on that one! __________________ 2004 UZJ100 "El Rinoceronte" - Gotta pay to play...
#80 | |
In these times, 200K miles on a vehicle isn't very much in my opinion. I would think that Toyota would engineer them to last for at least 400 - 500K without a whole lot of trouble. With a rebuild or two, they SHOULD last a million miles. That's my opinion however. I've seen old Toyotas with hundreds of thousands of miles on them and still running strong, starting at the first turn of the key. __________________ 2004 UZJ100 "El Rinoceronte" - Gotta pay to play...
