Go Back   IH8MUD.com > classifieds.ih8mud.com > Vendors Market > Vendor Forums > EMS Powered
Old 09-10-09, 01:43 PM   #1 (permalink)
Supporting Vendor
baktasht's Avatar
FZJ80 Performance Exhaust
EDIT 10/9/2009:
For anyone interested in purchasing the exhaust in it's current version, this is for you. We're calling it's current version p0.91. We've built a few sets already. With the p0.91 version, the things to note are:
* If you have a larger than factory spare tire in the factory location it may rub the exhaust pipe
* As noted by Ebag333, interference may occur with the rear control arm with heavy articulation of the rear axle during rock crawling
* Sliders should fit, but may require trimming (from what we've seen so far though, they should fit without trimming)
* Will be 100% bolt-on for 95-97 LX450 and Land Cruisers
* Should fit 93-94 FZJ80 as well, but has not been test fitted yet
Options:
Full "Header-Back" Exhaust (including Y-pipe & Cat section) - Complete ehxaust system. Bolts to the OEM headers and goes all the way back to the exhaust tip.
Y-pipe & Catalytic convertor section only - Bolts to the OEM headers and includes a high-flow catalytic converter. Bolts directly to the secondary OEM catalytic converter.
"Cat-back" Exhaust (Bolts to the primary OEM Cat) - Bolts directly to the OEM primary catalytic converter, and goes all the way back to the exhaust tip.
Sale thread here: http://forum.ih8mud.com/%2A%2A-ih8mu...t-upgrade.html
END EDIT 10/9/2009
Related threads:
http://forum.ih8mud.com/80-series-te...80-series.html
and
http://forum.ih8mud.com/80-series-te...s-powered.html
and
http://forum.ih8mud.com/80-series-te...o-results.html
Finished and ready to go:
baktasht is offline   Reply With Quote
Old 09-20-09, 06:47 AM   #2 (permalink)
Is this for sale?
I thought this came up in the classifieds, or did I miss something?
rtson is offline   Reply With Quote
Old 09-20-09, 08:50 AM   #3 (permalink)
Supporting Vendor
baktasht's Avatar
Classifieds? Nope. There are only 2 prototypes that were built so far. They will be for sale soon though.
Old 09-24-09, 02:54 PM   #4 (permalink)
do you have a price in mind yet?
And what is the tubing diameter?
thanks
"I love the smell of diesel in the morning"
1991 HDJ-80, 1HD-T stinky, Walbro, Racor, Donaldson, Warn winch, HUGE ho-made front bumper, OME 2.5", 33's, ARB Locka.
lacruiser is offline   Reply With Quote
Old 09-25-09, 12:15 AM   #5 (permalink)
Supporting Vendor
baktasht's Avatar
thanks
The piping is CNC mandrel bent 2.5" stainless steel. It is a great setup for naturally aspirated FZJ80's and turbo/supercharged FZJ80's running up to around 10psi.
We'll announce pricing in the next couple of weeks.
Old 09-29-09, 10:27 AM   #6 (permalink)
VanGo's Avatar
TLCA# 18273
Garage
Very nice-
Van
KB3RWR
1997 FZJ80, 40th, Locked, Slee'd, 285/75/16 BFG AT, 15# Powertank, 100K HG'd, OME 2.5", TaskLEDs, ARB'd, Warn M8000, Master Pull XD, Slee Sliders, Slee Skid Plate, IPF 900XSD, Safari Snorkel, LT MAF...
"We have the wolf by the ears, and we can neither hold him, nor safely let him go. Justice is in one scale, and self-preservation in the other."
-Thomas Jefferson
2008 Sienna
2006 Trek Fuel EX 7
1989 Trek 1100
1967 M416
VanGo is offline   Reply With Quote
Old 10-09-09, 03:10 PM   #7 (permalink)
Supporting Vendor
baktasht's Avatar
Options:
Old 10-10-09, 12:33 PM   #8 (permalink)
Sorry in advance if I missed it; what type of stainless was used, same as OEM? Any performance gains? Have you experimented with a resonator/small muffler near the tail pipe like the OEM exhaust, or could it be added? Some of the pipe sections look tack welded only, or is there something else there to form a tight seal?
Kernal is offline   Reply With Quote
Old 10-10-09, 04:08 PM   #9 (permalink)
Supporting Vendor
baktasht's Avatar
* The type of stainless used: 304SS, completely TIG welded
* No resonator at this time, future versions of the exhaust may have one
* Some of the pictures are of incomplete assemblies that are only tack welded. The final pieces are fully TIG welded.
Old 10-10-09, 05:38 PM   #10 (permalink)
Thanks for the info. Not sure what type of stainless the OEM system is, but it lasts a long time. Mine is getting close to the time for a replacement. What I do like about the OEM system is how quiet it is, don't really want it any louder, hence the question for the resonator; will that tone it down a tad? Also, assume that the single cat works as it should, no codes from the O2 sensors/ECU?
Old 10-10-09, 10:31 PM   #11 (permalink)
Supporting Vendor
baktasht's Avatar
I think it is fairly quiet as it is, just a bit deeper sound. The highflow catalytic converter we use is plenty to keep the emissions to a minimum. It is quite a bit larger than the factory cats and has a lot more internal surface area. Your factory O2 sensor and ECU will work fine with the catalytic converter we use and you will not get any error codes.
Old 11-03-09, 10:45 PM   #12 (permalink)
hatfieldcb's Avatar
TLCA# 2768
I'm interested. PM sent.
Chris Hatfield KCŘZAB
TLCA#2768, Ad Sales Manager, Toyota Trails/tlca.org
"As long as you're skating on thin ice, you may as well dance!"
'97 FZJ80, '69 FJ40 "Project Orange"
Rising Sun 4 Wheel Drive Club Cruise Moab 2010
Join TLCA, ask me how! New TLCA.org -----> Member Login!
hatfieldcb is offline   Reply With Quote
Old 11-03-09, 11:29 PM   #13 (permalink)
Supporting Vendor
baktasht's Avatar
replied...
