11-04-09, 09:08 AM
Anyone using a Comet SBB-5 antenna?
I passed my tech license test a few months ago and now am about ready to pull the trigger on a radio set-up. I'm thinking of getting the Yaesu FT-7900R, a Diamond K-400 mount and the Comet SBB-5 antenna.
Is anyone running the SBB-5 and if so how does it perform and is there anything you do not like about it?
I know a lot of guys use the SBB-1 with great results but I want something that will give a little more range and not have to buy two antennas right now.
Dan
I'm not lost......I'm exploring! ‹
97' LC 40th AE #2722, Slee Rear bumper, Hanna Sliders [KJ6BDJ]
11-04-09, 12:16 PM
You want to do what...?
IIRC I have it.
No indication so far that it's lacking. But obviously, bigger is better, rangewise.
 : '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!
 : '03: 115K
DDs: Accord, Prius
 : souped-up DR650
11-04-09, 01:00 PM
On the Golf Course!
Dan,
One of the gang that was at the last SoCal80's get together when we ran Holy Jim had the SBB-5. Wish I could remember who it was. Post in our section and you may get an answer. I think it was one of the SD guys too!
I run the SBB-1 for trail use and daily on my commuter Miata. SBB-7 for daily street use on the cruiser.  the SBB-5 being right between the two! I've been considering upgrading the Miata to the SBB-5.
There is a noticable difference, for all the obvious reasons, in range/performance between the SBB-1 and SBB-7. The 7 is just too damn tall, even on the short trunk lid of the Miata to be able to drive into the garage! The 5 would be perfect.
You'll like the Diamond mount on the rear hatch. I use one for both the ham and the CB. Running the 4' firestik for the CB with a heavy duty spring and it's taken some pretty good whacks on the trail and the Diamond mount has held up real well so far. The SBB-1 is short and flexible enough that I don't worry about it on trails.
Brent
'94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; BFG MT KM2 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik!
TLCA Member #13420; KI6SGO
11-05-09, 11:24 AM
OHV Trail Patrol
x2 on the Diamond mount. Another nice thing with the Diamond is you can rotate the antenna down if you need to. Every once in a while, I get out and drop my SSB-1 for a low limb section of trail.
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
11-05-09, 09:15 PM
Dain Bramaged Member
In my FJ40 I use the FT2800 with the SBB-1 and SBB-25. The SBB-1 is used in heavy brush etc. The SBB-25 is used on the highway, or in open country. It is tall but it is a fold down antenna so you can lower it when you go into a parking garage. The SBB-25 is a 5/8 wave antenna so it has a horizontal radiation pattern, good for simplex between vehicles, and a good impedance match with no ground plane so it works well as a hatch mount.
If you have a good ground plane the SBB-1 works well. It is a 1/4 wave antenna and it needs a ground plane to achieve a 50 impedance match. It's radiation pattern is more vertical than the 5/8 wave antenna so it is good for hitting those repeaters located on high points like mountain tops or tall buildings.
I've found that the SBB-1 works well enough without a ground plane on the trail for all practical purposes. Most times you stay within a few miles of each other on tight trails and that is well within the range of the antenna.
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
11-05-09, 09:20 PM
Originally Posted by e9999
..... But obviously, bigger is better, rangewise.
This is not always true. I suggest you purchase the ARRL antenna design book and study it before you make such broad statements.
Dan Johnson
Rust never sleeps.
11-08-09, 05:31 PM
The SSB-5 looks to be a 1/2 wave antenna. I have the Diamond version. The 1/2 wave does not need a counterpoise/ground/ground plane to get a decent SWR like the 1/4 or 5/8 wave varieties. It allows greater mounting options.
The 1/2 wave a has a more gain at the horizon than the 1/4 wave.
