Go Back   IH8MUD.com > General Tech Forums > Electronic Toys
Old 10-19-09, 10:45 AM   #1 (permalink)
Moby's Avatar
voltage sensing relay (0-5 volt)?
Not sure if this is the right forum for this but I'm going to take a shot...
I'm looking into replacing the (AFM) air flow meter on my FJ-62 with a programmable MAF unit. The main problem that I've got is that the OEM AFM unit has a fuel pump relay integrated into it. If the meter is not actually flowing air the fuel pump turns off to prevent dumping gas into the engine bay in the event of an accident. I realize that I could hack this with an ignition hot relay but that kind of defeats the intended safety feature.
What I need is the ability to trigger a relay based on any voltage > 0 (the AFM scale is 5-0 volts where 5 is low flow and ~0 is high). I've seen voltage sensing relays that go down to 3 volts but I need more resolution than that.
Any suggestions?
Joel
'89 FJ-62
Moby is offline   Reply With Quote
Old 10-19-09, 02:38 PM   #2 (permalink)
Dain Bramaged Member
rusty_tlc's Avatar
TLCA# 15069
Any suggestions?
Build an OP amp comparator circuit to drive the relay.
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
rusty_tlc is online now   Reply With Quote
Old 10-20-09, 09:57 AM   #3 (permalink)
Moby's Avatar
Excellent, thanks! A quick search indicates that I have some studying to do
Joel
'89 FJ-62
