09-09-08, 12:39 PM
#31 (permalink)
Dain Bramaged Member
Originally Posted by CreeperSleeper
Got my call sign!!! KE7VSA
Good for you
73
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
09-10-08, 10:25 AM
#32 (permalink)
OHV Trail Patrol
Thanks guys.. I ended up wrecking my daily driver Monday night, so it may be a while before I can afford a radio. It's been a somewhat stressful week!
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
09-10-08, 06:58 PM
#33 (permalink)
OUCH !!! Hope all is well... as can be.
78 FJ 40 Russstard..and a sistership for parts
7.5 Fishmerwester plow
09-11-08, 01:51 PM
#34 (permalink)
OHV Trail Patrol
Well, nobody was hurt... The first inspection showed damages equalling 40% of the value, but we won't know for sure if it's fixable or not until they get it on the rack and start pulling it apart.
KE7VSA - MetalTech
10-03-08, 01:13 PM
#35 (permalink)
OHV Trail Patrol
Okay, I think I've narrowed my search down! I'm going to start off with a mobile unit. I'm thinking about a Yaesu FT2800M. Now I just need to figure out what ant to buy...  Any information you may have will help!
I will get a HT eventually, probably a VX-170.
KE7VSA - MetalTech
10-07-08, 12:30 AM
#36 (permalink)
Guy Fawkes Lives!
as for antennas, I've had very good results with the Larsen NMO 2/70 BK and the NMO Kit (coax with end connectors). About $60 total.
I've also had great performance with the Larsen NMO 2/70 SH (shortened version with a spring loaded base).
If you'll be mounting somewhere with poor ground plane (say your front/rear ARB bumper) you might consider the Diamond NR7700 - this 1/2 wave antenna works phenomanally well (get the matched coax, it is a key component of the system).
Good luck!
1996 FZJ80 (original owner) Less Stuff than WFD175
