Product Review: CB-AM/FM Antenna Splitter (Firestik AR-1A Match-Maker)
I purchased this device because I wanted to use my CB antenna as my AM/FM antenna so I didn't have to have 2 antennas on my truck. I installed it on Saturday and I've been trying it out for the past 2 days.
Info: walcottcb.com AR-1A Basically what this unit does is split your CB antenna signal into a dual-cable that hooks into the CB and stereo head unit for AM/FM signals. CB Antenna -> Match-Maker AR-1A -> CB Radio/Stereo head unit Installation: Installing the unit was simple enough, and the instructions were very easy to understand. You disconnect the antenna coax from the radio and plug it into the Match-Maker, then you plug the coax cable from the Match-Maker into the CB radio and plug the standard antenna cable into the back of the AM/FM stereo head unit. I should note a few things about tuning: - Your SWR should be properly set for your antenna/radio setup BEFORE you even start hooking the Match-Maker up. For more info on tuning your CB radio/antenna, see Firestik's tech help section: Setting the SWR of Your Antenna© - Firestik® Antenna Company - Once you hook up the system, put an SWR meter in between the Match-Maker and the CB radio. Using the built-in tuning screw, you must tune the Match-Maker so that the SWR is below 2.0 on CB channels 1, 19, and 40. Make sure you remove the screwdriver from the Match-Maker when measuring SWR or it can throw off the reading. Make adjustments in no more than a half-turn at a time, as it is very sensitive. These steps are very important because when I first hooked it up the SWR was in the red on all channels because the Match-Maker hadn't been tuned to match my setup. Performance: I don't use AM, so I haven't tested that, but FM seems to be very clear but the range seems to be decreased. I can't catch as many stations as I could before, but what stations do come in are much clearer. However, there is occasional static "blips" but they are not very noticeable. The one reason I think that I might not be able to catch as many stations is because I only have a 3' Firestik and it is mounted fairly low, so it does not stick up above the roof of my truck. Therefore, if you have a whip or taller antenna, you will probably get much better reception. The CB TX/RX range does not seem to be affected and I hear no interference from using both devices (CB and radio) at once. Overall: I am satisfied with this unit but if you listen to the radio very often and you listen to a wide variety of stations, make sure you install this unit within your first 30 days of return policy to you can make sure it works for you. Otherwise, it is a great solution for someone like me, who only listens to the radio occasionally and didn't want to have 2 antennas on my truck
Thanks for the writeup ... my power antenna needs replacing, and I've been thinking about just putting a CB antenna there and getting one of these.
I have this mod and love it.
__________________ Ken, Cascade Cruisers '64 FJ40, '66 FJ45, '79 FJ40, '81 BJ42, '82 BJ42, '85 xcab, '89 FJ62 Steens Photography, LLC |
Where did you get this unit? Reccomended vendors?
They're only about $20, really anywhere that sells Firestick should work.
I got it from walcottcb.com - very reputable and I haven't had any problems with them.
If you don't mind my asking... what type/size of antenna do you have? Upon further use I'm noticing that my FM band is really pretty week (I'm only running a 3' Firestik). Do you have any tips on tuning it?
Anything further on this? How bad is your FM with a 3' firestik ... I know that's hard to quantify.
It only really becomes an issue when you are getting out of range of the station - it has less reach than the stock antenna.
-Phil |
#10 | |
#11 |
I was going to post a thread about this, but then I ran across this one.
Just installed this splitter, and my FM is coming in better (I had a 1' rubber whip on the fender beforehand), and the CB SWR numbers have dropped considerably after tuning. I'd recommend this, especially since it's so cheap. I'm running a 4' Firestik-type antenna on the front bumper, and nothing on the fender. I like the look with only one antenna. I also tuned the AM, and it's working fine, too. I don't use AM that much, though. __________________ 1985 FJ60 1987 4Runner 2007 Honda XR650L |
#12 |
I am about to order the 3' Firestik but I noticed some options, for the complete CB newb, which of the firestiks do you recommend AND how to mount them on an externally stock truck? I have seen some cool mounts that fit between the hood and the fender but no idea what was used. Back bumper is ok too if I knew what other 80 owners used.
__________________ 70 FJ40-sold, worst day of my life 79 TOY 4WD pup-stolen, 2nd worst day of my life 91 4Runner 4WD-burned to ground, 3rd worst day of my life 83 FJ60- suckiest day of my life 97 LX450, 216k, non-locked. Expedition vehicle in progress ふざけんなよ! |
#13 | |
WalcottCB.com: Hood/Fender/Door Groove - The Firestik II with the tunable tip is fantastic. I love my 3' one - has plenty of reach and fits in my garage (it's mounted on my front bumper: ![]() Make sure whatever you order that you get a spring and a good Coax cable - this is imperative for a good setup. I just buy the Firestik kit as it comes with great directions... This kit may actually work for you - includes the hood groove mount and coax - just add a spring to your order as well and you should be all set to go. I don't know if this hood mount would fit our trucks but I've seen a similar one used. Firestik MK174 - Hood Groove Mini Kit Also, DO NOT USE YOUR RADIO UNTIL YOU HAVE TUNED IT! You can damage the radio! PM me if you wanna work out a time that you can stop by my place and we can tune your antenna (EDIT - I know this sounds gross... but I should have clarified and said your "CB" antenna lol) - I've got an SWR meter and we can get it all set up for you. Set it and forget it! ![]() -Phil |
#14 |
Phil you rock!
As soon as I get this ordered and in my hot little hands I'll let you know. Joey __________________ 70 FJ40-sold, worst day of my life 79 TOY 4WD pup-stolen, 2nd worst day of my life 91 4Runner 4WD-burned to ground, 3rd worst day of my life 83 FJ60- suckiest day of my life 97 LX450, 216k, non-locked. Expedition vehicle in progress ふざけんなよ! |
Web Advertising | Mortgage Calculator | Personal Loans | Online Loans | Bad Credit Mortgages |
