Go Back   IH8MUD™ Forums > General Tech Forums > Electronic Toys
Old 11-10-07, 10:49 AM   #1
Angel?'s Avatar
TLCA# 16516
New Offroad GPS and Dual Band Radio Installed
http://expeditionportal.com/forum/showthread.php?t=9237
Cal
W6CRH
South San Francisco Bay Area
Los Gatos / Monte Sereno, CA
1994 FZJ80
Angel? is offline   Reply With Quote
Old 11-10-07, 11:48 AM   #2
You want to do what...?
e9999's Avatar
fancy! nice job!
how long does it take to remove the DS seat?
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD
souped up DR650
Old 11-10-07, 01:34 PM   #3
Oh yea, verry nice; much better than I did.
D.F.Morse
1994 FZJ80 Kazumatized 74000 mi
1979 FJ-40 74000 mi
Here endith the lesson
dfmorse is offline   Reply With Quote
Old 11-10-07, 04:04 PM   #4
mobi-arc's Avatar
That's a lot of radio.
'98 Land Cruiser, MOBI-ARC Underhood Welder Equipped, POWER-GATE Dual Battery Isolator, Slee Dual Battery Tray, Long Ranger 180L Aux. Fuel Tank, TJM Nudge-bar, dual Hella HID's, BFG AT 295/75/R16's
www.perfectswitch.com
mobi-arc is offline   Reply With Quote
Old 11-10-07, 11:26 PM   #5
Angel?'s Avatar
TLCA# 16516
Originally Posted by e9999 View Post
fancy! nice job!
Thanks!
Removing the seat is quite easy. Whole process first time thru start to finish might be a total of 15 minutes. There are four bolts holding down the seat - two front and two rear. All bolts require the use of a 14mm socket with a 3" extension. The front two bolts are removed with the seat completely back. The rear two bolts are accessed with the seat completely forward. The rear two bolts are covered by plastic trim pieces that are easily removed. With the four bolts out and the seat completely back, the front of the seat is tilted up, giving you access to the power seat electrical harness plug in the center, which you unplug. Then the seat can be lifted up, swung and removed from the car thru the drivers door. Installation is the reverse process. Make sure the bolts are tightned well.
Cal
W6CRH
1994 FZJ80
Old 11-10-07, 11:28 PM   #6
Angel?'s Avatar
TLCA# 16516
Kind words - your install writeup allows others to understand the componets and the process. Thanks for the thread - it was very helpful!
Cal
W6CRH
1994 FZJ80
Old 11-10-07, 11:36 PM   #7
Angel?'s Avatar
TLCA# 16516
Kenwood TM-D710A dual band amateur radio
So I am just learning. In addition to being dual band, it allows dual receive on the same band. It is APRS ready (I just worked my way through the setup with the 540c GPS today). It can act as an APRS digipeater by itself. It has a large number of memory channels, has some powerful scan capabilities, and weather alert. And it can be connected to the internet as a node. Think it is all the radio I may ever need. I am very happy with it.
Cal
W6CRH
1994 FZJ80
Old 11-11-07, 08:00 AM   #8
e9999's Avatar
Originally Posted by Angel? View Post
Thanks!
good to know, thanks.
And plenty of clearance under there for the radio box or very tight?
DD
souped up DR650
Old 11-11-07, 09:11 AM   #9
Angel?'s Avatar
TLCA# 16516
I suggest you get the dimensions of the unit you are planning on installing, and if possible, make a mock-up of the unit's dimensions in a cardboard box.
With my setup, I moved the alarm as far to the driver's side as I could, so I could install my unit in the center of the underseat area - otherwise it would not fit as it was being hit by the seat track nearest the passenger side. In the center of the underseat area, it clears without contact.
My unit's dimensions are 5.6" wide, 2.5" high (with the 0.5" aluminum channel tracks and the unit's bracket), and 6.35" deep.
Cal
W6CRH
1994 FZJ80
Mortgages | Ringtones | Car Credit | Buy PSP | Mortgage Calculator
