Guy Fawkes Lives!
FT-8900R ? (Ham radio unit)
Anyone using a FT-8900R?
I currently have just a simple Cobra 75wsxt all-in-one CB deal purely for trail use. I was looking to add a nice Ham setup, even though I they are not much in use in my wheeling group (but I like the idea). I've followed other threads here and I noticed the recent post about great deals at gigabit.com (Romer also purchased his FT-8800 at gigabit.com). I was looking at the ultra-great price on the FT-2800 but figured if the FT-7800 was good enough for Romer, then it was good enough for me ![]() While looking at the details, I incorrectly clicked on the link for the FT-8800 and noticed that the 8800 mentions UHF-UHF and VHF-VHF capability. Not sure what this means. It also has cross-band features that I don't understand and will probably never use (which I now know is why Romer went with the 7800). It also doesn't seem to have the NOAA alerts ![]() But while lost and looking at the 8800, I found the details on the 8900R and the following description: The FT-8900R provides extended receiver coverage beyond the Amateur bands, so you can keep informed of communication activities in the public safety, commercial, aircraft, and government communications ranges. Included is coverage of 28-29.7 MHz, 50-54 MHz, 108-180 MHz, 300-480 MHz, and 700-985 MHz (cellular frequencies are blocked and non-restorable).This 'quad-band' option sounds pretty darn neat. But am I understanding this correctly, will the 8900R send/recieve on the CB bands (and at a whopping 50 watts)? and also the marine VHF bands? Other than the higher price, is there any reason NOT to go with the 8900 over the 7800 or the 8800? What antenna setup would I need to transmit/receive on such a wide range of freqs? Geez, you guys really make it hard to get anything done. Just last week I was following this forum to determine what antenna I should buy for my simple CB radio (I'm still looking at the firestick antennas BTW). Now, as a result of reading too much, I feel the pressure to spend even more money on new toys I didn't even know I needed
__________________ 1996 FZJ80 (original owner) Black & Oak, 105k miles with factory F/R lockers, CDL switch, hand throttle, OME Springs & Shocks, ARB, Warn M12000, Milford Barrier, Dual Optima Blues, extended breathers, OEM dash cupholder, 285/75/16 BFG AT, Landtank seat rails, Slee AC dryer & T-case skid plates, Slee light & aux harnesses, Slee SS brake lines (frame->axle->caliper), V-1 with remote display, Icom IC-7000, Yaesu 8900R, Cobra 75wstx, Larsen NMO-2/70 & NMO-27, 100-series pads Last edited by Miescha; 10-09-07 at 06:11 PM. Reason: typo |
The 8900 won't TRANSMIT on the CB or marine bands. Off the shelf HAM transceivers only transmit on the HAM frequencies. Many transceivers offer wide receive coverage - but will transmit on the HAM frequencies only.
There are 4 band antenna units out there for the 8900. Diamond and I think Comet both make an antenna specifically for the 8900. cheers, george. __________________ where ever you go, there you are.... '97 S/C White CE, locked^3, sliders,arb,kaymar, m12000,dual batteries, LEDs, etc..... ki6ibx http://www.george4wd.taskled.com |
That 8900 is way more radio than you need. It will also be more difficult to operate and much more expensive.
Start with a single(2m) or dual (2m, 440) band. The 8800 has some nice features, but for significantly more $$ than the 7800. The one on sale for $107 the 2800 is a fine radio, hard to go wrong there for the price. On the 8800 the UHF/UHF etc, really means it is basically 2 separate radios. You can tune 2 frequencies of VHF, 2 of UHF or 1 or each. The cross band repeat allows you(for instance) to talk to your truck with a hand held on say UHF, and have it repeat the transmission at much higher power on VHF, then back, in reverse. I could imagine a use or two for that. __________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, Now SOA! 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
Guy Fawkes Lives!
Thanks for the help guys. The 8900 really is way more than I need - and as cruiserdrew noted, probably way more than I can handle. But it sure is purty
![]() I'll probably just follow Romer and go the exact same route with the 7800 and the same mount and antenna. As I said before, if it is good enough for Romer, it is probably good enough for me. I do however like the cross band repeat feature of the 8800 for the purpose of out-of-truck hand-held use (otherwise the measly 5w power of the handheld is not going to get far). Thanks again! __________________ 1996 FZJ80 (original owner) Black & Oak, 105k miles with factory F/R lockers, CDL switch, hand throttle, OME Springs & Shocks, ARB, Warn M12000, Milford Barrier, Dual Optima Blues, extended breathers, OEM dash cupholder, 285/75/16 BFG AT, Landtank seat rails, Slee AC dryer & T-case skid plates, Slee light & aux harnesses, Slee SS brake lines (frame->axle->caliper), V-1 with remote display, Icom IC-7000, Yaesu 8900R, Cobra 75wstx, Larsen NMO-2/70 & NMO-27, 100-series pads |
#5 | |
Just for reference, we were playing around on the Rubicon with a 1 watt hand held patched in to a decent antenna, and hitting a repeater 50 miles away with clear communication. Most communication from my mobile is at 5 or 10 watts. The real limiter is the antenna, and that is the place to really hone in on a set-up that works for you. My guess is, you will love the 7800. Go study and take your test. This is how to find the closest exam in your area: http://www.arrl.org/arrlvec/examsearch.phtml __________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, Now SOA! 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
#6 | |
<brain dump> There are a couple of quad-band antennas (the Diamond CR-8900 and the Comet UHV-4. The Diamond, at least really is not bad on 2M and 440. The radio isn't very hard to use, at least for the same features you would get on a single band basic radio. The monitoring of two frequencies is nice. The cross-band repeater is nice only if you have a hand-held. Remember, you cannot use 10M with the basic tech license.</brain dump> In other words, the 8900 offers little extra to begin with; by the time you are ready to use it, you will probably want a radio in each of your vehicles anyhow. That said, it is a solid, straighforward radio, with a good display I have no trouble seeing in sunlight, a removeable display (easier installation), a nice microphone and a couple of extra bands to use in an emrgency. I like mine and do not regret the choice. __________________ '92 FJ80 stock | '94 FZJ80 not stock and currently *down* | '08 Tundra Grade DCSB 4x4 5.7 |
#7 | ||
Guy Fawkes Lives!
). Sorry.Quote:
I guess I could still monitor the 10M freq but just not transmit with the basic tech license. Oh well, its a start. Now to determine antenna choice and mounting location . . . __________________ 1996 FZJ80 (original owner) Black & Oak, 105k miles with factory F/R lockers, CDL switch, hand throttle, OME Springs & Shocks, ARB, Warn M12000, Milford Barrier, Dual Optima Blues, extended breathers, OEM dash cupholder, 285/75/16 BFG AT, Landtank seat rails, Slee AC dryer & T-case skid plates, Slee light & aux harnesses, Slee SS brake lines (frame->axle->caliper), V-1 with remote display, Icom IC-7000, Yaesu 8900R, Cobra 75wstx, Larsen NMO-2/70 & NMO-27, 100-series pads Last edited by Miescha; 10-19-07 at 06:03 PM. |
You want to do what...?
well, keep in mind that IIRC the FCC allows you to basically transmit on anything anywhere anyhow if there is an emergency, so tech license or not, if you're lost in the Desert and running out of water, hammer away at that 10m...!
__________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD Accord souped up DR650 |
#9 | |
As for the antenna: http://www.eham.net/reviews/detail/4946 & http://www.universal-radio.com/catal...antm/2123.html (not the cheapest place, but the first link I found) or the Comet versions http://www.universal-radio.com/catal...antm/3248.html and http://www.universal-radio.com/catal...antm/4289.html In either case, either drill your roof or get a Diamond K-400C mount and mount it on liftgate lip or the hood lip. Then get a shorter antenna like so: http://www.universal-radio.com/catal...antm/3914.html to actually use on the trail. The tall antennas are fairly fragile. I use the AX-75 (http://www.eham.net/reviews/detail/4...041d2a02897119) daily and seem to have no problems with an occasional tree branch encounter. __________________ '92 FJ80 stock | '94 FZJ80 not stock and currently *down* | '08 Tundra Grade DCSB 4x4 5.7 Last edited by aim; 10-11-07 at 10:13 PM. Reason: *&! spelling! |
#10 |
addict.
FWIW, I'm really glad I popped the extra $$ for the 8800 over the 7800. I regularly "monitor" two channels in the truck, and have at times held conversations on two of them, it's so easy to flip back and forth. Best example is the late guy reaching the group on the repeater channel, while the group is all on simplex. I also haven't missed the extra features of the 8900, it just seemed like too much to cram into that little box. But to be honest, I still haven't done anything outside 2m, other than listen to KOA on 440.
__________________ 96fzj80, mostly stock except for the suspension, steering, gears, brakes, batteries, lights, bumpers, running boards, skid plates, stereo, speakers, cargo area, and tires. some of my best friends are TLCA members. |
#11 |
I now have 3 ham radios HT, HF and the 8800. The 8800 is by far the best choise for the truck for the easy of being able to monitor 2 channels at once. I normaly leave one side tuned into the pack and the other side scanning the near by repeaters. It is also a very easy radio to learn all of the functions.
#12 |
when you monitor 2 channels on the 8800, they don't have to be on different bands then?
#13 |
bj74_guy?
Nope, you can monitor whatever band you like on either side. It's like 2 seperate radios in one box.
__________________ norm '85 BJ70 - old yard decoration '89 BJ74 - newer yard decoration |
#14 |
Guy Fawkes Lives!
I know its WAY more than I will ever need and probably more than I will use (at least initially), but I went ahead and popped for the 8900 (almost identical to the 8800, but for just a bit more money you get two more bands for a total of 4). I have figured out a mount or antenna yet. It came with the free remote face mounting kit as part of a Yaesu deal that is running until the end of October (otherwise that would add around $65).
#15 |
Well, congrats. That's a really full featured radio, and should keep you on the air for years.
Aim's point about the radio slowing sucking the battery down is a good one. Most of the Yaesus have a feature that turns off the radio after a period of non-use. I have mine set at 4 hours, so if I forget, it's off anyway. I did have a question about this radio. Is it one of the radios that you can actually control (like change frequency etc) from a hand held? That would be an extremely useful feature. Ie, you are using the cross band repeat, but you decide to change the main radio to another repeater frequency? __________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, Now SOA! 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
#16 | |
http://www.rigpix.com/yaesu/ft8900r_manual.pdf and http://hamradio.online.ru/ftp2/sch_serman_ft-8900.pdf I don't think so. That being said, I wish somebody would prove me wrong! As for Automatic Power-Off as Yaesu calls it - sure. You cannot turn the rig back on remotely, though. __________________ '92 FJ80 stock | '94 FZJ80 not stock and currently *down* | '08 Tundra Grade DCSB 4x4 5.7 |
Mortgage | Loan | Connecticut Flags | Adverse Credit Remortgage | Loan |
