Go Back   IH8MUD Forums > General Tech Forums > Electronic Toys
Old 10-06-07, 03:38 PM   #1
Boston Mangler's Avatar
TLCA# 9060
Best Antenna For a iCom V8000 2m??
Hey Guys
What antenna would you all recommend for an iCom 75watt V8000?
I am looking into a permanent mount, as short as possible, but dont want to sacrifice quality too much.
Anyone?
Baja Overland
www.bajaoverland.com
2006 XR650L
TLCA #9060
Own a Land Cruiser? Join TLCA Today @ www.tlca.org
Boston Mangler is offline   Reply With Quote
Old 10-06-07, 10:15 PM   #2
Any of the big manufacturers are fine. There is a Ham Radio Outlet in San Diego. The longer the antenna whip, the greater the gain, which means the higher effective radiated power (and receive).
For example, if one antenna has a gain of 3dB over another antenna, that means the effective radiated power is DOUBLED.
Kofoed is offline   Reply With Quote
Old 10-07-07, 01:18 AM   #3
You want to do what...?
e9999's Avatar
the shorty Comet SBB1 1/4wave is wonderfully flexible, but its SWR can be much worse than that of the longer SBB5 1/2w (see other thread), so short is good for trees but not necessarily so great for the xceiver if it's not tuned... It also gives you 1.5dB less. Some compromise needed there I guess.
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD Accord
souped up DR650
Old 10-07-07, 09:03 AM   #4
ginericLC's Avatar
TLCA# 7328
My only advice is make sure you compare DB to DB and not to DBi.
Eric V. TLCA 7328
99 UZJ100 "T-REX Edition" under construction
FJ68 PROJECT aka LEGO(60 body, 80 Chassis/Running Gear)
74 FJ15 (that is about all that is left of it)
Lots of Parts FS http://forum.ih8mud.com/sale-parts/2...ml#post3693029
ADIDALC "real environmentalists don't pave roads" "dents are like tattoos with better stories"
www.WildWildWestArt.com
ginericLC is offline   Reply With Quote
Old 10-07-07, 07:06 PM   #5
Cruiserdrew's Avatar
TLCA# 11734
Kevin-You have probably figured this out already, but, there is no free lunch. For best performance on a permanent mount you need a fairly long antenna, mounted as high as possible. Since you have a huge reflecting surface of the 80 for counterpoise, you can run a 5/8 wave antenna for best performance.
For trail use, short and flexible is best, hence Eric mentioning the SBB1 which is very short and very flexible. Since it's a 1/4 wave antenna, it's performance is not nearly as good. It works, though, just don't expect super long distance contacts. Compared to CB, it's still miles better.
If you are brave, and don't use a roof rack, you can drill a hole in your roof, and run an NMO mount. This is by far the best arrangement electrically, but, you have to drill a 3/4 hole in your roof! A lip mount on the rear hatch is a good compromise.
I have been playing around this week with some steel whip antennas from Larsen. I am trying to get better performance from my radio and still have an antenna that will take the blows, tree branches, rock overheads etc that are part of every trail. I'm thinking that steel whip may be ideal because it's tough, and easily replaceable if it gets bent or lost. For $12 you can even carry a spare. Just something to consider. I just put the Larsen 150CHW on my 40 and think it might be the ticket for offroading. You could run the 5/8 wave equivalent on your 80. I'm going to try that for Death Valley in March.
Andrew
1984 FJ-60 H55f, 4.11, Now SOA!
1997 FZJ-80 Driveway queen
Cruiserdrew is online now   Reply With Quote
Old 10-07-07, 07:12 PM   #6
TLCA# 9060
DAMNIT! I am starving!!!
Yeah, that is what i figured, i run a roof rack and roof tent, so space it limited. I will likely mount a plate to my rack and use a permanent mount to it.
Yeah, this will basically ONLY be used on the trail and communicating with other rigs on the trail. It will never be used for chatting with other radio folks while sitting at home!
That is what i am thinking, going to check the exact fitment of my rack and where its positioned and see if i can pull it off!
Care to elaborate?
Thanks for the tips!
Baja Overland
2006 XR650L
TLCA #9060
Online Advertising | Myspace Proxy | Free Credit Report | Alabama Flags | Loans
