CB antenna and wires help
I did do a search but still need help. I am a newby to CB and need some suggestions. I am looking to buy a Midland 1001Z 40, so what antenna and wire do I buy? Can I hook this directly to the battery or is there a better mode? Where is the best antenna placement? Thanks
Mike __________________ Mike Winder, Ga 1988 FJ 62 Georgia Crusiers Upstate Cruisers TLCA # 17859 |
IMHO, get a center load antenna. Where is the best antenna placement? If it’s on the 62, the best place is the center of the roof. Can I hook this directly to the battery or is there a better mode? Hook directly to the battery with proper fuses in both the neg. and pos. leads as close to the battery as possible. Now, real world. You would probably be better off to compromise and mount the center load antenna to the rear upper panel near the rear window. Keeps it out of the way for most trail grabbing items like trees, branches. Most center loads antennas do not have a spring base, as the antenna will flex some, but a short spring base may be helpful. Some put the antenna on the hood, if you do, make sure to add a couple of ground straps from the hood back to the frame, the painted hinges don’t make a good ground path. Make sure the antenna mount is well grounded to the frame of the truck as well. For the ground connections use a braid type line, not a #12 wire. Don’t use standard Radio Shack coax, get the best quality coax you can find with 100% shielding, in the RG8X size. Make sure the radio is well grounded also, not just a screw through the base into the floor pan. Get someone with a GOOD antenna analyzer/matcher to tune the antenna after all installation. Good luck, Jerry D. __________________ 1968 FJ40 - 2F, H41, ToyBox, 3 speed Xfer, 4.88’s, ARB's front and rear, York air, Saginaw PS w/Toyota pump, disk brakes around, Warn winch, Trail Gear 6 bolt knuckles, 4X4 Labs high steer, 38.5X14.5 TXL/SX, full cage, 3” body lift, 4” suspension lift, FF rear axle. 2007 FJCruiser: empty bank account. Member: Toyota Land Cruiser Association; Florida Land Cruiser Association; FL4WDA |
Advertising | Blog5 Game Cheats | Remortgages | Loans | Adult ADD |
