9/15/07 Sat Offroaders Ham Net
Going to keep at it until we all master this ham thing and are enjoying global comm from our rigs
![]() There is a lively discussion on expeditionportal.com about how we can improve this and if you look around there or here you will find my previous post on how to get on the net http://expeditionportal.com/forum/showthread.php?t=7882 It looks like Saturdays at 9pm Az time which is currently the same and MDT/PDT will be our default time until a change notice is made...that should help with the heat/busy days and if folks are checking in from a campsite then they are in rest & relax mode instead of trying to nav a trail at the same time. Join in with other newbies and some experienced folks and use your ham radio to talk offroad stuff. __________________ Assisting the handicapped with vehicle based backcountry access.
"The Adventure Duo"
I'll see if i can make it again... kind of on the late side.. but i'll try.
__________________ www.adventureduo.com [KI6LBB] 2004 Jeep Wrangler TJ X Edition 2003 Sportsmobile 4x4 EB50 |
9pm works much better for me I should be checking in
This is the first I've seen about this. Is there a link to the Net in Northern Texas?
__________________ I once had a lifted '87 Toyota pickup 4x4 22R 5-speed, etc. I latter had a '97 Tacoma X-cab V6 5-speed with all kinds of cool stuff on it. I now have a '07 FJC TRD SE 6-speed completely stock, but still has some cool stuff on it. Spaldam.com |
Thay are using the IRLP system and there are nodes all over. You can get the full list from there webpage http://www.irlp.net/
TLCA# 16387
It looks like I might be able to connect through a node in Chiapas, MX this weekend. Can someone give me step by step how to connect instructions? I have an Icom 706MkIIG in the truck with a dual band mag mount Radiall/Larsen antenna. The HF is not yet connected.
VA7 CFW 73 __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
It's so easy all you have to do is follow there simple instructions... ID youself, give your location and the location/node you wont to connect too and enter the node number on the keypad well still holding the PTT. wait for 5 - 10 seconds and if you did everything right you will hear a message play letting you know you are connected.
To end your call identify yourself and let others know you are dissconnecting the node and enter 73 well still holding the PTT. Again wait 5 - 10 seconds and you should here a message letting you know you are dissconnected... And as always listen before talking. This process is also layed out with more details on the IRLP webpage. Hope to here you on the air |
#8 | |
TLCA# 16387
#9 | |
echolink uses your computer and the internet but I have not played with it yet and don't know if you are able to link into the IRLP system with it or not (from what I have read) |
#10 | |
The quick brown fox .....
Is this 9pm PDT or is this 9pm MDT? -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#11 |
we in arizona have advanced beyond the need for your
primitive "daylight savings" ritual so right now we're the same as PDT... ... and don't blame lance he's a forward slash dyslexic. __________________ "Mate , you must drink some serious piss to need to get to youre chilly bin that quickly." - topend yobbo |
#12 |
So....
Off-Roaders HAM net Every Saturday beginning at 9PM PDT (~1hr) IRLP Western Reflector node #9251 To connect to the Off-Roaders HAM net: * Tune to the IRLP Western Reflector frequency in your area. (See www.irlp.net ) * Identify yourself (callsign) * Give your location and the IRLP node (9251) * Enter the node number on the keypad while pressing PTT ... wait for 5-10 seconds for a confirmation message To end your IRLP connection: * Identify yourself (callsign) * Let others know you are disconnecting from the node * Enter 73 while pressing PTT … wait 5-10 seconds for a confirmation message. Always listen before talking. The above process is described in detail on the IRLP webpage. (Do I have this correct?) -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#13 | |
TLCA# 16387
MDT = Mountain Daylight (Savings) Time PST = Pacific Standard Time MST = Mountain Standard Time Some places like Arizona have not discovered that you can adjust your clock though! Also some of Latin America does not always go onto daylight savings time because there is no difference in the amount of daylight throughout the year. Here in Guatemala it's almost always light at 6-6:30 in the morning and it's dark by 6:30-7:00 in the evening year round. __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
#14 | |
As clarified above, the time is 9pm PDT which is 10pm MDT where I live. -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#15 |
Anyone else on the net tonight? I can only see two nodes logged in Salt Lake City and myself?
#16 |
I thought about joining, but I was in bed by 11pm CDT, when it started.
Home Insurance | Car Loans | Online Loans | Love Calculator | Loans |
