Ham antenna mount on a 40
I'm trying to figure out the best way to mount an antenna on a 40 - since the top is fiberglass, it seems the hood may be the best ground plane - although I had one guy tell me the whole car works as a ground plane anyway.
Anybody have a spring mount? Another consideration is running under low branches... Any thoughts on that? __________________ '78 40, 4" Skyjacked, Aussie Locker, 33" MT's, Warn 8274 '99 4Runner with Jayco Baja Pop-up '04 Corolla LE 5-Sp Yaesu FT-7800R Dual Band VP, High Desert Cruisers Drill Baby Drill |
KI6MIE
I have run a mag mount on the fender, and it works surprisingly well. I was able to access a repeater system from Rubicon springs, so almost be definition, that's very good, since the repeater was down in Cameron Park. You could also weld or bolt on a mounting tab to the roll bar-That would be less redneck and a clean install.
__________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
What about an on-glass antenna. I've got a Radial Larsen and it works like a champ.
http://www.radialllarsen.com/ __________________ '98 Land Cruiser, MOBI-ARC Underhood Welder Equipped, POWER-GATE Dual Battery Isolator, Slee Dual Battery Tray, Long Ranger 180L Aux. Fuel Tank, TJM Nudge-bar, dual Hella HID's, BFG AT 295/75/R16's www.perfectswitch.com Last edited by mobi-arc; 04-28-07 at 01:45 PM. |
I tried a Pro-Am thru glass a couple of years ago. It worked until the low branches eventually took it off the rig. (Kiss that $40 good bye).
I'm currently going with a hoaky (spelling?) mag mount wired through passenger kick vent. The magnet sits front center just outside the windshield. But... I have dreams of converting the old fashion 40 series AM antenna to a ham stick. Anyone seen this done? __________________ 1981 BJ42/Factory smurf blue/PTO Ramsey 03 Volkswagon wagon TDI Only gassers left in my household are my Stihl chainsaws... |
I just heard there are some quarter waves that will bend over at a 90 and snap back - I'll see what I can find out...
KI6MIE
There are bunches of antennas that fold 90 degrees, and other extremely flexible antennas. I have one of each. If you really want flexy-look at the Comet SBB1. It is only 18 inches long, is flexible and works great for this type of use.
#7 | |
The quick brown fox .....
I had the SBB1 on my truck when we were testing your install last weekend. I also have the SBB5 that folds 90* and is ~38" high. Both are NMMO mounts if you want to try them on your mount. -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#8 | |
Thanks Steve __________________ '78 40, 4" Skyjacked, Aussie Locker, 33" MT's, Warn 8274 '99 4Runner with Jayco Baja Pop-up '04 Corolla LE 5-Sp Yaesu FT-7800R Dual Band VP, High Desert Cruisers Drill Baby Drill |
Wills | Credit Cards UK | WoW Gold | Mortgage Calculator | Fantasy Football |
