BJ42 Factory Tacho
My BJ42 factory tacho hasn't worked since I purchased the truck. Where the hell does the factory tacho hook up to to get the rpm signal on a diesel?
Could it be sender failure? What would be the most likely cause? Any suggestions? __________________ 81 BJ42 3B Ranchos, 31x10.5 Muddies Soon to be turbo! |
Bell housing is the correct location...
isn't the tach taking a signal from the fly wheel & the pickup bolts to the bell housing?
__________________ 81 BJ42/FJ40 Frame Off Conversion/Restoration... OEM Soft Top/1-piece tail gate New Brazil-Spec Front Doors PTO Winch OEM Full Floating Rear Axle Cable Locking Diff. Front & Rear |
#3 | |
Mod in Hibernation
Yes the signal is from the pick up sensor on the bellhousing. RH side. You should see a white plastic connector around the exhaust down pipe. Pull that off and put a meter across the terminals, you want about 500 ohms.
On the back of the tach, terminal 5 is power, thru the 15 amp engine fuse. terminal 2 is the pick up sensor. terminal 4 is a ground terminal 3 is a ground terminal 1 is power from the tail light circuit. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
#5 | |
Long story short, lost interest in my truck for a while there but now back (finishing) restoring it but still no working factory tacho.However you are right the tacho sensor is on the right hand side of the bellhousing. The connector is above the bellhousing and quite difficult to get to. My sensor is dead. Nothing coming out of the sensor, everything else seems ok. Took out my sensor today and I found out why its dead. Its missing half of the sensor. I don't know why but its been sheared off somehow by the look of it, at a 45deg angle (Flywheel hitting the sensor?) So where is the rest of it? Floating around in the bellhousing? So I got onto the phone to Toyota and quickly found out the tach sensors are no longer available. Next phone call to a 4wd spare parts place I lucked onto a sensor. Got back, went to install it and it didn't fit. I couldn't get the sensor all the way in to even start on the thread. It seems to be too long. Or is it somehow hitting the missing half of my old sensor? Or maybe its not actually from a bj42? Or is there a difference between the 4 and 5 speed tach sensor? Mines a 4 speed. Its starting to look like I need to pull the gearbox just to fix my factory tacho. Find the missing part of the sensor. Who knows what damage that has done. ![]() Ive fixed just about every problem the old truck has (except rust ) and thought this may have been an easy fix by screwing in the sensor but Murphy got in the way.I'll get some pics tomorrow of the original and replacement tach sensors. Has anybody else had a sensor like I described, sheared off? Cheers and hi all again. __________________ 81 BJ42 3B Ranchos, 31x10.5 Muddies Soon to be turbo! |
Old thread ..
the rest of your sender is in the bottom of the bellhousing or missed at all .. I'm not hold my breath for it. Just search on ebay for a new one .. could be and option .. Other option that come to my mind are the new version of the sender coming in 13B-T or 2H bell housings, IIRC are very similar .. but never get on my hand one from BJ42 to compare .. |
junkyard dog
I wonder if someone fitted a sensor from a 2H into the 3B? The length of the sensor is quite different between the two engines, and though i can't quite remember which one is longer, that would certainly explain how the end could have been sheared off - they put in the wrong tach sensor.
#8 | |
Can anyone tell me the lengths of the 3B and 2H tacho sensor? __________________ 81 BJ42 3B Ranchos, 31x10.5 Muddies Soon to be turbo! |
here is a sensor off of a 3B
![]() Best Regards Gord Last edited by exmodlad; 06-26-08 at 09:32 AM. |
#10 |
Thanks for the pic, its much appreciated. It confirms the replacement sensor I have is not for a BJ42 3B. Its twice as long.
Sorry for the crappy camera phone quality but its 1.30am atm which is why I'm not out ripping out the original sheared off sensor. __________________ 81 BJ42 3B Ranchos, 31x10.5 Muddies Soon to be turbo! |
#11 |
I do have some of these available for sale (4 only..USED)
![]() PM or email me for a price Best Regards Gord |
#12 |
in the bellhousing no ?
#13 |
If you need a bellhousing i have those too, also have the dust shields
Aluminum... !!!!!! ![]() Steel... !!!!!!!!!!!! ![]() Best Regards Gord |
Mobile Phone | Remortgage | Mortgage Insurance | Credit Cards | SMS-Sprüche |
