Diesel for blood
1HD-T gearbox
I got a line on a freshly rebuilt 1HD-T in my area. I was thinking if I bought would it bolt up to my 1HZ H55f?
The seller says yes ,but Birfield.com says it woud need a H151.:confiused: I tried a search but found conflicting advice. Can anyone clarify that? __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
yes it will bolt up to the old box. The h150 and 151 are similar boxes and both will bolt up also. The turbo diesel got the 151 and the non turbo and petrol 3f and 3fe got the 150 gearbox with the lower geared first gear.
#3 | |
Diesel for blood
mmm, uggh
rick d running H55 behind HD-T too (icky racing diesel thought up idea in 1996) |
Question:
To run a 1HD-T with H55, do you need the 1HZ bellhousing and input shaft from an H151? __________________ FJ-55 Weatherstripping www.pvcruisers.com FOR SALE: '81 HJ-47 Troopy LHD '07 Vortec Motor, 4L60E Trans, New Steel Body, PPG Paint, Rebuilt from the Ground Up '79 HJ-45 Troopy RHD |
hz h55 input + hz bellhousing + either hz clutch/flywheel (275mm) OR
300mm HD flywheel and isuzu clutch. |
#7 | |
Thanks Rick __________________ FJ-55 Weatherstripping www.pvcruisers.com FOR SALE: '81 HJ-47 Troopy LHD '07 Vortec Motor, 4L60E Trans, New Steel Body, PPG Paint, Rebuilt from the Ground Up '79 HJ-45 Troopy RHD |
#8 | |
If you already have 1HZ ( if I'm underestand well ) with H55F the new 1HD-T is a direct swap .. |
#9 | |
Diesel for blood
![]() About the 1HD-T .It was fully rebuilt 130000klms ago . The current owner did not know about BEB delamination and it spun a bearing and has had a new crank and BEB fitted by the original rebuilder. It was to be used in a 80 series ute but is now at the engine rebuilder for sale. Thanks for the replies. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL Last edited by roscoFJ73; 06-08-06 at 02:41 PM. |
#10 |
Can someone confirm that H151 input shaft is the same as H55F input shaft the transmission are completly different. I have both and they are different in every way I can think of, not to mention that 1HD-T clutch parts are very differnt from 1HZ clutch parts.
Cheers, Michael |
#11 | |||
Dave |
#12 | |
![]() Dave |
#13 | |
are completediferent .. input shaft. |
#14 |
Is the tailhousing and output shaft on the H150/151 the same as the R150/151?
If not, are the output shafts interchangeable? Thanks, Phil |
#15 | |
Michael |
#16 |
hz input 21 splines
hd-t input (H15X) 14 splines you cannot make a H15X input fit a H55. rear ends of H15X and R15X I believe are different. the cousin R14X (4sp, used in PZJ75 mine trucks) has a standard issue 38mm t-case on rear. not the 80 series t-case system. Dimensionally the H15X and R15X are two vastly different sizes and shifter locations. |
#17 |
Thanks for the information. Toyota has been pretty good about standardization in the past. An example is the x340x series automatics. There are 3 distinct transmissions that all share the same case. I was thinking the H15x and R15x might share the same case design(?) and therefore the adapter options for the R15x would potentially work for the H15x.
Phil |
Credit Card Debt Consolidation | Personal Loans | Mortgages | Debt Consolidation | Halifax |
