Old 04-24-06, 10:47 AM   #1 (permalink)
Fuel delivery screw
Can anyone send me a picture of where the fuel delivery screw and possibly the turbo boost screw/adjustment is. I received a pic. from another member who has a 2LT but it does not seem to match my system.
I have a 1990 LJ71 with the 2LTE . The reason I am asking is that I want to turn back the fuel as I'm blowing some black smoke on hills and under load etc.
Thanks.
108Cruz is offline   Reply With Quote
Old 04-24-06, 11:53 AM   #2 (permalink)
retired maths geek huh
denis's Avatar
the E suffix in 2LTE stands for "electronic fuel injection" which means all the controls are electronic. If you have lots of black smoke you either have bad injectors, wrong base timing or not enough air. For a start you could change your air filter, check the boost pressure and have the injectors serviced.
'71MS75 5cyl crown coupe '74MS75 6cyl crown coupe '74MS75 4cyl crown coupe '75BJ40 DD '79FJ55 rostig schwein '80BJ40 never ending resto '82BJ45 project troopie 50% '83LN46 no engine '84BJ45 project troopie 50% '88LN65 getting closer '90HDJ80 the bear '92LN85 turbo ute '96LN108 rustbucket
Originally Posted by LandCruiserPhil View Post
there are a lot more single women available then nice low mileage Land Cruisers.
denis is offline   Reply With Quote
Old 04-24-06, 12:21 PM   #3 (permalink)
Psilosin's Avatar
Sorry the picture didn't work out for you. I guess maybe the 2LTE injection pump doesn't have a max fuel adjust screw??
Probably your best bet then is to hit up the Australian Toyota Surf Owners Forum
Lots of guys there with 2LTE's.
Psilosin is offline   Reply With Quote
Old 04-24-06, 12:29 PM   #4 (permalink)
Thanks for the info guys.
I checked the air filter and it's clean. I will work at getting the injectors checked.
Old 04-24-06, 02:40 PM   #5 (permalink)
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
There is a line between the output(big line) and the wastegate on your truck. This is the sense line for your turbo.
As things get older the boost drops. You can cut that line and tee in a small gauge. afterwards cap the tee and leave it in place. or add a pernament gauge going into a different spot on the main output from the turbo to the intake of the engine.
I cheap gauge at napa and some line fittings might only cost 20 bucks.
to test you basically have someone rev it smoothly while you watch the gauge. Best if you do a pernament gauge mount and drive. Then you know the boost underload rather than static.
If your boost is low, you might have to get a boost controller or a ball valve(grainger valve) to put in the sense line to delay the signal to the wastegate.
I bet you have electronic stuff on those lines too though. SO you have to be upstream of all that junk. You probably have an electronic controlled max setting.
Yah go to the surf forum for more info. I am fishing here.
-91 FJ80, wife's ride
Old 04-24-06, 02:55 PM   #6 (permalink)
crushers's Avatar
my suggestion... crank up the boost...
the start to the above truck here: http://forum.ih8mud.com/70-series-te...uck-build.html
shit all flows down hill and pools around your feet. The object is to
keep shovelling it away. If the shit is gaining you better figure out
how to shovel faster :-) Dave Stedman 03/20/09
(for any of you going through a divorce, thanks Woody) http://forum.ih8mud.com/1650867-post1.html
Wayne in Ontario
www.luxuryimports.ca
Old 04-24-06, 04:14 PM   #7 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Nice advice .. !!!!!!
Also just check your oil .. and where are you .. ? altitude compensator ?
HJ-60 2H-T Intercooled Tencha
Old 04-24-06, 07:10 PM   #8 (permalink)
dieselcruiserhead's Avatar
TLCA# 9439
here is where mine was on my 2H. Not sure if it helps but it might be similar on a 2L...
- Cummins 4BTswaps.com Forums
- Hazard Assembly Dirtbag Adventuring Community
- Diesel Conversion Website
TLCA# 9439 Since 1999, Wasatch Cruisers
'89 Toyota Pickup V6, OME, 33x10.5's
'69 FJ55 Project on locked FZJ80 Frame, Cummins 4BT, NV5600, Dana 300
dieselcruiserhead is offline   Reply With Quote
Old 04-09-08, 07:47 PM   #9 (permalink)
Rookie
I am looking for the fuel mixture screw on a 12h-t. Does anyone have pics. Thanks Jamie
89HJ61 is offline   Reply With Quote
