2L used about 1.5 Litres of Oil in 4 hours or so
On Sunday, I drowned my Hilux for a second time.
Where would the Oil be going, if the Exhaust isn't Blue, and it doesn't smell like Oil is burning? Also, when I removed the Oil Filler Cap, whilst the Engine was running, to fill it with Oil, it looked and smelt like Exhaust coming out. On the one and a half hour drive Home, it was well down on Shetlands, and it Idled at about 890 RPM. Penrite Semi-Synthetic SAE 5W/40 I've put in a new Air Filter and Oil Filter, changed the Oil to Repco API CC SAE 20W/50 and tomorrow I'll get new Glow Plugs, then I'll start it and see how much Oil it uses then.
__________________ 1986 Nuclear Reactor 1985 Toyota LN65R LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO! |
Whe you say "drowned" do you mean submersed it while the engine was running?
Regards __________________ Louis Check out my youtube videos at: www.youtube.com/lshobie Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/ |
#3 | |
You may have bent some expensive parts Mate. Best bring it to a shop at this point. My guess is that the more you drive it the more damage you do. A friend hydraulic'd an 8cyl chev diesel - truck only had 8,000kms on it. Anyway, he fried the turbo, bent 2 rods and other problems - still drove home, was smoking like a bastard though.
Let us know what you find out. __________________ Louis Check out my youtube videos at: www.youtube.com/lshobie Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/ |
#5 | |
There was a thread in the 80 series section about someone losing oil through the gasket at the oil filter. If you've just installed a new oil filter, you might want to check that. Sometimes the gaskets get distorted and don't seal properly, and the oil just pumps out.
Just a thought. |
Check for excess blow-by? Seems you got some abnormal crankcase pressure?
bummer. liked the pics though johnny __________________ 82 BJ60 "Old Blue" plow truck - she's a beauty! Fleet of JDM goodness 97 Yamaha Enduro 55 Case 500 Diesel tractor 73 JD 500C backhoe |
could also be the old "O"ring stuck to the filter housing with the new filter and "O"ring on top hence a possible leak...
seen it in the past... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#9 | |
Diesel for blood
__________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#10 |
I've put in new Glow Plugs and a Fuel Filter. I ran the Engine for about 40 minutes to an hour, and the Oil dropped about 2mm down the Dipstick.
The Engine smoked the whole time, and didn't Idle smoothly, also when comming off WOT the Engine is very slow comming down in revs.
#11 |
Diesel sniffer
Jonathan.
Check the compressions. The 2L is a remarkably forgiving engine. My 2LTE ran OK but noisy when I broke a valve and it holed a piston, idled quite well when I pulled off the road before I switched it off and started first time on the key when I was mad enough to try it. You may have broken the rings on one of the pistons as they are a weak point if you Hydraulic the engine. The oil must either be leaking out or burning - think you would notice the leak so burning is the best guess. If it is a non Turbo then the only places I can think to look are the Pistons or rings, the valves or the head gasket. You are going to need to pull off the head anyway to check. __________________ Cheers Andy 1993 HDJ80 (1HD-T engine) Brooklands Green Metalic. 210K miles. Factory Winch, Old Man Emu Shocks, 17 inch wheels, 265x70x17 Cooper Discoverer ATR http://www.gloucestershire4x4response.co.uk http://www.4x4response.info |
#12 |
Is a 2L-T a bolt in replacement for a 2L, apart from the Exhaust?
#13 |
Can 3L Pistons be fitted onto 2L Rods?
Can a 2L be Bored out enough to accept 3L Pistons? __________________ 1986 Nuclear Reactor 1985 Toyota LN65R LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO! |
#14 | |
Diesel sniffer
2LT will fit straight in, need the front pipe from the exhaust and the fuel pump etc. Don't think you would want to modify the 2L block to fit the 3L pistons - you would need a 3L head anyway. Better to get a complete 3L engine. However a 3L head will fit a 2L block if it is the later type of 2L engine. You can also fit the turbo off a 2LT onto a 3L head, just need the complete assembly including manifolds, pipework etc. Best bet to me would be the 3L route and then get hold of a 2LT Turbo and ancillaries. __________________ Cheers Andy 1993 HDJ80 (1HD-T engine) Brooklands Green Metalic. 210K miles. Factory Winch, Old Man Emu Shocks, 17 inch wheels, 265x70x17 Cooper Discoverer ATR http://www.gloucestershire4x4response.co.uk http://www.4x4response.info |
Mortgage Calculator | Property for sale in Spain | Mobile Phones | Loan | Xbox Mod Chip |
