need a new glow plug indicator thingy - BJ40
hey, doesnt anyone know if you can get one of these somewhere or make one? you know the little coil type thing that goes red when the glow plugs are hot?
mines snapped :( cheers |
Mod in Hibernation
did you try toyota?
I would scrap the coil idea and use an amber light. a couple dollars or so.... but if you really want a coil.. they can be bought from certain tractor/heavy equipment retailers. I have seem mining equipment with these. On scooptrams and underground bucket trucks. So if you start calling around you may have sucess. Personally I would go with an amber light....IMOP open ignition source is not my favorite. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
amber light hey? ive never heard of it. (this is my first diesel)
do i need a special amber light? where do i get one? Thanks again brownbear
Disciple of Dan
I am not sure of the crossover, but Toyota did have a coil type for the BJ42 about a year ago.
__________________ 1981 BJ42, OME, ARB Lockers, AXT Turbo, Warn M12000 1994 FZJ80 ROTW 1997 FZJ80 40th Anniversary being modified Victimized by CDan Court photographer for HRH The Shaman Honi Soit Qui Mal Y Pense |
#5 | |
Mod in Hibernation
to me(correct me guys if I am wrong) the purpose the having a coil for manual glowplugs, is that when you turn on the glow plugs the coil should heat up at the same rate as the glowplugs(same resistance). that way you know by looking at your super hot coil that you glowplugs should also be red and hot too. When Toyota went superglow, you don't have control over the timing of the glowplugs....so no need for a visual reference as to how hot they are. personally, I would just have a 2 buck light in there and count off 15 seconds or soo. unless you like to light a smoke on it.....thats what they do in the mines If you want a coil check with Toyota. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
glow coil vs amber light
If im not mistaken the superglow has a resistance wire in series with the glowplugs that allows the correct voltage to be applied to the glowplugs.. in the old BJ42 system the glowing coil does the same thing.. if im not mistaken, it is an integral part of the glow system and replacing it with an amber might result in accelerated if not immediate failure of the glow plugs due to over voltage / excessive current draw... of course i have been wrong before, but in my 24 volt BJ70 the glow plugs are wired in paralell with a bussbar and are all rated waaaay lower than 24 volts.. (any one know how low?) this means that they all see the same voltage and its not 24 volts... again i could be mistaken, but i will go measure the working voltage and come come back .. fortunately i have never had to service the glow system on the BJ yet..
__________________ I dont want a pickle i just wanna ride my Motor Cycle |
TLCA# Reset to Zero....
yeah, the bj40 system is pretty different from the bj42's. completely manual, hold key backwards for as long as you like, and a push button on the dash for when it runs like shit.
I can barely see that thing glow on mine unless it's dark out anyways, so I usually just end up counting. I wouldn't particularly miss it if it were gone. I was under the impression it was only a visual timer. allowed you to see when they were hot.... cheers, ryan |
well, i'm in the same boat now. mine snapped at the mountain after a day of powder. talk about a bad turn to a perfect day. i jumped my wires and got a bit of glow i think, so she started rough, but did start. tried to do the same thing again next day but no go. they are getting 20 volts and ohm out well so they should work. anyways i want to replace the glow screen too but the dealer wants too much and it's a week away. anyone have one for sale? part#28550.
how about alternate ideas? i'll try the truck shops like brownbear suggested. chris |
You might try a Kubota equipment dealer,we use to have them on some of the equipment with Kubota diesel motors in them at work,also a friend has one on a small Kubota tractor he has,only thing is they were all 12 volt.
Kubota part #15531-65951 or from Isuzu Part# 5-81410-040-0, these might be old numbers but they should cross up to thier new numbers James... __________________ 91 HZJ73 warn electric winch,electric lockers,suspension seats Last edited by Jimmy B; 03-15-06 at 07:19 PM. |
#10 |
for the time being i just joined the two wires that go to the glow plug screen together and it was starting fine...
until this morning :( couldnt get it to start... checked the glow plugs, 3 had infinite resistance and one had 0.03 resistance... so i replaced 3. Still wont go :( I have 12 volts at the bar... any ideas what else i can check? im outa ideas :( |
#11 |
Mod in Hibernation
12volts at the bus bar....3 new plugs. no reason they are not glowing. edic not turning on?
change the other plug too. 0.03 is almost straight to ground. could be the others are not even heating up. Shouldn't there be almost an ohm per plug? to test the theory, disconnect the one old plug, heat up the other three and try to start. it will start on 3 good plugs. also verify the fuse is not blown, incase you do not have power now. __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
#12 |
i was told it should be 0.00 ohms if the plugs are brand new...
if one was not working, would it stop the others from heating up? if i have voltage at the bus bar, that would mean the fuse is ok wouldnt it? ill check anyway edic seems to be working *shrug* thanks again brownbear, hopefully it'll sort itself out.. |
#13 |
one dead glow plug does not affect the other ones...
__________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#14 |
well it started tonight, a little rough but i guess its always done that sometimes...
i have no idea why its starting now and wouldnt before... lots of strange things happen with this car, fingers crossed it keeps starting! |
Bad Credit Mortgages | Nature Photography | Credit Card Consolidation | Loans | Car Loans |
