Old 03-05-06, 07:01 PM   #1
Chang-kuao-lo's Avatar
Location: in the rain replacing the alternator, again...
Question Ever use "Sea Foam"?
Used this stuff for years, a Piper-Cub owner told me about this stuff years ago, swore by it for aircraft engines. Look on the label and see that it is used for injector bench cleaning mixed 50/50 with diesel. Or, one can fill the fuel filter with it and run the engine for a similar effect. Anyone ever try this?
"You spend $3,000 on a pair of night-vision goggles so you can freak out your cat at night, and I'm the one who's baked?"
1971 Pontiac LeMans
1984 YAM. XT600
1982 Toy pickup, 2LT diesel
1983 BJ42
1985 BJ74 PTO winch (lawn ornament, thanks NHTSA )
Chang-kuao-lo is offline   Reply With Quote
Old 03-05-06, 09:15 PM   #2
Dmax's Avatar
have never used it for that purpose. I use it on the drilling rigs. Works great to disperse water in fuel and keep it for gelling up.
01 Chevy Duramax, 6" Superlift, 35" trxus mt's, mbrp 4" dual exaust, bullydog power chip, banks bighead waste gate, and glass works fenders
71 fj40 in pieces in my garage
05 Cadillac XLR
Dmax is offline   Reply With Quote
Old 03-05-06, 09:17 PM   #3
Dmax's Avatar
thats suposed to be keep it from gelling up
05 Cadillac XLR
Old 03-06-06, 06:48 AM   #4
Eric Winkworth's Avatar
There has been a thread on this before, You can use it in your oil before a change too, works really good in two stroke sleds/ quads and bikes. Cleanes the carb and carbon of the top of the piston.
For sure some good stuff.
1986 BJ70, 24v with a 3B
Eric Winkworth is offline   Reply With Quote
Old 03-06-06, 03:06 PM   #5
It isn't hocus pocus stuff at all, with all the carbon build up in diesel and 2 storke type engines sea foam seriosly does work, it has been around for like 50 years.
Old 03-06-06, 04:39 PM   #6
wesintl's Avatar
TLCA# 4180
I've used Seafoam in gassers never in a diesel...
I don't think I need it but i'm curious as to how used and what benefits in diesel.
Injector cleaning?? is that it? I can think of better products for diesel...
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Old 03-07-06, 08:02 PM   #7
No hocus pocus, the guy who recommended this owned a V8 rebuild shop (no grab-ass, six bays, you drive in with your car at 8:00am and pick it up at 5:00pm with a new V8 in it), used it in his Piper-Cub (next to the twin otter, probably the most sought after light aircraft on earth.) Been made since 1942. Can be used in fuel, crankcase oil, or carb/throttle body. It's just that I recently noticed that it says it can be used in injector cleaning machines, or filling the fuel filter. I'll try it and report back. I usually throw a can in the tank once a month, normally I use Lucas, or preferably Howe's, when I can find it. Usually use it on oil changes, when I can remember it. The other thing I used to use in the engine oil was Molyslip-E (also recommended by the same guy). Great stuff, coats all the metal surfaces with molybdenum disulfide, kinda acts like graphite, will only burn at near nuclear-reaction temperatures (not like PTFE, which turns to hard goop at about 180degC). I can't seem to find it down here though.
1971 Pontiac LeMans
1984 YAM. XT600
1983 BJ42
Old 03-08-06, 06:33 AM   #8
diesels produce alot of carbon and soot, which is why they blacken oil quickly. In your fuel it will unclogg injectors and take the carbon off the tops of your pistons. In your oil before a change it will clean carbon and soot deposits out of bad areas and the first time using it if high km motor, your oil actually is chuncky.
I've noticed a difference in how she runs, not more power really just better, oil stays clean a little longer.
I don't think I would put it in synthedic oil though, get amsoil engine flush if you are using synthedic.
JMO
Old 03-08-06, 12:36 PM   #9
It does claim to be compatable with synthetic, lots of fine print on this little can...
1971 Pontiac LeMans
1984 YAM. XT600
1983 BJ42
Old 03-09-06, 10:09 AM   #10
Just going by the the thirty years of engine building experience from the fellow who recommended it . At $4.95 a can, what do I have to lose (other than my $4.95)?
1971 Pontiac LeMans
1984 YAM. XT600
1983 BJ42
Old 03-09-06, 08:40 PM   #11
a guy that has rebuilt engines everday for the last 25 years recommended it too me!
Old 03-09-06, 10:27 PM   #12
it's a wooly worm
Gold Boy's Avatar
Sometimes old school is better than new.....
Just because its not written in some science journal.... Does not mean its not right?
GB
BJ74 & TUFT & U-AFPT
Gold Boy is offline   Reply With Quote
Old 03-09-06, 10:37 PM   #13
crushers's Avatar
here is the way i view stuff, take it for what it is worth...
will it do damage to the engine? probably not.
will it do any good? who knows till you try it. if it works, great. if not then you wasted $5, big deal.
i can see both sides of the issue, limited documentation but used by various "old boys"...
me, i love old school thought and practice...
cheers
Wayne in Ontario
Old 03-13-06, 06:47 PM   #14
it seems to eat the crap off parts you clean in it pretty quick. Fads come and go but the stuff that stays the same for 40 years stood the test of time for a reason. I notice a remarkable difference running on Howe's. "If it doesn't start, we pay the tow." I wonder if anyone actually took them up on that. And it smells like Murphy's oil soap
1971 Pontiac LeMans
1984 YAM. XT600
1983 BJ42
Old 03-14-06, 07:21 PM   #15
TLCA# 12413
Gotta case in the truck, we use it at work in all our big trucks, and backhoes, track hoes, track hoes dozers. If we could buy it by the 55 gallon drun we would.
Lex
Some ladies love me...... and some ladies love each other
DaGrvedigr is offline   Reply With Quote
Old 03-14-06, 08:00 PM   #16
it's a wooly worm
Gold Boy's Avatar
Can we confirm on which way to use this "sea foam", I wan't to give it a go on my 13bt....
GB
Books | Cow Farming | Remortgages | PayPal Hosting | Car Loans
