Old 01-28-06, 06:51 PM   #1 (permalink)
Intercooled 12-ht
Thought someone would be interested in this.
To day I added a water-cooled intercooler to my 12-ht engine.
The cooler replaces the tube from the turbine to the intake manifold. A water cooler, water reservoir and a water pump is located in front of the radiator.
I havent had a chance to test the performance of the car after the cooler so I can´t tell if it is a much diffrent.
The first pic shows the water cooler, the pump and the reservoir.
The second shows the cooler, hoses and tubes I made.
The third shows the cooler in place.
haffi is offline   Reply With Quote
Old 01-28-06, 06:55 PM   #2 (permalink)
more pics
The fourth pic shows the cooler in place from a diffrent view.
And the fifth shows pipes from the turbine to the cooler.
Haffi
Old 01-28-06, 07:33 PM   #3 (permalink)
Stone's Avatar
Interesting stuff, Haffi...thanks for sharing. I think I'm going to link this to our FAQ section also.
One thing that I notice right away is how small the intercooler unit is. Especially considering that this is supposed to be a water-air cooler...I would have imagined that the size should have been a bit bigger. Of course I'm not an expert in turbos or intercooler in any way, but I did take my 13B-T to a local ricer shop and they indicated a water-air cooler that appeared significantly larger than the one you have pictured. And considering that your 12H-T has a larger displacement than mine...I'm wondering if you are even getting efficient cooling happening, or not?
Do you have any way of taking temps pre and post your intercooler? And do you have pics of what that cooling unit looks like inside? Maybe some dimensions? Thanks, and good luck!
Stone is offline   Reply With Quote
Old 01-28-06, 10:31 PM   #4 (permalink)
The Dude's Avatar
TLCA# 8113
I looked into this but the guys at the local speed shop talk me out of it.
To much heat wash. The guys at the track get awsome results filling the resoivoir with ice cold water just before a run.
very cool
let us know if you notice a difference
Brad T
88 HJ61 "Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs...
78 BJ 40/42/60
The Dude is offline   Reply With Quote
Old 01-29-06, 03:21 AM   #5 (permalink)
Stand and deliver
roscoFJ73's Avatar
To much heat wash.
Just curious as to what you mean by" heat wash"
Does this mean it is too efficient and draws too much heat away?
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Holden Commodore V6
Honda XR650L
roscoFJ73 is online now   Reply With Quote
Old 01-29-06, 06:49 AM   #6 (permalink)
Stone's Avatar
The other way around. Because the intercooler sits on top of the engine, heat from the engine and exhaust manifold rises up and heat transfers to the intercooler, negating some of its effects.
The ricer shop that I went to recommended putting a small water-air cooler in front of my airbox in order to avoid this problem. I was originally planning a similar setup on top of my engine, like a Subaru...but they didn't think that would be worth the effort.
Old 01-29-06, 08:51 AM   #7 (permalink)
Well I have been driving for about 2 hours today, just in town no higway driving. When i stopped I opened the hood an I touched the pipes on both sides of the cooler. I felt a diffrence I belive. Not much but a little. I might try to measure the temp somehow in the nex days.
The water in the reservour was not cold, it was warm, It felt quite comfortable sticking my finger into it
Maybe a hoodscoop of some kind would be a good idea to flush the heat from the engine down with colder air?
I might also try to isolate the cooler from the engine? Perhaps with a thin metal plate below it? I bought that stuff used for about 1/4 of the prize of it so I belive this worth the effort for me.
Haffi
Old 01-29-06, 10:12 AM   #8 (permalink)
Stone's Avatar
Haffi:
I think the hoodscoop and heat shield between the intercooler and engine would be a great idea. It might also cool your turbo down a little while you're driving. Sheldon has done a ceramic coating on his exhaust manifold and turbo housing...I hear this is a good way of keeping under hood temps lower. Just some ideas.
It's always worth the effort, and you deserve credit for in effect pioneering this type of modification for us. So I'm sure many out there who have a 12H-T would like to toast a your way.
Old 01-30-06, 10:59 AM   #9 (permalink)
Turbo Diesel Lover
Tapage's Avatar
The intercooler setup for all kids of tubro system are measured in CFM . ? for example .. just to know the real and specific performance for a intercooler unit ..
HJ-60 2H-T Intercooled Tencha
Old 01-31-06, 07:57 PM   #10 (permalink)
bigbrowndog's Avatar
This is the set up on a Nissan Patrol 3 liter diesel Ute , similar to what you are attempting. Perhaps not ideal compared to an intercooler out front but it works very well on the Patrol perhaps someone should tell Nissan.LOL. The bonnet also has a small air scoop. Believe me these units can really haul.
bigbrowndog is offline   Reply With Quote
Old 01-31-06, 08:16 PM   #11 (permalink)
This is an intercooler stuck out front of a 60 series wagon. The motor is a 2H.
Old 01-31-06, 11:27 PM   #12 (permalink)
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
Could it be Stone that this shop has no clue as to what the airflow would be in your diesel and are only thinking in Gasser terms of airflow. Where as a 3.4 gasser would be huge airflow. ???
Or do they know how to work out diesels for airflow.???
I imagine ricer shops would have no clue to diesel stuff.
-91 FJ80, wife's ride
Old 01-31-06, 11:56 PM   #13 (permalink)
Stone's Avatar
Hi Darryl:
The CFM would basically be calculated from engine displacement and RPM, right? I think they have an idea as to how much roughly my engine would require. This ricer shop is near Piers Diesel Research...I'd figure those guys talk to each other once in a while.
Old 02-01-06, 10:58 AM   #14 (permalink)
zander's Avatar
I had thought about a hood scoop for an intercooler as well. Actually I was wondering about it for moving the AC rad so as to improve the effeciency of the engine radiator especially on really hot days and steep hills. (pretty much when you want the AC on right?)
The Nissan patrol pic is good to see this in action. Any other experience with hood scoops out there? Good hood scoop sources?
Zander
87 HJ-60 running on biodiesel, 12H-T, new frame, and "extreme" automatic transmission. OME supension, Safari Snorkel, Custom aluminum bumper, AutoHome rooftop camper, pusher fan and hood vents for operating in the hot desert.
zander is offline   Reply With Quote
Old 02-01-06, 11:07 AM   #15 (permalink)
Turbo Diesel Lover
Tapage's Avatar
I see good ones in summit .. and with good prices.
Old 02-01-06, 11:21 AM   #16 (permalink)
It´s working. The last few days I have noticed a diffrence. When driving up a hill where I had to shift down to 2´nd gear. I can now drive in 3rd gear without a problem The cruiser also feels a little quicker... But the best part is the extra torque.
I have also been looking at hood scoops. My local used part dealer is looking for scoop from a Izuzu Trooer he belives he has somwhere in the back. I migth get it tomorrow. The Trooper has original intercooler placed on top of the engine (similar to the Nissan Patrol) but a much bigger scoop. And it looks like it will fit the cruiser properly. I will post a pic if it fits.
Old 02-01-06, 11:51 AM   #17 (permalink)
sandcruiser's Avatar
I'll see if I can grab a shot of the 4runner intercooler-- a lot like the Nissan above, I think.
Pretty cool idea. I'm curious to know how hot the water gets? Seems like you could flow veggie oil through the works and get preheat on the oil while cooling the air.... maybe.
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Geolander MT's 33x12.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns.
ask me about Costa Rican Realty
sandcruiser is offline   Reply With Quote
Old 02-01-06, 11:52 AM   #18 (permalink)
nickw's Avatar
How much did all this end up costing you?
1988 BJ74 / Lots of goodies - Sold
1990 HDJ81 / Fully outfitted loaded beautiful truck - Rolled
1985 BJ60 / Beautiful Stock truck - Stolen
nickw is offline   Reply With Quote
Old 02-01-06, 12:50 PM   #19 (permalink)
I bought the air cooler, the water cooler, the reservoir, the pump and some silicone hoses used for about 158 usd. Then i bought some pipes, hose clamps, bolts and some more hoses for maybe 80 usd, so everything for about 240 usd.
Old 02-01-06, 02:10 PM   #20 (permalink)
This is how the air scoop looks on the Nissan. All neat and functional. cheers
Old 02-01-06, 02:18 PM   #21 (permalink)
We often get temperatures in Oz that are well into the 40 degrees celcius, the air is used all the time in the north with no problems so long as the cooling system is ok. Weather forcast for today is is mid 30s with 90% humidity, will give you an idea. cheers
Old 02-01-06, 03:25 PM   #22 (permalink)
Turbo Diesel Lover
Tapage's Avatar
very very good .. !!! so cheap.
Old 02-17-06, 10:38 AM   #23 (permalink)
Hoodscoop
Added a hoodscoop. Bought a universal fiberglass scoop in a local ricer shop. Looks kinda cool to me...
Old 02-17-06, 01:53 PM   #24 (permalink)
-uhuru-'s Avatar
it looks stock! good job!
did you make those flares?
-uhuru-
'99 HDJ105 i-Phantom
-uhuru- is offline   Reply With Quote
Old 02-17-06, 02:52 PM   #25 (permalink)
The flares
No I bought them from a fiberglass-shop, but had to work the edges of them to make´m fit the fenders perfectly.
Old 02-17-06, 08:30 PM   #26 (permalink)
That air scoop looks great. Would suit the HJ75 also,LOL. Will have to look into one. Was wondering what is all that crap on your motor or is it the picture? Maybe sprayed on insulation to keep it warm.
Old 02-17-06, 09:07 PM   #27 (permalink)
Radd Cruisers's Avatar
Denco doese a simular kit, simple install and good gains.
The kit is a self contained unit with radiator and the radiator is placed on top of the engine, very compact.
I will have to try out thier water to air kits one day.
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
