Old 12-23-05, 08:54 PM   #1 (permalink)
ivanhoe's Avatar
TLCA# 15543
Question installing block heater in 85bj60 ?
merry x-mas!
i've purchased a 1500w inline self propelled block heater with 5/8" inlet & outlet. it has to be installed at the lowest part of the engine block and the return line back to the top of the engine block. i'm not to sure exactly where to install it and was wondering if anyone is using one of these. i need to know where it worked best for you.
tia,
ivanhoe
ivanhoe is offline   Reply With Quote
Old 12-23-05, 11:07 PM   #2 (permalink)
crushers's Avatar
i have tried those in the past and wasn't ipressed so now i use the lower rad hose heaters...
get an adapter for hte block drain right above the starter and then go from there to the inlet for hte heater core...
HTHS
cheers
the start to the above truck here: http://forum.ih8mud.com/70-series-te...uck-build.html
shit all flows down hill and pools around your feet. The object is to
keep shovelling it away. If the shit is gaining you better figure out
how to shovel faster :-) Dave Stedman 03/20/09
(for any of you going through a divorce, thanks Woody) http://forum.ih8mud.com/1650867-post1.html
Wayne in Ontario
www.luxuryimports.ca
Old 12-24-05, 12:08 AM   #3 (permalink)
Stone's Avatar
HTHS
cheers
Hi Wayne:
I just bought a lower rad hose heater from Crappy Tire...was on sale for $32 CAD. I bought the 1.5" diameter one from measuring a hose that was lying around in the shop...is this the right size for the 13B-T? Thanks!
Stone
Stone is offline   Reply With Quote
Old 12-24-05, 06:55 AM   #4 (permalink)
ivanhoe's Avatar
TLCA# 15543
HTHS
cheers
hi wayne,
i still have my lower rad hose heater and it stop working. it looks like it's the sensor on the cord that prevents it from coming on(i know, cheap fix). i taught i try the tank type heater to eliminate using the two heaters that i'm using at the moment and keep them as spares. it's a little more complicated than i anticipated. do you know the block drain size off hand? there's one in the kit, 1/4" NPT.
thx,
ivanhoe
Old 12-24-05, 09:03 AM   #5 (permalink)
Supporting Vendor
Greg_B's Avatar
TLCA# 7091
Originally Posted by ivanhoe
merry x-mas!
tia,
ivanhoe
I had a 1500W one in my BJ42. It worked well from what I recall, even the few times I had it in Calgary. Trick is to ensure it is low enough to get a good convection current going. I had it mounted to the frame, so the feed had to head downhill a little. Will look later to see where it was ties in.
All that said, the lower rad hose will be my next one...easier install, no tank to mount, and no hoses running around.
hth's
gb
Old 12-24-05, 09:05 AM   #6 (permalink)
Supporting Vendor
Greg_B's Avatar
TLCA# 7091
Originally Posted by Stone
Hi Wayne:
Stone
You gonna be around the shop at all? We have scads of used 3/13BT lower hoses in the hose box. You can scoop one and cut it up, where you are going to mount the heater. Measure and buy to suit!
gb
Old 12-24-05, 06:25 PM   #7 (permalink)
ivanhoe's Avatar
TLCA# 15543
hth's
gb
by jolly, we are back in business! i'm gonna return the 1500w heater 'cause i got the lower rad hose one working again. a bad connection was preventing having 120vac juicing it! now for the next option, right now i have a 1 3/8" 300 watt. if i go to a 1½" i'll have 600 watts! i'm sure the 1½" should fit
thx everyone and have a safe holiday,
ivanhoe
Old 12-29-05, 08:18 PM   #8 (permalink)
Stone's Avatar
I just finished installing the lower rad hose engine heater in my BJ74 tonight. It turned out to be an easy install that ended very clean looking. The heater unit fit perfectly just under the spring clip that holds the lower rad hose against the fan shroud. This area also has the required 3" straight section and is angled upwards towards the engine block.
I'm heading to Kelowna next week for a few days. It's fairly warm there right now, but if it cools off siginificantly while I'm there and I get to use the engine heater, I'll let you guys know how it works.
The brand of my heater is Zerostart, a Canadian made product retailed at places like Canadian Tire. Mine is the 1.5" 600W model, and it regularly retails at Canadian Tire for around $39.99. I bought mine on sale last week for $32.
Old 01-16-06, 08:22 PM   #9 (permalink)
Stone's Avatar
Didn't get a chance to try out the new lower rad hose heater...temps were downright balmy in Kelowna while we were there. No leaks though.
