What I Found In A Coolant Hose
That was out of the upper hose that goes from the thermostat housing to the radiator. The hose was "crunchy" when I squeezed it so I pulled it off and that's what I managed to remove. The hose itself seems to be in good shape except for the rust build-up. When I check the other hoses most have the same "crunchy" feeling. Obviously the guy who owned this rig in Japan rarely (if ever) changed the coolant. On the outside the radiator seems to be in good shape and anything I fill it with will drain right away and there are no leaks. I've flushed the system with some cleaner and plan to flush it a few more times. Does anyone know if someone sells a kit that replaces every rubber coolant hose? I've seen the kit that 4WheelAuto sells but that's only 3 of the hoses I'd need. __________________ '89 BJ74 '85 BJ70 - Sold (Frame rotted away )
Think it might pay to also have a look at your welsh plugs also[ think you call them frost plugs if I remember correctly.At least knock some out and check them and stick a hose in there also for a good wash out.They can rust out from the inside and you will loose your coolant quickly.
looks like he just used water as a coolant for years. I suspect your rad would be full of that stuff too, should get it checked and flushed.
Regards __________________ Louis Check out my youtube videos at: www.youtube.com/lshobie Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/ |
i ran into a LJ71 that was simular. it had hot temps and when i pulled the rad the same crap came pouring out.
cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
I thought you need a reall deep flush to your cooling system .. !
i ended up parting out the vehicle...
i did not want to sell that to a customer... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
Yeah I'm flushing the crap out of the system and also replacing the thermostat while I'm at it. I did a search in regards to installing a aftermarket temp gauge and the port that people are hooking into on the thermostat housing, in the pictures below, which one is it?
And is there any reason most of you guys are going with mechanical gauges instead of electrical? __________________ '89 BJ74 '85 BJ70 - Sold (Frame rotted away )
Present
Sorry for the dumb question but where do think the rust build up was coming from? Radiator?
#9 | |
Factory Toyota gauge is not very good and often does not give the detailed movement based on what is going on with the temp. mechanic is quick very accurate easy to install - cheap insurance policy
#10 | |
Michael |
#11 | |
Actually it's iron, not steel. Most (99.9%) of engine blocks are either iron or aluminum. Just a technical point. __________________ MOOSE SOLD HER - SOMEDAY SOON JDM's...THEY SAVED THE BEST FOR THEMSELVES!! |
#12 | |
#13 |
northerner
so maybe it never gets cold in japan and they neglect their antifreeze.
greddy sells bungs with a temp sender mount that you can splice into any rad hose. __________________ 93 fzj80 66 fj40L m101cdn trailer 91 LS400 sedancruiser 64, 2x65 honda ct 200 2 x67, 2x68, 3x1969, 1972, 1975 Honda ct90 "Diplomacy is the art of having someone else impose your will on you" Lester Pearson "I have the conch" Piggy |
Loans | Credit Cards | Car Finance | Loans | Mortgages |
