Old 09-01-05, 09:11 PM   #1
TLCA# 13446
Exhaust and tire size for my BJ42
I need to replace my exhaust system and was wondering if there is any advantage to going to a larger size pipe to help the engine breath better. My thinking is since larger pipes help the Ford, Dodge pickups, maybe it would help my Cruiser.
I am also thinking of some new tires and was wondering if 35x11.5 MTR's are too big for the 3B engine. I have a 4" lift, so clearance is not an issue.
Thanks for your advice!
This is not my beautiful wife.........
Cruiserhead - hopelessly addicted
74 FJ40, 81 BJ42, 86 FJ60
Mike G. is offline   Reply With Quote
Old 09-01-05, 09:57 PM   #2
She idles just fine
dieseldog's Avatar
TLCA# 14999
Given stock ring gearing, the 35's are probably too tall for your 3B. I run 33's on my 3B-equipped cruisers and I feel it's just about right. If you turbocharge, change out your ring gear, and add a lift of at least 2 inches, you can probably run the 35's. Do you have the 4-speed or the 5-speed?
Sparkplugs are Irrelevant.
1976 HJ-45; 1984 BJ-42; 1988 BJ-73; & 1993 KZJ-70
Originally Posted by Hugh Heifer View Post
I have been searching for the right one all day. I like the feel of the small one Yooper has...but your long one was fun to play with . . .
Originally Posted by stinkyfj60 View Post
I have intense impulse control over all situations....
Just sayin'.
Originally Posted by Jman View Post
. . . . I think I am having an orgasm in my mouth.
In Search of More Gubs . . .
dieseldog is offline   Reply With Quote
Old 09-01-05, 11:20 PM   #3
TLCA# 13446
I've got the four speed with the split case transfer. I was wondering about upgrading to the 5-speed. I have one in my 60 and love it. Is the install into the BJ a simple swap, or is more involved?
Also, what ring gear size would you recommend if I went with 35's?
Old 09-02-05, 05:37 AM   #4
crushers's Avatar
with the H55F instlled you will be able to turn the 35s easier but 5th gear is useless. i ran a BJ42 for years with 35s, it is a slow rig but rocks off road. add a turbo and the whole truck transforms into a much mor epleasent driving experience.
the H55F is a bolt up but you need to modify the driveshafts the front is 3" longer (i beleive, measure beor you modify) and the rear ends u being a 2" pipe when using a CV joint driveshaft (which i recommend) from a 60 series.
you will need to cut the shifter hole back 3" so the tower will fit through.
if you use the 4 speed gears make sure you get the 5 speed t;case and just swap most of the guts over. you need the 5th gear oiler that is in the 5 spd case...
cheers
Wayne in Ontario
Old 09-02-05, 10:29 AM   #5
Diescipel's Avatar
TLCA# 14854
There isn't a difference in the frames in the 83-84 BJ42s with the H55F? I thought the curly-tube cross member on the frame was moved back slightly to accomodate the longer 5 speed tranny?
I'm sure I'm wrong--just thought I heard this somewhere, sometime.
I will 2nd what folks are saying on tire size--I have 33x9.5s on mine and it seems just right though w/o turbo I am frequently downshifting into 4th on hills. It may be that 33s are a bit big for the higher 1st ratio in the H42? They are perfect down low in the gearing on the H55F.
B
Brendan
1983 BJ42 bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
Diescipel is offline   Reply With Quote
Old 09-02-05, 10:37 AM   #6
crushers's Avatar
i do beleive you are right. the conversion leaves about 1" between the back of the t/case and the cross member.
you need to stick the tranny and t/case on the engine then lift it up to put the mount in place...
Wayne in Ontario
Old 09-02-05, 11:05 AM   #7
Diescipel's Avatar
TLCA# 14854
Ok so you don't have to move the X member? Roger.
B
Brendan
Old 09-02-05, 11:31 AM   #8
Greg_B's Avatar
TLCA# 7091
Correct.
However, I know some people have cut the tube right at the frame, attached a plate to each side, and now bolt it in and out, when they have to do work to the tranny.
I ran 255/85/R16's (33x10) for years on my H42 BJ42. Starting on a steep grade in 1st H can be a pain. For regular driving around (city and highway), it seems right. I can see 1st with an H42 being a real PITA with 35's.
gb
Old 09-02-05, 05:24 PM   #9
crushers's Avatar
yes, i have seen this done but for the home do-it-yourselfer, a straight bolt up can be done...
Wayne in Ontario
Old 09-02-05, 06:02 PM   #10
Tapage's Avatar
Originally Posted by Greg_B
Correct.
gb
but 4.11 R&P .. ?
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 09-02-05, 06:58 PM   #11
Greg_B's Avatar
TLCA# 7091
Originally Posted by Tapage
but 4.11 R&P .. ?
Yes, sorry. Stock 4:11 in the BJ42.
gb
Old 09-03-05, 09:51 AM   #12
TLCA# 13446
OK, sounds like I should stick with 33's for now. The 5 speed man come sometime in the future. Any thoughts about increasing the exhaust pipe size?
Old 09-03-05, 10:14 AM   #13
Diescipel's Avatar
TLCA# 14854
LOL here we are talking about tranny swaps and you want to know about exhaust size...
I assume you are into your BJ42 for the long haul like me, and I assume you have not turbo'd it. I'm interested in a turbo in the (distant) future, so if I were you I would build your new exhaust for that possibility. Larger exhaust won't help you much now without turbo, but it will in the future with it, if you are considering it. With this in mind, I would go with a 2.5 inch galvy exhaust system and a very free flowing muffler (which you can remove easily when the turbo comes). That's what I would do.
My .02
B
Brendan
Old 09-03-05, 10:22 AM   #14
4.56 would be enough?
Should a turbo'ed 3B @ 0,8bar, intercooled with stock 4speed gearbox and 4.56 R&P would be enough for pushing 35's, or should i go with higher R&P ratio? for now i have the stock 4.11 with the 35's but it seems it's not a good option.
BJ40 3B is offline   Reply With Quote
Old 09-03-05, 12:06 PM   #15
Greg_B's Avatar
TLCA# 7091
Originally Posted by NorCalCruzr
LOL here we are talking about tranny swaps and you want to know about exhaust size...B
lol...yes: The main question. I did exactly as you mentioned, and built my exhaust for the future possibility of a turbbo. 2.5" with a free flowing muffler. I needed a new exhaust anyway.
Yes, I believe there is an advantage even without a turbo. The better you can exhaust the hot gases...well, the better! Are you going to be making full use of it? Probably not till you have a turbo, but if you have to do the exhaust anyway...do it.
gb
Old 09-05-05, 08:28 PM   #16
crushers's Avatar
yep, that should turn 35s quite nicely...
cheers
Wayne in Ontario
Old 09-06-05, 04:32 PM   #17
Tapage's Avatar
For a good fuel economy 4.11 for good power 4.56 ( not much top speed )
Old 09-15-05, 09:03 PM   #18
You'll get your speed once you take the overall tire diameter into consideration in the final output ratio of your driveline, but will you have the power to get the tach up. Start saving for the AXT now and you won't regret it.
blownbj is offline   Reply With Quote
Old 09-15-05, 10:32 PM   #19
crushers's Avatar
AXT makes a shitty kit for the 2H, for that kind of money you would think they could design a clean install...
Wayne in Ontario
Old 09-16-05, 11:41 AM   #20
Tapage's Avatar
Well I never seen the AXT 2H turbo Kit .. but anycase the second part of the sentence is right .. 3000 USD not a joke ..
Old 09-16-05, 12:01 PM   #21
crushers's Avatar
i have seen a total of 2 and both were very poorly designed. for $3000 USD i would expect to do NO mods and have the bugger bolt right up...
Wayne in Ontario
Old 09-16-05, 12:34 PM   #22
Tapage's Avatar
In the AXT instalation instruction ( that I can see through a web cam ) appears all easy and bolt on .. there are interesting thing, if all setup is more complicated then that.
Old 09-19-05, 12:21 PM   #23
tlcruiserman's Avatar
TLCA# 7932
I am running 4.88 gear with my BJ42 with AXT turbo and 3B with 35" boots. I have found that it to be too low geared for wheeling the torque does not line up with the H55F tranny. I am going to go back to 4.11 gears worked better. However if you have the H42 I would think the 4.56's would be ideal.
cheers,
Michael
tlcruiserman is offline   Reply With Quote
Old 09-19-05, 12:22 PM   #24
TLCA# 7932
I have yet to see or do a AXT turbo kit that does not require a few mods. both on 40's and 70's (all 3B engines).
cheers,
Michael
Old 09-19-05, 05:25 PM   #25
Tapage's Avatar
cheers,
Michael
your setup 35" + 4.88 + 3B + Turbo = 37" or 38" easy .. with 4.56 and 35" you have the best powerfull setup .. and with 4.11 best milleage.
