Old 09-01-05, 08:01 PM   #1
Mainer7's Avatar
Tiny-Tach installed, good so far
Just hooked up a "tiny-tach" on my 13bt.
Installed easily/quickly and no calibration needed.
warm idle is about 655+/-
pics are of display and transducer mounted on metal fuel line.
This thing was like 65 USD
I got the 1/4" "PN: DTT-1/4" size, it fits well but could be a hair larger. But a week so far and not an issue.
here's the site ... http://www.tinytach.com/tinytach/diesel.php
'78 FJ40 13BT/H55F
Saginaw PS 4" Skyjacker - Old Man Emu shocks
33x10.50 Super Swampers - stock wheels
'91 yota pickup-22re, rust flakes
Mainer7 is offline   Reply With Quote
Old 09-02-05, 10:38 AM   #2
I read the site but I am assuming it attaches to the #1 injector line? it must get a pulse signal from the line? Very easy to install!
It says it updates every second? Does it have a noticeable lag time when revving?
no cruiser right now
chet is offline   Reply With Quote
Old 09-02-05, 11:01 AM   #3
Diescipel's Avatar
TLCA# 14854
Now I found something I can put in the spot where the factory digital clock was supposed to go!
B
Brendan
1983 BJ42 bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
Diescipel is offline   Reply With Quote
Old 09-03-05, 08:14 AM   #4
Mainer7's Avatar
chet, the manual does not specify a certain line to use. It just must be unpainted metal and a straight section.
Usually while revving, there is no lag. Occasionally coming to a stop, it will switch to the hour heter display for a second, then go back to tach. At warm idle, it does fluctuate between 648-660 usually closest to 655. Not sure if that is the tach or the rpms doing the fluctuating. Is that a normal range for a 13bt?
Is the fluctuation a bad thing?
One "drawback" is that you cannot see it at night. No illumination of the display, but I don't care. Just installed it so I would know how it's running compared to specs. I've not changed any of the stock settings for fuel or boost.
'78 FJ40 13BT/H55F
Loans | Personal Loans | coupon-coupon.com | Free Ringtones | Credit Cards
