Not a very strong swimmer
1978 BJ40/42 - Buying one from Canada, anything to look for?
First time in the international section, but figured this would be the place for this question(s).
A young man that used to work for me who is currently a pilot flying Chinnook helicopters in Iraq emailed me a couple days ago. He is looking for a project cruiser to work on when he gets back around the 1st of the year. He was wondering if I knew of any? Of course I told him of the typical ebay stuff, plenty of that around. I also mentioned a 1978 Diesel BJ40/42 (FJ, not even sure what it is?) that I knew about across the border in Canada. I've known for a while the guy who wanted to sell it, but I've already got 2 -40's and another project in the pipeline so never really inquired about it? So, I called the guy tonight, still got it, he's wants $800 US. Says it was rolled many years ago, no top or doors. Still has the roll bar and jump seats, he said all that was straight. He said it starts and seems to run fine, shifts, 4wd works, goes down the road, etc.... Body he said, rusty as hell, personally he thought the body is toast. Anway, for $800 I'm pretty much expecting junk anyway. I guess my question to you guys who know this stuff: Anything I should be looking for? I guess mainly pertaining to the Diesel. I think I know a lot about FJ40's with the 2F, but I've never seen a 40 with a Diesel in it? Anything that should jump out at me that I should be looking for? Like I said, not expecting much for $800, but I don't want to take this thing home and have an $800 useless pile of iron in my yard waiting for this guy when he gets home from Iraq. Any comments sure appreciated, Thanks, Matt
__________________ Wanted to buy: FJ45LV interior door handles and door jam stops. If you have any or know of any, please PM me. Thanks, Matt Last edited by buckroseau; 08-24-05 at 12:06 AM. |
if that one does not work out for you i have a good friend that has a rusty but great running BJ40 for sale for $2000 CND.
do a coolant pressure test, these are notorious for coolant leaks where the head cracks between the valves do a compression test, a 3B can be an expesive engine to rebuild properly check the frame before and above the rear solid spring mounts espec where it goes close to the muffler if you need a body check with Mike Gozzard for a fiberglass unit, much nicer than aluminum and won't rust like steel check for vacumm pump, this is a very expensive fix since you will need to replace botht eh alternator and the pump itself that is all i can think of right now... HTH cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today |
First look hard at the frame. A lot of cruisers up there have really severe rust problems and the frame is not immune. Some in ebay have been pictured with holes easily large enough to put a fist through right in the frame rails! Look at and behind the spring hangers first.
As to the engines - there are a lot of people who can speak to that better than I can as I've only just aquired one of them. Wayne, known by "crushers" in here can be particularly helpful to you if you happen to be lucky enough to catch him in a very rare civil mood . The BJ40 and BJ42 will have either a 'B', a '2B', or a '3B' depending on year model. They're a family of four cylinder engines mostly made by Hino, a subsidiary of Toyota. Generally they can last a very long time but watch out for signs of having been overheated as that, along with running low on oil, is likely the biggest killer for them. They're solid lifter mechanical injected engines so expect a nice bit of racket that isn't necessarily harmful.There's much more, but I think a lot of people would be happy to buy that truck at $800. for the driveline alone - engine, trans, and that. The vehicle you mentioned (1978 BJ40) is 25 or more years old it's an easy import as it would be exempt from EPA and DOT requirements. Newer than that can be problematic. __________________ Specialization is for insects '77 BJ40 FST;'77 FJ40; '65 FJ40; Last edited by honk; 08-24-05 at 07:29 AM. |
Why, there's Wayne, in person! La!
__________________ Specialization is for insects '77 BJ40 FST;'77 FJ40; '65 FJ40; |
good morning,
you are right, if the engine has not been overheated or too many missed oil changes then the B series engines is about as tough an engine as you can find. i guess the reaso i keep bashing them is to let everyone know they are not bullet proof and you should know the seller before you buy... cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today |
#6 | |
Yes, there IS a misconception on the part of many people in the US that diesels "last forever". I think that you're right to do as you do in order to both protect yourself and to try to bring people to realize that ALL mechanical devices, diesel or otherwise, do wear, breakdown, and otherwise fail to satisfy. I personally don't view diesels as a class of things to be any better than gasoline engines by nature. In both spheres are examples of incredible longevity as well as ones of horrific and early demise. BTW, several owners of diesel trucks down here, when faced with a failed vacuum pump system, simply convert to an aftermarket electrical one and drive on. Sucking is sucking, eh? __________________ Specialization is for insects '77 BJ40 FST;'77 FJ40; '65 FJ40; |
I guess I don't know the seller that well, more or less stumbled across it because mutal people knew I was into cruisers and they knew this guy had one. He's an older farmer/logger just north of the border. After talking to him he seems like a straight shooter.
I knew about the 25 year and older exempt thing, I had called the border and asked. I actually know quite a few of the border guys here, US and Canada, I only live 9 miles from it. Another question I was planning on calling and asking the border guys today, but maybe you guys know. No title, need one to get across or can a guy whip up a quick bill of sale as parts? Not to concerned about the title, might try to obtain one, but I have a 79 FJ40 clean title I told him he could have if it was impossible to get one. The Diesel thing just seems cool................ Thanks, Matt __________________ Wanted to buy: FJ45LV interior door handles and door jam stops. If you have any or know of any, please PM me. Thanks, Matt |
A bill of sale as parts will work but depending on the particular crossing people what makes it parts and not a whole can vary. I've heard of people being denied if the whole vehicle is present, dissassembled or not. Others apparently have come through with cut in half frames. As far as I know the exemption should apply regardless the form, but a whole vehicle will still need a showing of it's origin. That means a title from oone of the Canadian provinces.
#9 | |
#10 | |
I did how ever since my last post call the DMV and the border patrol 9 miles north of me. Border patrol said they didn't need a title or registration card, just a bill of sale whipped up by both parties with a price would be fine. My local Minnesota DMV said to swing by and pick up a duplicate title form. Have the guy sign it when I pick it up, the rest I can fill out. She said, not a big deal, can obtain a new Minnesota title. Matt __________________ Wanted to buy: FJ45LV interior door handles and door jam stops. If you have any or know of any, please PM me. Thanks, Matt |
#11 |
that sounds too easy...
congrates on having a senseable guard and DMV person... i have heard a few horror stories over the years... cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today |
#12 |
TLCA# 16387
I've been told different at the border. They told me if there is a VIN number you need a title, period, end of story. I'd check really careful. The last thing you want, even worse than a rusty pile of junk in your yard, is a rusty pile of junk at the border and you in jail for importing "stolen cars". That's the reason for the title requirement and the three business day wait. They use that time allegedly to check if the vehicle is stolen and some places presume it's stolen if you can't produce title!
__________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
#13 | |
Yea that's what I thought? I work kinda in a highly visable public retail position locally and I know the people I'm talking to, gotten to know them over the years, so that probably helps? I'm expecting a POS. Assuming everything goes as planned hopefully I can post some pics Saturday night Matt __________________ Wanted to buy: FJ45LV interior door handles and door jam stops. If you have any or know of any, please PM me. Thanks, Matt |
#14 | |
When I spoke to the border guy this morning he told me Canadian vehicles have a registration card, not a title. I'm trying to argue, just repeating what he said. He just said it wasn't required to bring this vehicle across. Matt __________________ Wanted to buy: FJ45LV interior door handles and door jam stops. If you have any or know of any, please PM me. Thanks, Matt |
#15 |
Location: toolin' around Iraq in my Helo somewhere.....
so here i am....
#16 |
concern: diesel sounds cool because its different but is it going to be a bust?
diesel (B which from what i found produces 80hp@3600rpm and 141ftlb@2200rpm) vs. gas (2F 135hp@3600rpm 210ftlb@1800 rpm) is a guy going to be disappointed with that kind of perfomance? |
#17 | |
I don't think he's buying it to drag trailers around the US or anything like that, so big performance #'s aren't a huge issue. I think his main reason(s) for buying this particular cruiser is because the fact that it is a Diesel. Sometimes it's fun to be different, we don't have those cool engines in the states I think he is honestly looking for a project and he likes the FJ40's. I know he bought an older heep a few years ago, but I think he finally is seeing the light He contacted me because I have a little back ground in brining a few 40's back from the dead. I'm going to be helping him on the initial stages of the project when he gets back from Iraq around Jan. He will be then stationed in GA for a year or so he said where he wants to try to finish it up.My experience with my rigs is documented on my website, www.crustycruisers.com I finished up, "Matt's Cruiser" about 2 years ago, currently working on, "Lana's 45 Wagon" All those links are on the side bar. I know he's emailed me a couple times this morning from Iraq this morning and now is probably watching this thread. I imagine he might pipe in with a few questions, probably under the user name, "RPGDOGER". Seems to be what he goes by........... Matt __________________ Wanted to buy: FJ45LV interior door handles and door jam stops. If you have any or know of any, please PM me. Thanks, Matt |
#18 | |||||
If you do get this truck for your buddy I would second Wayne’s advice about Gozzard. I really want to do a Gozzard truck at some point! hth’s gb |
#19 |
Matt,
HeavyLift or RPGdodger its all the same.... travis |
#20 | |
I agree, extremely nice stuff. I'm pretty sure that's what he is leaning towards. In fact, he's posted on this thread now under, "Heavy lift". He can start answering some of these questions But unfortunetly he can only ask questions, ultimetly I am the one who has to make the descision since he is far, far away until Jan.Matt __________________ Wanted to buy: FJ45LV interior door handles and door jam stops. If you have any or know of any, please PM me. Thanks, Matt |
#21 |
i would go with the Gozzard tub...matt has me convinced its a great option.
still wondering if that engine is gonna be a bigger headache than we think.... |
#22 |
Any of you gentlemen have any experience with the B engine?
Curious if you found it underpowered.... |
#23 |
The math will contradict this but the B actually *feels* faster in a stock rig. Something about the power curve I guess. I'm pretty sure it will lose in a race with a 3B powered rig but if you drive them one at a time the B will seem faster. This has been my experience anyway.
You can't really lose on an $800 rig anyway. drive it around while you fix the body and then swap in a 13BT later My folks live just across the lake from you guys and I'm surprised there's a cruiser in NW Ontario I don't know about. I'll have to have a chat with my spies there. __________________ Rocky Mountain Land Cruiser Association TLCA # 5513 '87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn I support our Troopies |
#24 |
what happens when you throw on a pair of 33's?
#25 | |
Or a 13BT ![]() Definately factor a different engine into the picture with time... gb |
