Could one charge one's 24V system with two 12V automatic battery chargers, each connected seperately on each batt.?
__________________ "You spend $3,000 on a pair of night-vision goggles so you can freak out your cat at night, and I'm the one who's baked?" 1971 Pontiac LeMans 1984 YAM. XT600 1982 Toy pickup, 2LT diesel 1983 BJ42 1985 BJ74 PTO winch (lawn ornament, thanks NHTSA )
No you just need one charger and hook it to the motor for ground and postive on the one battery. AT least thats how the manual tells you to jump them, I think two chargers on the two separte batteries would be fine but I would disconnect the battery cables!
I don't know too much about it either, thats just what I've read __________________ 1986 BJ70, 24v with a 3B |
#3 | |
Also, if you are talking about jump starting and not battery charging....when jumping a 24V vehicle it is always wise to have a volt meter on hand to determine which battery is low, or if it is both. If one battery is low, connect that battery to the cables from the battery poles, then go to the jump vehicle battery + pole, then final hookup is chassis ground on the jump vehicle with the negative lead (assuming a 12V jump vehicle). I do NOT go to chassis ground on the 24V vehicle that is being jumped. It would be too easy to muck it up and cross something. If both batteries on the 24V vehicle are low, use two jumper cables, and treat each battery independent, and go to chassis ground on each jump vehicle (assuming the jump vehicles are 12V). If you do not introduce chassis ground on either vehicle then you can simply go from battery to battery, and leave everything hooked up. There is the chance of spark when doing the final connection, which is why chassis ground is always recommeded, as the spark will be away from any potential battery acid vapors...so if you go battery to battery, wear a shield, look to the side, protect yourself...etc. Hope that made some sense...working on 4 hours sleep in 36 hours... gb |
i boost as if i was boosting a 12V, positive and ground of the same battery. i never ground to the frame.
charging the same way. postive to positive and ground to ground. i someitmes charge both at once using 2 chargers. cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
This is a good topic. Especially the jump start procedure. Does anyone have any drawings of manual instruction to post?
Greg, get some sleep. Was Abby on fire last night? ![]() Thanks, B __________________ Bruce, '76 FJ40 (sold long ago), '88 JDM BJ74V (recently sold), '86 HJ60, TLCA #15095, Coastal Cruisers member "The worst moment for any atheist is when he feels grateful for something and has no-one to thank." |
Do you disconnect the cables when charging with two seperate chargers? I'm just using two 2A automatic chargers.
You can charge two batteries from one charger. First is to disconnect the two batteries from your ride. Next, connect both batteries pos to pos and neg to neg. Last, connect the charger to either battery, it doesn't matter much which. Be sure you have plenty of time. You can best preserve what's left of your battery life with a slow charge. A 2A charger would probably need an overnight to reach a full charge.
Kalawang __________________ LC80 Full time AWD 1HD-T 1990 model 4" Lift 33" Yoko Geo MT Airtec Snorkel Bullbar 9,000 Warn PIAA CDL |
#8 | |
You can also charge in parallel as described by Kalawang if you have one charger... gb |
#9 | ||
gb |
#10 | |
Yes, its as easy as it seems. red to + and black to - __________________ Rocky Mountain Land Cruiser Association TLCA # 5513 '87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn I support our Troopies |
#11 |
do yourself a favor and boost on the baterie that is gounded to the frame that way your tied into the 12V part of the system then you can hook posotive to posotive and negative to negative and you won't blow up your donor battery. The same rule applies If you were to boost a 12V from your rig as the donor. Use The battery that is grounded to the frame!!
#12 |
You can boost straight to the upper battery as well, if that is the low one. Just do not introduce frame ground. That would be an ouch.
+ to + and - to - as Lowenbrau said earlier. gb |
#13 |
Well in my opinion boosting on the upper battery would not be a good idea unless you were to take it out of the series first because hooking to the negetive post without disconnecting it from the other battery is just the same as going negative to posotive on the first battery in the series and I sure you don't want to do that .
#14 | |
__________________ Stone's Land Cruiser & Flyfishing Pics Flyfishing British Columbia: www.flyfishbc.com bcfishingreports.com |
#15 |
I'm making that same face that RAMullen makes when I ask him questions about Propane injecting and turbo charging IDI diesels. As long as you are connecting a 12v charger or a 12 V battery to another 12V battery and you are doing it + to + and - to - it doesn't matter whether its a 12V or 24v or 600 v system. Ever wonder why a bird on a wire doesn't get electocuted? __________________ Rocky Mountain Land Cruiser Association TLCA # 5513 '87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn I support our Troopies |
#16 |
Hey...Nice avatar, Bruce!
#17 | |
#18 |
I just don't get why the manual tells you to ground to the frame?
#19 |
Connecting to the frame is a safety thing. In the old days batteries used to gas off a lot of hydrogen when they were charging. Owners were expected to top up thier batteries with distilled water every so often as a result. The proceedure of connecting + to + and then - to ground (of the dead rig) was to have the inevetable arc from the final connection as far as possible from the explosive gas. These days batteries lose a lot less gas and it is a smaller issue though it's still wise to connect the dead battery last.
#20 |
So conect one jumper to + on battery 1 and one jumper on + to battery 2?
right? __________________ 1986 BJ70, 24v with a 3B |
#21 | |
It seems easier to me to connect + to + and - to - __________________ Rocky Mountain Land Cruiser Association TLCA # 5513 '87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn I support our Troopies |
#22 |
so if I am using my power box, I just put the jumper cables on the high battery just like I would if it was a 12v truck, right?
#23 | |
#24 |
Do we need a diagram?
