| View Poll Results: Which engine would you choose? | |||
| 3B |
11 | 35.48% |
| 11B |
0 | 0% |
| 13B |
14 | 45.16% |
| 14B |
6 | 19.35% |
| Voters: 31. You may not vote on this poll | |||
TLCA# 16387
Which "3B" series engine to use?
I'm toying with the idea of installing a "3B" series engine (with a turbo of course) into the '67 FJ45LV in the process of restoration. Here in Central America the "3B" and "H" series engines are relatively common, however turbo's are not common on those engines (I've never heard of a turbo'd one of these locally).
I can get the 3B, 11B, 13B, and even a 14B. Which would be preffered? I'm not a fan of the "H" series due to it's problems of cracking rings. I know the 3B isn't perfect but with an alloy head most of the 3B problems are taken care of not to mention my mush greater familiarity with them. __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
Well, if you're saying you can't find parts for the 13B in your region, and that parts for the 3B are common, then I guess you may want to consider the 3B.
However, all things being equal, the 13B is a much more powerful engine than the 3B and would be my choice. __________________ MOOSE SOLD HER - SOMEDAY SOON JDM's...THEY SAVED THE BEST FOR THEMSELVES!! |
The main difference between 3B and 1-3B-T is the head. same stuff from the head down as a 3B. Direct injection, and no glow-plugs, a pre-heat screen instead, and of course turbo, all really great options. The 2H is, unfortunately, a bucket of bolts, probably the worst engine Toyota ever made, however: the 1-2H-T is an awesome engine. The turbo is the same as a Toyota Supra, just the housing's different. Pretty much everything but the head and turbo(+40 hp!!) are the same on 3B and 1-3B-T engines. The JDM parts can be had. 1-3B-T is the best "bang for the buck". Not to say the old 3B isn't a good ol' workhorse
__________________ "You spend $3,000 on a pair of night-vision goggles so you can freak out your cat at night, and I'm the one who's baked?" 1971 Pontiac LeMans 1984 YAM. XT600 1982 Toy pickup, 2LT diesel 1983 BJ42 1985 BJ74 PTO winch (lawn ornament, thanks NHTSA )
Diesel for blood
Cruiser guy,Did you mean you can get 13B but not 13BT?
Does anyone know much about the 13B 14B ? Ive always presumed the numeral '1"in front of the 4B meant it was turbo ready?? Ive heard it has a thicker crank, reinforced block or bigger bearings ect. Its got 96hp and 177lbs/ft of torque,has a slightly longer stroke and 18:1 compression ratio. It could be a real giant killer with a turbo You can get parts easy anywhere Dynas are sold. If anyone was interested there is a place in oz selling brand new injector pumps for 14B for $600US |
Absolutely the 13B-T out of your list, Charles. Greg and I are going to shim our turbos in the next little while to bring our boost back up to spec...and we're thinking there should be a good difference.
All that said, I love the 12H-T...smooth, torquey, and a miser with fuel. The short production run of them would be what would have me worried...but they are great engines. __________________ Stone's Land Cruiser & Flyfishing Pics Flyfishing British Columbia: www.flyfishbc.com bcfishingreports.com |
Stone, what do you mean you are going to "shim" your turbo?
-kevin |
We'll do it first, then report back if it is noticable and worthwhile
![]() gb |
#8 | |
#9 | |
Mod in Hibernation
shimming the wastegate mech? how about just restrict the air to the wastegate, that'll bring the boost up to better than pathetic 5.5psi levels. eh? aim for 13-15, please do report about shimming......... __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
#10 |
The "1" in front of the 3 or 4 in 13B or 14B says they are direct injected, unlike the 3B. The 13BT is as you know in addition turbo charged. Same applies to the 14B-T. The 14B(T) is 3.6 liters if I remember correctly. I know the 13B and the 14B were/are powering some of the Dynas.
__________________ Greetings from Northern Norway, Vegard. |
#11 | |
Diesel for blood
#12 |
I would hazard a guess that any of the "1"s without a turbo must be mondo smokey....
gb |
#13 | |
TLCA# 16387
#14 |
i tried something yesterday since i over fuel my own trucks and do not have the pyro problem that you do. i tried lugging through the gears and the temps rose fast but when i drove as i normally do the temps were fine.
could it be yo are working the engine to hard, not allowing it to breath? try bring the revs up higher between shifts so it isn't lugging as much and let me know what happens... cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#15 |
Brownbear, I guess they don't want to tell us what "shimming" the turbo is. Maybe its a secret... ;-)
-Kevin |
#16 |
It's no secret, Kevin...and Brownbear knows exactly what it is (as in his post). We're planning on shimming our wastegate so that it builds up more boost before dumping. After talking to Rob Millson, Greg decided to put a vacuum gauge to our engines to see exactly how much boost we're developing. His was making around 6.5 psi, and mine was a pretty low 5.5 psi. So...we're planning on shimming our wastegates to bring it up to the factory 8 psi and see if that makes a significant difference. We'll let you know how it turns out.
#17 | |
As Stone says...we will report back when done. hth's gb |
#18 | |
TLCA# 16387
#19 |
1-4B powered the 2t dynos (is that the same as Hino in NA?), I'm not sure if there was a turbo option on them.
#20 | |
If you look at the track record of Toyota, for the most part they only improve on design as time goes on. I would go with the 14B if you can, it is basically an updated 13B.
Cheers, Michael Quote:
#21 |
what does the waste gate actuator setup on the 13BT look like that you guys are taalking about shimming? On my AXT I bottomed out the turn buckle trying to get more boost pressure but could ony achieve about 8psi so I cut some of the threads off the linkage and was able to bring it up to 12psi but that was about all I could load it up to.
#22 | |
TLCA# 16387
Many of the factory OEM turbo's are non-adjustable which is why Stone and others need to shim them (basically move the actuator away from the wastegate thereby increasing the actuator/wastegate distance and "tightening up" the linkage (is that about right Greg/Stone). __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
#23 | |
Stop adjusting the vacum linkage and get a grainger valve, that will allow you to trick the vacum into thinking you have less boost that you actually have and delay the bypass. I have found them to work great. Cheers, Michael Last edited by tlcruiserman; 08-30-05 at 05:39 PM. |
#24 | |
We are playing a little to see if the amber light comes on, and what PSI this will happen, and how much shimming is needed to make it happen, so some data will be in the collective if someone wants to do this, not use a grainger valve, or boost gauge. The manual says the amber light on the dash should come on at 15.5lbs. When we are done playing, we'll post up. I think it will require too much shimming to get to 15.5lbs, however if someone can add a small amount like say...4mm, and get a few more lbs (which will be noticable) and run at 8.5-9lbs..with little worry, this might be good...no? gb |
#25 | |
NO, it is very bad. I think you should remove the entire engine and send it to me, then install a good old 3B. You will thank me when you do!
__________________ Diesels Rule 81 BJ42 Check out my endless fix up progress at http://forum.ih8mud.com/ca-bc-peace-canyon-toyota-swamp-donkeys/152995-bj42-winter-fix-up.html |
#26 | |
now do note that if the spring did fail either breaking or weakening, the boost would go back to 8 lbs, if the complete unit came free of the housing then the boost would be usually 20 lbs (or so i have seen). __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#27 | |
