Old 08-10-05, 11:22 AM   #1
BJ60 Overheating
Ok, I was rushed and lazy. I had a mechanic replace the waterpump, rad hoses, thermostat, install a block heater and powerflush the 3b. Afterpicking it up, the engine gets really hot (almost to red zone), then the thermostat opens and the temp drops to just over 1/2 way mark. Pulled the thermostat and tested, it seems to be opening to high, so I went to Toyota purchased another and installed it. It does the same thing! Previously, it would run between 1/4 to 1/2 zone. Any ideas? (besides going back to the mechanic, had too many problems with them).
-It was running fine before the repairs. it would go from cold to middle and then run between 1/4 - 1/2 range.
-It doesn't overheat, just goes from cold to very hot (almost red section) then back to just over half way.
1985 BJ60
3.4l 3B Diesel
Naturally Asperated
H55
340k
randman59 is offline   Reply With Quote
Old 08-10-05, 11:40 AM   #2
Deny's Avatar
TLCA# 11568
I had similar issues with my truck when I first got it, except it was more fluctuating, and it would really freak me out. It ended up being a bad connection at the temperature sensor by the water pump, I cut off the old conector, and saudered in a simple conector, and its worked great ever since.
Just a thought.
Cheers,
Deny
Diesels Rule
81 BJ42
Check out my endless fix up progress at http://forum.ih8mud.com/ca-bc-peace-canyon-toyota-swamp-donkeys/152995-bj42-winter-fix-up.html
Deny is offline   Reply With Quote
Old 08-10-05, 12:03 PM   #3
I think that is a different issue. The Temp and Fuel gauges usually over-read at the same time. Mine does that as well. Thanks for the tip on how to fix that one.
Old 08-10-05, 12:27 PM   #4
Just fishing here, is it possible to put the thermostat in backwords?
Rob
Come and visit us in Duncan, BC
www.raddcruisers.ca
--> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included
--> in stock and ready to go.
Old 08-10-05, 02:39 PM   #5
David*BJ70's Avatar
TLCA# 15514
Maybe that can help you... specialy the post #5...
http://forum.ih8mud.com/diesel-tech-24-volts-systems/40854-thermostat-question.html
BJ42 1982 * The Primitive Beast - wvo
BJ70 1985 * The Green Machine - wvo some say The Mighty Pickle ! come on !
1992*Corolla*All-trac* The Quiet Spirit
Si je dois aller en enfer... ce sera en Landcruiser
(Canadian french guy (Québécois)... sorry for my english ! )
David*BJ70 is offline   Reply With Quote
Old 08-10-05, 06:29 PM   #6
silvercrusher's Avatar
Since it isn't overheating it is probably ok. The spring on the t-stat is new and may take awhile to pop when its supposed to. Give it a month and see. I would put in a mech temp gauge and watch that. Those oem gauges are crap. Real gauges will save you hours of wondering.
Cheers
Challis
"it'll only take a minute to fix"
85 BJ60 all stock so far
03 VW JETTA WAGON TDI
silvercrusher is offline   Reply With Quote
Old 08-10-05, 08:05 PM   #7
Diescipel's Avatar
TLCA# 14854
What temp t-stat did you put in? Did you have an 82 degree replaced with an 88? I just replaced my 88 with an 82--down here in relatively warmer Cali the 88 would do what you describe your rig doing now, and the 82 does what you describe your temp did before the work was done. Just a thought.
B
Brendan
1983 BJ42 bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
Diescipel is offline   Reply With Quote
Old 08-11-05, 03:57 PM   #8
They only sell 88 degree t-stats here. I talked to a Toyota mechanic yesterday who indicated that this is quite normal. Thanks for all the help.
Old 08-11-05, 08:13 PM   #9
Eric Winkworth's Avatar
What do you mean normal, does it just have to break in?
1986 BJ70, 24v with a 3B
Eric Winkworth is offline   Reply With Quote
Old 08-12-05, 12:13 AM   #10
My understanding is the T-stats are slow opening when new, the spring should soften up in a while.
Old 08-13-05, 10:42 PM   #11
cruiser_guy's Avatar
TLCA# 16387
My 88 degree stat works quite well everywhere even in Phoenix last week at 105 with the A/C running and the truck grossly overloaded!!
www.wirrell.com
Loans | Deals On Products | The eBay Song | Tallinn Stag Weekends | Charity
