Old 08-07-05, 01:56 PM   #1
needed: electrical connector
My old BJ just about caught fire as a live wire chaffed through, causing a short. The end result was it melted one of the 2 large blade type connectors inside the round off-white/opaque toyota electrical connector. Better than a fire caused by about 1000amps for 40-50 seconds but I've ruined that round off-white toyota connector.
In the end I need a toyota connector,( it appears water tight as it has a couple rubber gaskets), This connector carries juice from my battery to the relay and the glow plugs. It has two wires going in each end. Any body have one can email me to set up arrangements.
thanks
Aaron
magnus_heydoc is offline   Reply With Quote
Old 08-07-05, 02:15 PM   #2
daz
glow plug relay
can you tell me where they hide the glow plug relay on a 1997 landcruiser gs 4.2 diesel please
daz is offline   Reply With Quote
Old 08-07-05, 04:34 PM   #3
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
it should say in your factory service manual
but also this is a hijack on the above mentioned question.
-91 FJ80, wife's ride
Old 08-07-05, 04:39 PM   #4
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
thanks
Aaron
sorry I do not. but how were you going to wire it on? were you going to buttsplice it in or is there a way to disassemble the plug to resolder wires in?
if you were going to splice it on, you could bypass the connector and do a good solder job with shrink wrap on it. that would be fairly enviromental. you could even use some dielectric grease over inside the shrink wrap to prevent any corrosion from happening.
glad a fire never claimed a old BJ
Old 08-07-05, 07:10 PM   #5
buttsplicer not buttpirate!
yeah, I was just going to splice it in. Technically I'm not sure exactly what the connector accomplishes that buttsplicing wouldn't. I sort of had the addition of a fuse in the back of my mind somehow. I'm sort of surprised there wasn't a fuse in that circuit. Could have been a wicked fire and then possibly no more surf rig!
That connector was water tight I believe, maybe that's it's only purpose. Just wanted to replace the OEM part. Any idea if there is a part number for that?
Old 08-07-05, 07:12 PM   #6
Ol'smoothy
I just wanted to smooth things over before I cram a turbo in there.
For the last few mornings she needed a lil'Ether!
Old 08-07-05, 11:01 PM   #7
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
I am told jap diesels don't last very long using ether. They are not very liking of that torture. but when you don't have glow plugs............what to do?
If your going to buttsplice using the connector reallly serves no purpose.
IMOP just solder it. Buttsplices are better used inside the truck. Under the hood you are asking for trouble. They turn green fast.
Old 08-07-05, 11:07 PM   #8
wesintl's Avatar
TLCA# 4180
what is it with the bj's and fire this week. Sorry I can't help.. I was looking for a connector too so I went to the salvage yard and yanked a few off a 60.. none were the same blade. DOH. anyway good luck with your cruiser..
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Old 08-16-05, 08:12 PM   #9
I just got JACKED!
So I went to the Toyota dealer to see if they had a 'box with various connectors' and the parts guy, a super nice guy--very knowledgeable, sold me a thick wire like what was on the original, with a blade on the end. It was pretty much the same except it didn't have the little lock tab so I siliconed it in place inside the original connector----the only problem is that one blade connector was 9 dollars after taxes!!! Now that's not a rip off, that's a jack!
Works fine now however, I'm heading to the boneyard to see if I can find some trucks to rob.
ADJ
Magazine Subscriptions | Mortgage | Cell Phones | Loans | Secured Loans
