LinkBack (5) | Thread Tools | Display Modes |
#151 |
Diesel sniffer
Jim.
You need to unzip the files and put them on CD, the program won't run direct from the hard drive until you have the CDs, then load them onto the hard drive as part of the setup. In the zip file there should be a file that tells you what to name the CDs. They need to be named correctly otherwise the program won't recognise them. __________________ Cheers Andy 1993 HDJ80 (1HD-T engine) Brooklands Green Metalic. 210K miles. Factory Winch, Old Man Emu Shocks, 17 inch wheels, 265x70x17 Cooper Discoverer ATR http://www.gloucestershire4x4response.co.uk http://www.4x4response.info |
#152 |
Cruiser Curmudgeon
I thought the version that required burning to CDs is the two large files from the yankeetoys.org site?
The readme that came with this file said only to run setup.exe, then copy the three folders to the root C:/ directory. Which I've done 2 times now. If I can't get this version to work, I might try the 2 YT disc downloads. __________________ Thanks, Jim C. TLC Performance Underhood Janitor, cleaning up other people's since 1988. |
#153 |
Jim,
The version you got from me is the DVD version I guess. I also have the older version if you are interested, but that version has an aversion to installing on large sized harddrives so it is a little more tricky than the version you already have. I am currently installing this on my office computer so I will tell you what I had to do in addition to what the readme file says. __________________ Andrew 75' FJ-55 (future project) 87' FJ-60 (3FE-H55-Marks gears) 97' FZJ-80 (stock) 01' Taco (stock) |
#154 |
Hi
I have installed the DVD verson of the EPC on my computer follownig the readme file, but when i start the EPC program and press "1. Part Number Translator" the only thing that happens is that the program says "Execute the set up". What have i done wrong?? Please help me. |
#155 |
just saw this today is this dvd still available from soneone ?,the torrent link is dead ?? hope i didn't miss out
__________________ Jake S. FJ40,small block ,sm465 ,spring over ,cut-N-turn,shackle reversal, 38.5 superswampers, 4 wheel disc brakes, OBA=CO2 ,Warn 8274 ,4x4 labs high steer,Marlin chromo birfs , Metaltech Jackson cage ![]() ...ROTW:PBGBOTTLE.... ...Cardomain Pics ... EPC anybody
#156 |
thanks for the download Andrew . it works for me still learning how to use it tho . i just opened it with winrar ,did not extract it , ran the setup exe ,extracted the folders to copy to C . ,and copied them over . over-writing some of the files when asked ,. did not need to burn to dvd . thanks again
#157 |
did a test search for emblems ,this what came up this EPC is fun could be playing with it for hours
#158 |
Any one willing to seed?
Is anyone willing to host/seed this again? It would be much appreciated!
Have a great one, __________________ '85 FJ60, 2F,4spd,33x9.50, AAL, Conferr Rack Central Oregon |
#159 |
THE ANCIENT ONE
does any one actually have this copied to DVD
and available to keep from killing a gig of storage space and LOTS of time downloading?
you can email me at srplus@hotmail.com or click on the link in my sig line thanx __________________ SR+ steven d philbrick srplus@hotmail.com '86FJ60 - 'BlueBird' . '69 fj40 SOA - 'Piney Woods Rooter' . "nothin' but the best for my hawgs." - the great santini
#160 |
i got ahold of a price file for the epc .i don't know what language it is in but it does give a list price for the part #'s you enter ,it must be a newer file because some of the older fj40 part #'s come up blank . don't even know what currency it is in,
![]() i punched in the 69-79 bezel came up $71.83 and chrome $89.76 bezel 79-80 showed up $49.28 chrome $67.09 . does this even sound close . anyways just messin around with the EPC thought i would share
#161 |
Go to this thread to download the EPC
REMEMBER, YOU NEED TO RIGHT CLICK AND THEN "SAVE AS" TO DOWNLOAD!!!!! __________________ Andrew 75' FJ-55 (future project) 87' FJ-60 (3FE-H55-Marks gears) 97' FZJ-80 (stock) 01' Taco (stock) Last edited by Aseif007; 09-01-06 at 09:43 PM. |
#162 |
pic for andrew on the general discs installed , plus shows the extra JAPAN B3
also not to sure about the frame cd's yet ,maybe a frame #'s search i don't know . anybody have U.S.A disc's __________________ Jake S. FJ40,small block ,sm465 ,spring over ,cut-N-turn,shackle reversal, 38.5 superswampers, 4 wheel disc brakes, OBA=CO2 ,Warn 8274 ,4x4 labs high steer,Marlin chromo birfs , Metaltech Jackson cage ![]() ...ROTW:PBGBOTTLE.... ...Cardomain Pics ... EPC anybody
#163 |
o.k. heres an update i've managed to track down almost all the cd's (i think )unless there is more to the USA one . i have installed everything and managed to zip it all up like the origional download from Andrew . all i need is someone to host the download . it is huge zipped 3.3 gig unzipped 8.6 gig all cd's 2004 a couple 2003 anyone like to host
this copy of the epc actually contains the contents of the 18 disc's that i have aquired some i actually paid for .some a pirated copy .
#164 |
more of cd
#165 | |
BJ addict
__________________ 1983 BJ42LV 3B turbo diesel, 5 speed, power steering 24V Viair 450C, ARB locker front/rear, OME Heavy 4.56 R&P, BF Mud 255/85 (34") Warn M12000 24Volt http://www.ericleblanc.com/gallery/m...p?g2_itemId=20 |
#166 |
An idea. How about zipping the sub folders that hoold the data seperatly... that way if I have the app already installed, I can download just the US or Japanese, etc. info...
Thanks! Kraig |
#167 | |
i tried that when i first used the origional copy ,probably the one you have installed and even after i copied over the files the initial installed app would not see the new files . (general and USA) to get tha app to see the new files you need to copy over the installed folder file .its only 2.86.MB anyways . the only way you can install just the files you need is to have the cd's and install each one at a time .and you have to have them all because it ask's you to put each one in before acepting the next one (to verify you actually had the cd's .i guess i could make ISO's of the cd's and post just the cd's . 18 of them, .all at about 560 mb each still alot of downloading . then you could download only the cd's that you need . may be easier . i will get this hosted shortly
#168 |
pbgbottle, How do I get the U.S. data you have in your screen shot?
Thanks! __________________ ARB Bullbar, Front OME 850J Rear Custom Slee springs approx.10% stiffer than OME 863 pin 7 mod & CDL, Kenwood DVD/Garmin NAV, Power inverter, auxfan, rt temp gauge mod & a bunch of other things…… |
#169 |
#170 |
I am trying to install disc 1 and 2. How do I get past the not enough disk space? I have 170 free gigs?
#171 | |
the problem is you have too much disc space .the epc is old .make a 3 gig partition and put it on there .or download the newer one has no disc space issue
http://aseif007.net/ih8mud/ToyotaEPC.zip Quote:
#172 | |
I've tried twice to download but each time it gets to just over 800mb and stops/says download complete. Is that a problem on my end? |
#173 |
i heard people where having problems .so it was recommended to use a download manager .to resume download later if connection gets broken .
#174 |
OK...I got it...Took aboot 1/2 hr to download...I've been having issues with my DSL being slow, but it stayed at 640Kb the whole download..
![]() My question is, is this the 18 CDs?...My file size was 1575MB... __________________ Art 80 Hilux 22R Hybrid w/dual Mikunis, R151 trans, Budbuilt crossmember, 33" Buckshots 74 FJ40 "The Project" 86 Cressida 99 Tacoma And for parts: LOL 75 & 79 FJ40 84 4Runner 85 Cressida 86 PU Two 88 PU's TLCA #8472 |
#175 |
The file is about 1.6 gigs. Sorry if people are having problems but I think it may be on their ends?
#176 |
OK...I'm installing it now...
I see in the read me, this is just the Euro to 02, and the Jap to 00... Anyone have the US files?... I'd like to look up Tacoma and Tundra stuff as well... Thanx again! __________________ Art 80 Hilux 22R Hybrid w/dual Mikunis, R151 trans, Budbuilt crossmember, 33" Buckshots 74 FJ40 "The Project" 86 Cressida 99 Tacoma And for parts: LOL 75 & 79 FJ40 84 4Runner 85 Cressida 86 PU Two 88 PU's TLCA #8472 |
