Old 07-25-05, 09:50 AM   #1
cruiseruser's Avatar
dome lights and sunroof not working!
I posted in the 80 tech section but haven't gotten any ideas yet. I thought I'd ask you guys for some help. It's a 96 80 series. The fuse is fine. The sunroof is wide open. Thanks, Ryan.
cruiseruser is offline   Reply With Quote
Old 07-25-05, 01:13 PM   #2
Tapage's Avatar
You need to check all wiring, to know if to the SunRoof have apropiate 12V ( 24 if is you case ) and the motor, the controls and all thinks involved ...
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 07-25-05, 01:51 PM   #3
silvercrusher's Avatar
Look in your manual there should be away to close the sunroof manually. I think it should have a crank or something. Then find the motor for the sunroof ,just look around up top there and follow the sliding mechanism you should be able to see it. Get a multimeter and see if you have power to the motorwhen the button is pushed? I don't know what else to suggest
"it'll only take a minute to fix"
85 BJ60 all stock so far
03 VW JETTA WAGON TDI
silvercrusher is offline   Reply With Quote
Old 07-25-05, 01:54 PM   #4
Still thinking! You might have a relay under the dash after the fuse? Follow the wire and see where it goes. Check power before and after each component.
Mobile Phones | Loan | Hummer Dealer | Mortgage Calculator | Loans
