Old 07-21-05, 12:03 PM   #1
David*BJ70's Avatar
TLCA# 15514
Nozzle leakage pipe tub remplacement ?
Anyone know what is the best tube I can use to remplace the old one (overflow tube ?)?
BJ42 1982 * The Primitive Beast - wvo
BJ70 1985 * The Green Machine - wvo some say The Mighty Pickle ! come on !
1992*Corolla*All-trac* The Quiet Spirit
Si je dois aller en enfer... ce sera en Landcruiser
(Canadian french guy (Québécois)... sorry for my english ! )
David*BJ70 is offline   Reply With Quote
Old 07-25-05, 09:03 AM   #2
David*BJ70's Avatar
TLCA# 15514
OK, I put my question in a different way.
What materials should I absolutely not use for pipes in contacts with diesel?
Old 07-25-05, 10:51 AM   #3
Deny's Avatar
TLCA# 11568
If it is leaking is there anyway to braze it to fix it, or my other suggestion is try getting a whole new or used piece?
Diesels Rule
81 BJ42
Check out my endless fix up progress at http://forum.ih8mud.com/ca-bc-peace-canyon-toyota-swamp-donkeys/152995-bj42-winter-fix-up.html
Deny is offline   Reply With Quote
Old 07-25-05, 02:57 PM   #4
David*BJ70's Avatar
TLCA# 15514
Let me more explicit : I talk about the little flexible black tube. (not show on the picture)
Old 07-25-05, 03:05 PM   #5
Deny's Avatar
TLCA# 11568
Toyota want's too much eh?
Talk to the local parts store about fuel line, maybe they got something you can custom fit? if you plan on running biodiesel some day just stay away from rubber.
Cheers,
Deny
Diesels Rule
81 BJ42
Check out my endless fix up progress at http://forum.ih8mud.com/showthread.php?t=152995
Old 07-25-05, 03:11 PM   #6
wesintl's Avatar
TLCA# 4180
Isn't the oem one rubber anyway? Mine is unless it's not OEM. You could just use some rubber fuel line. BTW the # is 95332-04020 I don't know if it's been superseeded or not.
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Old 07-25-05, 04:55 PM   #7
lowenbrau's Avatar
TLCA# 5513
Any fuel safe hose will do. The scavenger line is low pressure. As Deny says don't use rubber for biodiesel unless you want to replace it with all the other rubber hoses when you do.
Rocky Mountain Land Cruiser Association TLCA # 5513
'87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn
I support our Troopies
lowenbrau is offline   Reply With Quote
Old 07-26-05, 06:16 AM   #8
David*BJ70's Avatar
TLCA# 15514
OK. Thank
Personal Loans | Myspace Proxy | Internet Advertising | Loans | Loans
