Old 07-22-05, 11:28 AM   #31
Tapage's Avatar
Originally Posted by brownbear
what typically is the "range" one of these engines run at? 60 psi? just wondering if I do buy a oil px gauge then do I get the 0-100 or 0-200 gauge?
2F and 2H engines 62PSI @ 2000 rpm .. ( with operative temp )
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 07-22-05, 02:20 PM   #32
expat's Avatar
TLCA# dunno
remember that guages are most accurate in the midrange (middle third)... so 0-100 seems about right.
Billions of bilious blue blistering barnacles!
1988 HJ61
1977 FJ40
1981 Nordic Tug 26 (now with new Volvo power)
I'm done with this Retard bandwagon back slapping thread. - Guambomb
I don't need stupid comments...I am asking for insight not half witted moronic mumblings. - Webelk6
expat is online now   Reply With Quote
Old 07-22-05, 05:23 PM   #33
silvercrusher's Avatar
Originally Posted by BURGER
Why do all these web sites that I read all have a bleed off port. Is the the design for some other type of turbo or only for gas motors?
Again going on Gt theory. Bleed air is required to stop the surge and stall that can occur during startup or initial spoolup. If you have air constantly moving through the turbine you have less chance for it to reverse flow . It pretty much allows the pressure to build slowly instead of slamming the turbine with max pressure. You may be eliminating the need for this by using the variable spring setup. Try without like you said and if it doesn't "unload" Then put it on.
"it'll only take a minute to fix"
85 BJ60 all stock so far
03 VW JETTA WAGON TDI
silvercrusher is offline   Reply With Quote
Old 07-22-05, 07:06 PM   #34
BURGER's Avatar
Good explanation!
BURGER is offline   Reply With Quote
Loans | Teen Chat | Homeowner Loans | Car Loans | Remortgages
