Old 05-10-05, 11:34 PM   #1
Island Moose's Avatar
Oil drip source located...sort of...
Hey guys,
The one or two nightly drops of oil under my rig are coming from the bottom of the dust shield in the tranny bellhousing, the oil gathers and drips from the two lowest bellhousing/engine bolts. I assume this means that either my engine rear seal or my tranny input shaft is seeping somewhat, but I suspect the tranny because the oil is clearish, unlike the engine oil which is black. Would you concur?
I assume that the tranny won;t run dry as this seal is well above the oil level...thoughts on this as well?
Thanks guys.
MOOSE
SOLD HER - SOMEDAY SOON
JDM's...THEY SAVED THE BEST FOR THEMSELVES!!
Island Moose is offline   Reply With Quote
Old 05-10-05, 11:53 PM   #2
Stone's Avatar
TLCA# 13772
Mine also has a little bit of oil in that area...specifically right near that foam piece, right? Mine doesn't drip enough to leave stains on the ground, but there s a bit of wetness there. I've been told that most diesel Cruisers do this, and it's not necessarily a cause for alarm unless it's excessive.
Stone's Land Cruiser & Flyfishing Pics
Flyfishing British Columbia: www.flyfishbc.com bcfishingreports.com
Stone is offline   Reply With Quote
Old 05-11-05, 12:09 AM   #3
She idles just fine
dieseldog's Avatar
TLCA# 14999
My BJ-73 does the exact same thing as Stoney is describing. The foam piece under mine gets sorta saturated. I don't get any drips on the drive though. My KZJ-70 is bone dry underneath. The only leaks you see come from the AC system doing exactly what it's supposed to do: DRIP WATER!
Sparkplugs are Irrelevant.
1976 HJ-45; 1984 BJ-42; 1988 BJ-73; & 1993 KZJ-70
Originally Posted by Hugh Heifer View Post
I have been searching for the right one all day. I like the feel of the small one Yooper has...but your long one was fun to play with . . .
Originally Posted by stinkyfj60 View Post
I have intense impulse control over all situations....
Just sayin'.
Originally Posted by Jman View Post
. . . . I think I am having an orgasm in my mouth.
In Search of More Gubs . . .
dieseldog is offline   Reply With Quote
Old 05-12-05, 01:05 AM   #4
Diescipel's Avatar
TLCA# 14854
Do you think this can be caused by the t-case seal/breather plug problem? I.e. the tranny oil is overflowing its regular limits. Just a thought. Have you checked the tranny oil level lately?
B
Brendan
1983 BJ42 bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
Diescipel is offline   Reply With Quote
Old 05-12-05, 10:12 AM   #5
B
Funny you should say this, when I filled the tranny around Xmas, I think I overfilled it because as I re-installed the filler plug, it was pretty much gushing out. I knew that would come back to haunt me. The leaking really minor (about 1 drop/24hrs) but I'm big into the look of my driveway.
MOOSE
Credit Card Consolidation | Loans | African Cichlids | Loans | Gas Suppliers
