Old 05-03-05, 10:56 PM   #1
Island Moose's Avatar
Oil stains
Hey guys,
If I leave my 70 in one place on the driveway for a week, I get a dark oil spot about 1 inch across on the concrete. It sure looks like engine oil (sooty) but I haven't really looked under there to find a source. Is there a list of usual suspects for this sort of thing (ie rear main seal etc)?
It's really nothing serious, and it doesn't always do it, but I'm really anal about my driveway...hate scrubbing at those gawdamn stains.
BTW, love the new pimp smilie! ...where's the "ho" smilie?
MOOSE
SOLD HER - SOMEDAY SOON
JDM's...THEY SAVED THE BEST FOR THEMSELVES!!
Island Moose is offline   Reply With Quote
Old 05-03-05, 11:02 PM   #2
Diescipel's Avatar
TLCA# 14854
Dunno if this is the same on your 3B II, but I am hating the oil cooler/filter housing area right now, especially the end by the exhaust manifold/downpipe. I hear somebody say sometime this is quite common--I bet the heat from the exhaust kills the gasket there (should there be a heat shield?).
But this could also be your crankcase vent tube (?), or any other gasket. Hard to tell until you actually get under there and check it.
Is there a full gasket kit for the oil cooler housing for a 3B?? Where to get?? 4wheelAuto??
B
Brendan
1983 BJ42 bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
Diescipel is offline   Reply With Quote
Old 05-03-05, 11:05 PM   #3
beanz2's Avatar
That and the rear transfer case output.
I open up large cardboard boxes and put them in lengthwise under the cruisers so oil drips don't get into the garage floor. If outside on the driveway, I use disposable baking pans made of foil, weigh them with a couple of rocks so the wind doesn't blow them away.
Dave
beanz2 is offline   Reply With Quote
Old 05-03-05, 11:09 PM   #4
It's definitely foward of the bellhousing, as I park nose up on a pretty good slope and the little stains appear directly under the pan that sits under the oil drain plug....hmmm....
MOOSE
Old 05-04-05, 12:38 AM   #5
Diescipel's Avatar
TLCA# 14854
Could be just as simple as needing a new washer thingy on your drain plug. Do we change these at every oil change as recommended by Porsche (I used to have an '85.5 944)?
B
Brendan
Old 05-04-05, 04:38 AM   #6
dieselbigot's Avatar
betcha its just your blow-back tube dripping. Mine has always done it and I have no leaks at all on my rig...like dave says, just throw some cardboard under it
88 FJ62 4spd/Toybox/SOA hardcore
99 UZJ100 softcore
03 VW TDI dd
92 M101 cdn
dieselbigot is offline   Reply With Quote
Old 05-04-05, 04:52 AM   #7
Diesel for blood
roscoFJ73's Avatar
The only way is to spend a night out there in a sleeping bag with a torch,sooner or later it will drip
You ARE supposed to change that oil plug washer each time.
Old 05-04-05, 06:38 AM   #8
crushers's Avatar
it can not be the blow by tube since on a 3B II it goes into the intake like a gasser does...
Wayne in Ontario
Old 05-04-05, 09:32 AM   #9
In another twist, mine actually hangs off the side of the block and dumps overboard as these guys say. It's a steel tube pointed straight down with nothing at the end.
MOOSE
Old 05-04-05, 09:37 AM   #10
crushers's Avatar
really?!? can you send me a pic of your engine on that side?
Wayne in Ontario
Old 05-04-05, 10:38 AM   #11
lowenbrau's Avatar
TLCA# 5513
Moose, what manufacturing month is your rig? I'm not sure they put 3BII in until the '89 model year. What makes you think yours is not a plain old 3B?
Rocky Mountain Land Cruiser Association TLCA # 5513
'87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn
I support our Troopies
lowenbrau is offline   Reply With Quote
Old 05-04-05, 10:39 AM   #12
You can see it to the left of the oil filter.
MOOSE
Old 05-04-05, 10:39 AM   #13
Bosch Rotary fuel pump.
MOOSE
Old 05-04-05, 10:41 AM   #14
lowenbrau's Avatar
TLCA# 5513
Rotary pump came as early as '82. Its not an indication of a 3BII. Eight bolts holding the flywheel on is but that's a bit hard to see from the outside. Perhaps the blowby tube is the external clue.
Old 05-04-05, 10:53 AM   #15
crushers's Avatar
take a pic of your tappet cover, passneger side back half...
please
Wayne in Ontario
Old 05-04-05, 10:54 AM   #16
crushers's Avatar
also take a piuc of your exhaust maifold for me...
please
Wayne in Ontario
Old 05-04-05, 10:56 AM   #17
Greg_B's Avatar
TLCA# 7091
We thought we had a 3BII core, till this discussion came up a while ago (Moose's injector issue), then looked closer into it, and it was indeed a 3B, with Rotory pump...which seems to be the norm for the JDM 3B's after some point in the early 80's.
Chances are the oil drip is from your blowby tube Moose. You can direct the blowby tube into the air intake pipe, post air filter.
gb
Greg_B is online now   Reply With Quote
Old 05-04-05, 10:58 AM   #18
crushers's Avatar
never mind, i can see you exhaust in the above pic, that is a normal 3B...
sorry
Wayne in Ontario
Old 05-04-05, 11:36 AM   #19
lowenbrau's Avatar
TLCA# 5513
gb
I'm not sure I've ever seen a JDM 3B with an inline pump. There are two BJ46s around ('81 and '84) and they both have rotary pumps. Charla's '85 BJ73, also rotary. I think Toyota saved the inline pumps for the "third world" or those countries (like Canada) with low quality diesel. I don't understand why the 13BTs didn't get a rotary. Might be too big a pain to modify for boost compensation etc.
Mortgage | Property for sale in Spain | Pink Ranger | Actress | Myspace Layouts
