Old 04-30-05, 11:52 PM   #1
3B head removal (85 BJ70) - might need #1 injector pipe
When I was removing the union nuts from the injection pump, i was able to remove #2,3 and 4 pipes without any problems. I did spay PB a few days in a raw, but I couldn't remove the #1 pipe. I will try tomorrow. If it will not work, I might need a good used one. If someone has one, please let me know.
Thanks,
Alex
TLCA# 3558
97 LX450
bj70alex is offline   Reply With Quote
Old 05-01-05, 07:55 AM   #2
crushers's Avatar
i have one,
BTW give hte wrench a good sharp hit, sometimes that works better than steady pressure...
cheers
Wayne in Ontario
Old 05-01-05, 10:53 AM   #3
Diesel for blood
roscoFJ73's Avatar
When I had this problem on my 1HZ I bought another open end spanner and put 2 spanners on the nut and it worked.
Doubling the surface area of the spanner allows you twice as much force before it begins to round the edges.
Old 05-01-05, 11:46 AM   #4
I notched the end of a closed end wrench like a spanner and use it to hold the injector and and tap the other wrench with a small hammer like Wayne mentioned.
The notch in the end of the wrench was just big enough to allow the injector line to pass through.
Come and visit us in Duncan, BC
www.raddcruisers.ca
--> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included
--> in stock and ready to go.
Old 05-01-05, 12:34 PM   #5
Wayne,
The problem is, the nut is turning together with the injection pipe, looks like the top of the nut is frozen with the pipe. I tried to smack it a bit with the screwdriver, but still cannot remove it. Well, I was trying to avoid removing the fuel pipe from the feeder pump. BTW, how much you want for the pipe.
Thanks,
Alex
TLCA# 3558
97 LX450
Old 05-01-05, 04:53 PM   #6
silvercrusher's Avatar
I get this alot at work and sometimes there just is no way to get it off without shearing the line. Sometimes new ones are just in order you got 20 years out of it waht more can ya ask for?
"it'll only take a minute to fix"
85 BJ60 all stock so far
03 VW JETTA WAGON TDI
silvercrusher is offline   Reply With Quote
Loans | TurboTax | Secured Loans | Mortgage Calculator | Online Loans
