Old 04-21-05, 11:03 AM   #1 (permalink)
Stone's Avatar
Lightbulb 24v Bulb part Numbers
Many of the diesels, especially JDMs, run on a 24v electrical system. Sometimes it's easier to find replacement 24v bulbs if you already have the part number in hand.
With that thought in mind, post up any part numbers that you use, specifying its application, in this thread.
This post will be linked to our International FAQ.
Thanks.
Stone is offline   Reply With Quote
Old 04-21-05, 11:10 AM   #2 (permalink)
Stone's Avatar
Some BJ74 24v bulb part numbers.
I'll start with a few: (Toyota Part Numbers)
1) Dashboard Peanut Bulb, sz Small: 90981-11022.
Application: Climate Controls, Cigarette Lighter, etc.
2) Dashboard Peanut Bulb (Small) Green Plastic Sleeve: 90339-04014.
3) Dashboard Peanut Bulb, sz Medium: 99134-12030.
Application: Instrument Cluster, E-brake indicator, etc.
4) Rear Combination Signal Light: 90981-16015.
Application: Rear Brake/Running light.
5) Rear Single Element Light: 90981-16014.
Application: Rear Turn signal (possibly also front turn signal), Reverse (?).
6) Front Single Element Light: 90981-16016.
Application: Front Running light.
Old 04-21-05, 04:17 PM   #3 (permalink)
A2B in a TLC's Avatar
TLCA# 15095
Thanks Stone,
Good thinking. Much better to share rather than answering just my email.
B
Bruce, '76 FJ40 (sold long ago), '88 JDM BJ74V (recently sold), '86 HJ60, TLCA #15095, Coastal Cruisers member
"...looking to import a JDM 70 series mail truck!"
"I would not say that the future is necessarily less predictable than the past. I think the past was not predictable when it started."
A2B in a TLC is offline   Reply With Quote
Old 04-21-05, 04:23 PM   #4 (permalink)
TLCA# 15095
Do you buy from Lordco or somewhere else? The guy at Tsawwassen Lordco did not recognize the part numbers.
B
Old 04-22-05, 12:29 AM   #5 (permalink)
Stone's Avatar
Hi Bruce:
THose are all Toyota part numbers.
Old 11-04-05, 02:03 PM   #6 (permalink)
24 Volt Bulbs from Gregg Distributors, Calgary;
Instrument panel - GE-13256 5W
Stop / Turn (double filament)
Clearence - GE-1683 (single filament)
Maker - Wagner 1251
Headlight ;H4 - GE-13342 (75/70W)
Should be available at any auto / electrical distributors.
mjohn7 is offline   Reply With Quote
Old 11-04-05, 08:39 PM   #7 (permalink)
fitchik's Avatar
TLCA# 15429
Originally Posted by A2B in a TLC
Thanks Stone,
B
Ditto on that
Thanks Stone... Looking into the FogLight Bulb at Lordco... Did you have a part number for that one?
Silly Boys, Trucks are for GIRLS
fitchik is offline   Reply With Quote
Old 11-05-05, 09:14 AM   #8 (permalink)
Stone's Avatar
Hi Petra:
You foglights take an H3 bulb, and the Hella 24V H3 bulb part numbers are as follows:
-70W 78145
-100W 78132
Old 11-05-05, 04:49 PM   #9 (permalink)
fitchik's Avatar
TLCA# 15429
Originally Posted by Stone
Hi Petra:
-70W 78145
-100W 78132
Thanks Stone... You are an awesome help..
Old 11-05-05, 08:05 PM   #10 (permalink)
FJota's Avatar
I'll second that . Thanks for the info.
88 HJ61
Talk is cheap because supply exceeds demand.
FJota is offline   Reply With Quote
Old 01-23-06, 10:13 AM   #11 (permalink)
Supporting Vendor
Greg_B's Avatar
TLCA# 7091
ARB H3 bulb numbers from Noah:
HB24130 (24 volt 130W H3)
HB12110 (12 volt 110W H3)
Old 09-25-06, 11:04 AM
beauh
This message has been deleted by Stone. Reason: post part numbers only...start a new thread for questions. Thanks.
Old 09-25-06, 10:19 PM   #12 (permalink)
Warning light cluster on 83-84 BJ42's-(four wheel drive light,E-brake light, seatbelt light-each have one bulb-Toyota part#90981-11022(24volt 1.2watt) $4.99 C-Dan price
1983 BJ42
1978 FJ40-Sold
1975 FJ40-Sold
Diesel42 is offline   Reply With Quote
Old 09-28-06, 10:08 AM   #13 (permalink)
dieseldan's Avatar
Great 24V Bulb Source..
Hey Guys, I used to work with an outfit who supplies virtually any lamp - locomotive, marine whathave-u
www.specialtybulb.com (Langley BC)
Not much of a website, but even if you have no part number, send them a fax sketch of the lamp and any #'s on it, they will have it or get it and at a reasonable price!
(how about a set of locomotive headlamps PAR56 24V - those will light up the sky)
HDJ81 lifted winched exhausted snorkeled diesel smoker - with a cup holder mod. Glow away.
M101-A1-CDN wood gatherer-upper.
dieseldan is offline   Reply With Quote
Old 10-01-06, 04:33 PM   #14 (permalink)
mikehj60's Avatar
TLCA# 17858
Out here in chilliwack I have had no luck getting 24V lights from lordco, but either Toyota or NAPA have everything in stock usually. And you can usually get a better deal at NAPA.
1982 BJ42
1986 HJ60 RIP
mikehj60 is offline   Reply With Quote
Old 06-27-07, 11:26 AM   #15 (permalink)
Where's mah cruzah?
polarweasel's Avatar
TLCA# 17558
In a BJ42:
Dual-filament bulbs (stop/tail): 1662
Single-filament bulbs (turn/reverse): 1683
NAPA numbers (both were in stock in Boulder, CO store this morning) are "LMP 1662" and 1683.
84 FJ60, locked and lifted and dismantled with Mercedes diesel
1982 BJ42 loud and slow daily driver on 33s
Horsetooth 4-Wheelers
polarweasel is offline   Reply With Quote
Old 11-02-09, 04:28 PM   #16 (permalink)
Rookie
24Volts Dashboard light bulbs for BJ 71
hi there!
I am in need of finding 24 Volts Light Bulbs for my BJ71, especifically for the dashboard (speedometer, gauges). Mine are brown and cordless. Not sure of their part numbers. Do you know them? I see that you had some part number for some, I wonder if they're the same.
pedroemillan is offline   Reply With Quote
Old 11-02-09, 05:14 PM   #17 (permalink)
mr. stupidyhead
Chang-kuao-lo's Avatar
TLCA# $1.69
^that's a wedge bulb. it should pull out of the plastic base-thingy. http://www.rallylights.com/detail.aspx?ID=2223
sorry, no part #s.
But for those in the US who are really stuck:
Susquehanna MotorSports - Auto Performance Products Catalog , and pretty much anything hella makes has a 24V version.
Now, in the future, the past has occurred.
be water...
1971 Pontiac LeMans
1984 YAM. XT600
1982 Hilux, 1L 2LT 3L(turbo)...
1983 BJ42
1985 BJ74 PTO winch (lawn ornament, thanks NHTSA )
1984 RZ350 (the yellow yahoo)
avatar
Chang-kuao-lo is offline   Reply With Quote
