engine mount location for 1hz into us spec fj-60?
what would the best way for me to determine the correct location for the engine mounts for the swap of 1hz into u.s. fj-60? Also drawing/specs for fabing the mounts would be great!!! Thanks.
bolt the engine to the tranny(i am assuming you are using a H55F) mount the assembly into the engine bay using the original tranny mounts. the height of the engine will be close to the same as the 2F and the distance from the engine to the frame will be the same or very close. the over all size of the 1HZ is close enough to the 2F to use it as a guide...
cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#3 | |
UC Webmaster
__________________ Hello. My name is VTCruiser and I am an addict. Project Overland Build - Updated 11/26/08 UpstateCruisers.net |
ditto as well. that's how i mounted my 13bt in. i used a combination of 2f and 3b mounts to make my mounts. i fabbed them in place based on where the engine was hanging. welded one side in, then the other. there would have been no easy way to fabricate anything before hand in my situation...
my .02 mike __________________ 1986 FJ60 - 13BT/H55F powered (BJ60T?) 1986 VW Turbo Diesel Jetta w/ straight veg. oil conversion 1992 Dodge Ram 250 - 5.9 diesel All running 100% Homebrewed Biodiesel made from waste oil and homepressed mustard seed oil.... |
thanks for the replys!! Mount pics would be greatly appreciated!
HZ-60 Engine Mounts
When I did mine, that is exactly what we did. Start at trani support and locate everything off that.
One word of warning - take a look at the vertical height of your engine location and if the stock fan set up will clear the lower frame bracket. My engine is about 2" lower and the stock fan will not fit. I'm thinking that I could have raised everything up 1-1.5" with a spacer on the trani-mount and raising the engine mounts before welding - and saved me money on an electric fan and possibly cooling issues (if my head gasket issue does not solve the problem). Used a 2f bracket on passenger side, FJ75 bracket on driver side (LHD). They ended up being mounted about 2-3" behind the stock FJ60 mounts and just a hair lower. Used a 2F motor mount on left and FJ80 on right. Bob Bancroft Bend, OR 1HZt60 |
#7 | |
Good to see you on Mud Bob, welcome...... I got luck, located the engine the same as the others, but I did raise the engine enought that the fan easily clears the cross memeber. The body was off the frame at the time, so it was pretty darn easy. __________________ Come and visit us in Duncan, BC www.raddcruisers.ca --> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included --> 12HT & H55F combos available - complete & running --> in stock and ready to go. |
Loans | Web Advertising | Hsbc | Mortgages | Mobile Phones |
