LinkBack (1) | Thread Tools | Display Modes |
#211 |
Yeah I actually got the "function" part of the clutch spork... it was the timing and chosen venue to post the picture that I was kind of unsure of. I too have some pretty red neck repairs under my belt. Mostly they utilize bailing wire combined with some of the surrounding vegetation.
G __________________ There is no such thing as a stupid question... just stupid people. |
#212 |
ingenious...
although i have yet to see a cruiser fork wear that bad, pretty smart bush repair. <of course you could have driven home not using the clutch, more challenging for sure> __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#213 |
That's a riot, I had my clutch fork wear right through and my slave cylinder poked through, so I took a Presta valve adapter from my bicycle tire stem and snugged it in the hole, fit perfectly and lasted for years until i came across a doner clutch fork.
The things you do on the trail to get you home.
#214 | |
__________________ VOODOO Engineering: Doing it first time with one clay doll, not four times with two. |
#215 |
IH8MUD Irregular
Dougal, awesome repair, but did you re-enforce the welds?
Awesome repair, and I'm sure no one's flatware is safe anymore. Welds and the areas around them fail with some regularity, so did you use any metal backing to ensure your repair stays solid?
__________________ TOBASH _ When all hope of logic and reasoning fail, just Take Out Back And Shoot in Head. It'll do wonders for your emotional well-being. Last edited by TOBASH; 07-24-08 at 08:38 PM. |
#216 | |
Enough zip-ties can fix almost anything.
#217 |
IH8MUD Irregular
It's amazing that I have thousands of dollars wrapped up in tools, yet a 3 cent zip-tie can often surpass all of them in utility.
Best, T __________________ TOBASH _ When all hope of logic and reasoning fail, just Take Out Back And Shoot in Head. It'll do wonders for your emotional well-being. |
#218 |
Flip original 3B exhaust manifold for turbo
i am planning to flip a 3B manifold to install a turbo, questions are as follow
1) I have a lebaron Chrysler 2.2 gas turbo. Is this turbo compariable since it has a carbon seal? 2) Do i have to enlarge the exhaust manifold to match the exhaust port on the head? 3) I have a vacuum pump attached to the alternator. a) Currently the engine supplies oil to the vacuum pump and returned the oil back to the filter housing.. do i run a tee on both of the feeder and scanvange lines , so the oil shares with the vacuum pump and turbo? b)If so, then i am afraid the hot returned oil from the turbo might flush the vaccum pump, will it happen since the turbo sits higher then the vaccum c) Finally, the heat from the turbo might radiated to the alternator, 4) Anyone please post some pictures of the flip 3b manifold turbo set up. Thank you
#219 |
I think that turbo has been used successfully by a few Mud members.
You can pull the oil from the alternator and I would drop the oil pan and weld in a return line. If you search a bit more you will see photos and well written articles on the turbo installations. Good luck,. Rob __________________ Come and visit us in Duncan, BC www.raddcruisers.ca --> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included --> 12HT & H55F combos available - complete & running --> in stock and ready to go. |
#220 |
i would not pull oil fromt he vacumm pump. a wasted vacumm pump is over $1500 to replace, run a 't' from the oil pressure guage and as Robbie suggests, drop the pan BUT make sure the return line is above the oil level...any restriction and you will have oil back up to the turbo... not good.
#221 |
Dear DDude
I know the D50 will drop in place perfectly, what sort of gasket do yo use in your set up and where do you find one? thank you |
#222 | |
Location: Campbell River BC on Vancouver Island in Canada on Earth
thanx
__________________ BJ60 TURBO 3B ,2 1/4" exaust pipe, Custom rear frame and 33x12.5/r15 Hankook Dynamic MT, bj74 springs frunt and rear, fixed 90% of body rust and painted metallic money green and truckbed liner. her name is "The Screaming Green Submarine" |
#223 |
Mod in Hibernation
aston, take your oil pressure off the oil passage along the block. behind the alternator is a plug in the block. It has good pressure at this point. A 1/8 BSP to 1/4 JIC fitting is needed. But it's like a buck or two and no tee's are needed.
Oil return must be double the size of the pressure line. half inch(.500) is needed. Return to the pan only. It is not a pressure return, more of a drain. So keep it unrestricted, no 90 degree angles. Max 45. I pulled my pan and welded a fitting on. Make sure before you weld where you want to put it. Too low its in the oil and won't drain. Also you don't want to be behind the filter. Also ensure your pan isn't too rusty prior to pulling it off and discovering it. Might be worth while to source a pan prior if this is the case. http://forum.ih8mud.com/diesel-tech-...ht=oil+pan+man http://forum.ih8mud.com/attachment.p...1&d=1151462960 for oil line __________________ -84 BJ60, Finally on the FN road! -91 FJ80, wife's ride Iron Butt award winner of the Cruise Moab 08 ! |
#224 | |
#225 | |
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/34599-turbo-position.html
| Turbo for the 3B - Options? - Pirate4x4.Com Bulletin Board | This thread | Refback | 08-10-08 12:41 AM | |
Loans | Debt Help | Millsberry Forum | Remortgaging | Bad Credit Mortgages |
