Home Forum Gallery CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > Diesel Tech and 24 volts Systems
Follow IH8MUD on Twitter Visit IH8MUD on Facebook
Old 12-11-09, 06:38 AM   #1
PHIL O's Avatar
our brakes
the brakes on the hdj81 is strong, but i have been observing the vacuum booster. repeated stomps on the brake pedal at panic stops feels like the booster runs out of vacuum on the second or third step. i was thinking of a vacuum leak but the dummy light doesnt indicate that. i was also wondering if vacuum is drawn back to the pump. do we need a check valve for the vacuum line? i dont see any chack valves on the hoses. any idea mudders?
1991 hdj81 auto tranny, 1hdt, factory lockers.
everything is stock. only the driver is modified
PHIL O is offline   Reply With Quote
Old 12-11-09, 10:16 AM   #2
Chang-kuao-lo's Avatar
Booster test:
With engine off, pump up the brake pedal untill it loses travel and gets "stiff". Hold it there and start the engine. if the pedal is slowly drawn in after the engine starts, your booster is working properly. Your rear brake self-adjusters might be stuck, and need a manual adjustment.
avatar
"have a crappy weekend, i hope your house burns down."
-carl brutananadilewski
Chang-kuao-lo is offline   Reply With Quote
Sponsor 12-11-09, 11:29 AM
Sponsored Link
advertisement
Old 12-11-09, 11:29 AM   #3
sandcruiser's Avatar
Garage
there is no check valve on the line from my vac pump to the booster
but I think that there should be
I also want to install a vacuum reservoir of some sort so that something fails on the vac pump, I've still got a little booster left. But it isn't a high priority.
91 j80 w/93 1HDT. OME 850+1"/860 & nchargers, LED domes, Full rack, HIRs, Pyro/Boost, -ACSD, Geolander MT's 33x12.50, Tuffy center, lightforce lights, body damage, Temp Gauge(M), OBA, ARB RR locker, blue fan, aux electric fan.
Now Selling Solar in CA, TX, AZ, OR, CO, MD, MA, NJ, PA, NY and DC. PM me!
sandcruiser is offline   Reply With Quote
Old 12-11-09, 12:21 PM   #4
cruiser_guy's Avatar
Location: Cranbrook, B.C., Canada/Mokanji, Sierra Leone, West Africa
Doesn't the '80 series have a vacuum reservoir like the '60 series diesels?
'82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, Warn 8274, Aussie rear locker, OEM LSD front, 4:11's, 32's, long range tank, rust FREE!!!
'67 FJ45LV c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! In progress!
www.wirrell.com
Old 12-11-09, 02:43 PM   #5
Garage
probably it should have a reservoir, but mine is a swapped-in motor and there are a variety of bits that aren't necessarily as they "should" be.
Old 12-11-09, 03:09 PM   #6
Gotcha! I didn't forget that little tidbit with the '55 swap.
Was your swap done in Costa Rica? If so, I can imagine there are probably a few other things that didn't make it either.
www.wirrell.com
Old 12-11-09, 03:21 PM   #7
Enigma's Avatar
Garage
Originally Posted by PHIL O View Post
the brakes on the hdj81 is strong, ?
This is the first time I've heard anyone voice that opinion, the general consensus seems to be they are mediocre at best.
Jeff S. * Coastal Cruisers * TLCA #8042
1990 HDJ81 with 'CruisinOffRoad armour, ATEB 3" exhaust, and factory fridge!
The semi retired/waiting for attention fleet: '74 fj40, '82 fj45, '71 fj55
And all the latest Land Cruising Youtube action.
SPOT GPS Tracking
Enigma is offline   Reply With Quote
Old 12-12-09, 06:06 AM   #8
PHIL O's Avatar
i say strong because i could throw my passenger to the windshield when i stomp on the brakes. but a series of pedal pumping (less than a second of an interval) almost makes it feel that the vacuum is not sufficiently replenished by the pump. i checked for booster vacuum leak, but turned out negative. my 80 has that vacuum reservoir. they say it is good for 6 pedal pumps before it runs out. could adding a check valve solve this? where should it be placed? in between vacuum pump and vacuum reservoir or between vacuum reservoir and booster?by the way, the brakes work great on single pedal pumps. did a 100% brake job recently
(changed rusted pistons, rebuilt caliper with oem kit, have oem pads, also opened LSPV for maintenance, adjusted LSPV rod height on axle end. also repadded the shoe of ebrakes...7 clicks and it hold rig on incline...no automatic adjusters on this since it is rear discs)
thanks for sharing your ideas fellow mudders
Old 12-12-09, 06:16 AM   #9
PHIL O's Avatar
by the way, it makes me wonder why our diesel rigs don't have a check valve on our brakes system. doesnt the pump draw in vacuum sometimes? is there a maintenance that mudders do on this pump? i dont know if the gassers have their vacuum drawn from the intake.
Old 12-12-09, 03:48 PM
Sponsored Link
advertisement
Old 12-12-09, 03:48 PM   #10
Did you put on a vacuum guage and check that the pump is giving specified vacuum? The root of your problem might be the pump itself, the vanes wear out but the rebuild kit is relatively inexpensive.
avatar
Trackbacks are Off
Pingbacks are Off
vBulletin® ©2000 - 2012, Jelsoft Enterprises Ltd.
©2000-2012 by IH8MUD.com - ALL RIGHTS RESERVED
