Old 02-01-05, 06:45 AM   #1
David*BJ70's Avatar
TLCA# 15514
60 and BJ70 part compatibility
Hello, in the manual of repair, all the parts seem the same ones, which are it really?
Disc rotor and brakes pads?
Caliper ?
Drum and brakes pads ?
Alternator ?
Shocks ?
Shackles and springs bushings ?
Wheels clearance ?
Damper shock ?
Brake master ?
Clutch ?
Clutch slave ?
and the biggest question... the T-Case ?
...and, what other part ?
Not a lot of strore (NAPA, Canadian Tire, ...) selling 70 part... so I need to figure if I can buy some parts for a 70 like a 60 ?
BJ42 1982 * The Primitive Beast - wvo
BJ70 1985 * The Green Machine - wvo some say The Mighty Pickle ! come on !
1992*Corolla*All-trac* The Quiet Spirit
Si je dois aller en enfer... ce sera en Landcruiser
(Canadian french guy (Québécois)... sorry for my english ! )
David*BJ70 is offline   Reply With Quote
Old 02-01-05, 11:36 AM   #2
wesintl's Avatar
TLCA# 4180
Caliper ?
Alternator ?
Shocks ?
Wheels clearance ?
Damper shock ?
Brake master ?
Clutch ?
Clutch slave ?
For the most part a bj60 and bj70 will have the same running gear except for axle shafts, drive shafts, body parts, etc. HJ60 would have much less in common with a 70 but brakes xfer depending on year, etc will still be the same.
I've seen 60 and 70 shocks listed as the same and then companys like OME will have different shocks listed due to load. But they are of the same fittings. Some items like a brake master for that will even cross over to a 4runner.
I believe all the items you have above are the same between a bj60 and bj70 of the same vintage.
HTH
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Old 02-01-05, 12:04 PM   #3
lowenbrau's Avatar
TLCA# 5513
The list you have are interchangable with a few exceptions.
Watch the voltage. all cdn spec BJ60s are 12v. Only '85 BJ70s are 12V . '86 and '87 are 24V
Shackles and bushings are interchangable but the rear fixed pins are unique to the 70 series.
Clutch slave is the same as a '84 or '85 BJ60 or '86 or '87 HJ60 but not earlier. BJ70s have vacuum assist.
The t-case from a '83 or '84 BJ60 is the same as a '85 BJ70
The t-case in a '86 or '87 BJ70 is unique in Canada but can be replaced (downgraded) with one from an '83 or '84 BJ60.
The internals and back half of a '86 or '87 HJ60 case will be the same as a '86 or '87 BJ70
Rocky Mountain Land Cruiser Association TLCA # 5513
'87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn
I support our Troopies
lowenbrau is offline   Reply With Quote
Old 02-01-05, 02:34 PM   #4
David*BJ70's Avatar
TLCA# 15514
I forgot this specification.
I have an extre T-Case from a BJ60 1982 (4 speeds) Can it fit in the 1985 BJ70 ?
And thank for the others informations
Old 02-03-05, 12:47 PM   #5
lowenbrau's Avatar
TLCA# 5513
Yes
You have to use the front half from the 70 but if you swap the early gears (from the 60) into your case you'll have a lower low range.
Old 02-27-05, 03:51 PM   #6
David*BJ70's Avatar
TLCA# 15514
Originally Posted by lowenbrau
Yes
... lower low range. How can I figure that... now I have 3.70 ... so can that could be something like 4.11 or 4.?? ... ??
Old 02-27-05, 07:19 PM   #7
beanz2's Avatar
Bruce was talking about the transfer case gears. Yours is 1.99 low range, he was referring to the 2.29 ratio.
Supposedly there is a 6.1 R&P set that fits the cruiser diff. Off a Toyota Stout or something.
Dave
beanz2 is offline   Reply With Quote
Old 02-28-05, 06:41 AM   #8
David*BJ70's Avatar
TLCA# 15514
Dave
I know he was talking about T-Case gears... but my question was not realy clear anyway. (You know... it's french in my head ! )I'm juste try to figure what this difference can make on my drive train.
So I will make my question different :
If I put the front half from a 1982 T-case in my actual 1985 T-case I will be able to put bigger (33-35) without stress my drive train... not like running 35 on a 3.70 ratio. Hope it's more clear now ...
(I don't realy whant to make this ... just for the information);
Old 02-28-05, 09:33 AM   #9
beanz2's Avatar
I'm not really sure what the older front t-case half will do really. Nor would it help anything in high range. What's more, if your BJ70 is 10/85 or older, the idler shaft would be incompatible with the '82 front half. If you are running larger tires, you can consider running Marks4WD's 1.08/3.08 transfer gears, or cheaper, go for higher diff ratios.
Dave
Old 02-28-05, 10:20 AM   #10
crushers's Avatar
actually the lower gears do make a big difference.
if you work out the numbers by switching the gears in the case you end up with the same result (in low range) as putting 4.88 gears in the 3rd member...
this does make turning 35" tires effortless when going down the trail...
on the highway it makes no difference at all since it is still 1-1 high...
from what i have seen of Marks gears, they scream like a banshee at highway speeds and unless you are into rock crawling they are over kill for the average trail....
cheers
Wayne in Ontario
Old 02-28-05, 10:29 AM   #11
lumpy70's Avatar
Originally Posted by crushers
from what i have seen of Marks gears, they scream like a banshee at highway speeds...
From what I've heard, the 1st generation of Mark's gears were non-helical cut so it whined like you were going in reverse, except at 100 kph it's pretty loud.
However, now I've heard that they are making them in a helical cut gear so they are as quiet as any other gear....so I've heard.
I think Greg B has a set, maybe he could comment further on the noise level.
Craig.
Sadly no longer owning a 70
1993 HDJ81
TLCA # 13682
lumpy70 is offline   Reply With Quote
Old 02-28-05, 11:50 AM   #12
lowenbrau's Avatar
TLCA# 5513
Dave
I think Dave meant 10/85 or *newer*
You don't want to use the four speed (82) front case half on the back of your five speed tranny.
Your '85 t-case front will mate up fine with the 82 gears and rear case half. Its a pretty easy job. I can't remember for sure but I think the companion flanges changed in that period so you'll have to swap the rear one from the old case if you use the rear t-case half. As Wayne said the differnence between 1.99 and 2.27 is significant.
Old 02-28-05, 11:58 AM   #13
David*BJ70's Avatar
TLCA# 15514
OK thank. So it's a kind of a good thing ?! I will keep this precious information until the time of actual T-Case died.
Old 02-28-05, 12:14 PM   #14
Greg_B's Avatar
TLCA# 7091
Craig.
I believe I ended up with an older set. They have quieted down around town, however on the freeway they are noticable.
gb
Greg_B is online now   Reply With Quote
Old 03-01-05, 09:41 PM   #15
beanz2's Avatar
Thanks for the correction, yes, I meant 10/85 and newer. But as I also said, the 2.29 low range gear would not "help anything in high range".
I have the 1.08/3.08 Marks4WD gears in my 40, the difference in high range is noticeable in the hills. Before I could not keep 55 mph in 5th gear going up certain hills around my house (NV4500, Chevy 350, 37"), now I can accelerate to 60-62 mph.
Dave
Old 04-29-05, 06:54 AM   #16
David*BJ70's Avatar
TLCA# 15514
Question
HTH
The BJ70 brake master are the same as the 4Runner ? I think my master slowly get worn...
What 4runner year ?
Is it the same part # at Toyota ? And NAPA ?
Thank for help.
Bye
Watch One Piece | Problem Mortgage | Books | Mortgages | Cheap Loan
