Old 11-06-09, 11:07 AM   #1 (permalink)
ohrly?'s Avatar
Turbo 'B' Build - Head Removed
So I'm doing up my turbo B.
I have two exhaust studs broken off in the back of the head (non-protruding)
Pulled the head off, looks really good - veryyy mucky inside - I'm probably getting really poor head cooling.
Should I have my valves and seats ground out?
-Hopefully I will post some pictures.
-24 volt 1980 BJ40.
-Five 24 Volt Hobbs heavy duty equipment lights.
-32x11.5 GWrench AT's.
ohrly? is offline   Reply With Quote
Old 11-06-09, 06:05 PM   #2 (permalink)
I'm doing the same thing... A B engine turbo. I rebuild my engine, oversize piston and ring, rebuilded head with new valves, seal...., ... ,.... A complet rebuild of the engine an a turbo that I'm working on todays and will normaly end next weekend for the first try.
for your question.. if you normaly rebuild your head... I will tell you to rebuild it before and test the engine compression. A bad engine with a turbo is not a good Idea.
Owner of a bj40 1979 with rebuild B 3.0L engine
FJ40 1975 4.2 double Baril
Wedg3 is offline   Reply With Quote
Old 11-07-09, 11:30 AM   #3 (permalink)
JoeCanadian's Avatar
Location: Campbell River BC on Vancouver Island in Canada on Earth
The head looked really good, no cracks between the pistons - a couple of barely visible cracks stemming at the precup and running no more than 2 cm toward the cylinder.
Reinstalled the head, torqued it to 400 ft-lbs to make sure it will never leak. (just kidding)
Turbo manifold is completed, oil pan is off and ready to be fitted with oil return female end.
Still lots more work to go.
BJ60 TURBO 3B ,2 1/4" exhaust pipe, Custom rear frame and 35/10.5/R16 TSL Boggers, bj74 springs front and rear, fixed 90% of body rust and painted metallic money green and truck bed liner. her name is "The Screaming Green Submarine"
JoeCanadian is offline   Reply With Quote
Old 11-07-09, 11:30 AM   #4 (permalink)
god damnit.
Above post is me, myself, in the flesh, Ohrly?
Old 11-09-09, 01:06 PM   #5 (permalink)
ohrly?'s Avatar
Photos of the finished, well somewhat finished, turbo.
Missed out on some good head pics, and filthy me pictures.
-24 volt 1980 BJ40.
Old 11-09-09, 06:03 PM   #6 (permalink)
ohrly?'s Avatar
so now my engine is missing at high rpm, no power whatsoever
my tank was full of water, and ive never run a fuel water seperator, had lots of water in my brand new filter, truck was stalling out before I started the job...
Sounds like my pump is done.
-24 volt 1980 BJ40.
Old 11-10-09, 05:05 PM   #7 (permalink)
wheelinwarren's Avatar
it may just be your lift pump I belive it works with your primer which is already screwed
85 bj60 600,000k 3b turbo biodiesel since 05 daily driver
85 bj60 320,000k under renovations
85 bj60 250,000k donor (rusted out frame)56 bucks at the scrapyard
84 toy 4x4 diesel, grease hauler -sold
88 bj62 under restoration
wheelinwarren is online now   Reply With Quote
Old 11-10-09, 05:11 PM   #8 (permalink)
ohrly?'s Avatar
So, should I just get a new primer, or am I fucked?
-24 volt 1980 BJ40.
Old 11-10-09, 07:25 PM   #9 (permalink)
just steal the one off les's engine
