Old 01-25-05, 11:17 AM   #1
Injector Service
I've doen 86000 miles in my HJ60 and am wondering about servicing the injectors. How often / when sould this be done? What is involved? What benefits am I likely to see from getting the job done? Is there anything that should be done to the injector pump?
Jim
1979 BJ40 - Now in Morocco
1989 HJ62 - Now in Pieces
The journey of a thousand miles begins with a broken fan belt and a leaky tire
Jim_Phillips is offline   Reply With Quote
Old 01-25-05, 11:49 AM   #2
Greg_B's Avatar
TLCA# 7091
There is an excellent article in #56 Aug 2003 of the Oz 4WD Monthly, if you have access or collect. Recommendations are 100,000 for a service with IDI nozzles and 150,000kms for DI nozzles. Recommendations for rotary pump service is 250,000 to 300,000 kms (though much depends on service issues/filtration etc), and no mention of inline pump service that I saw. Article focused on filtration as the biggest thing you can do for your pump and injectors, (water and particulate handling).
Direct quote...talking IDI nozzles here: "As the injector wears, the pressure it sprays at drops, until eventually it dribbles the fuel out rather then squirting it. The result is poor atomization of fuel, which is then forced to burn closer to the injector, causing the nozzle to overheat and melt away. The extra heat generated weakens the spring's tension compounding the problem. Usually the performance drop off is so slow that drivers don't notice...."
Talking with local injection shops I have learned that DI nozzles do not take the beating IDI ones do, so in many instances the nozzles can be sonic cleaned, checked and if okay put back together, and shimmed to crack at factory specs. IDI nozzles on the other hand usually need to be changed out, and shimmed.
Benefits would be knowing your injectors are healthy, and working correctly, meaning better use of the fuel.
Many injection shops will take your used nozzles to the test bench and show you the spray pattern and crack open pressure. Use the FSM to guide you through the removal and installation process. A deep socket will work to take out your old injectors.
hth's
gb
Greg_B is online now   Reply With Quote
Old 01-25-05, 12:03 PM   #3
wesintl's Avatar
TLCA# 4180
Some shops will test for no charge others will roll it into a rebuild if needed. If not it's something like 1/2 hr labor. I would just pull them and have them tested. That's what I did just recently
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Old 01-25-05, 03:33 PM   #4
smcruisin's Avatar
I suppose if you're paying for new injectors (nozzles and injector body), and they'll bench-test your old ones for you, you get a set of spares (assuming they're still close to spec) to put in your tool box. As reliable as our diesels are, I still find comfort in knowing that I can either fix or bypass any problem encountered far from the nearest Toyota parts dealer.
The Turbocharger: a replacement for displacement
estimated time to complete a truck project X 3 + 1 year = actual time required to complete said truck project...
'81 BJ-42 restoration nearing completion
smcruisin is offline   Reply With Quote
The eBay Song | Reggaeton Videos | Refinance | Debt Consolidation | Mortgages
