3b Rebuild. Cost?
Looking to get an idea of parts availability and rebuild prices on the 3b (total rebuild) and or a used 3b motor.
Thanks. Juke __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
Greg B.'s got a rebuilt never-fired 3B and tranny combo up for sale. He also has a new AXT turbo, new in box and complete kit, for sale.
__________________ Stone's Land Cruiser & Flyfishing Pics Flyfishing British Columbia: www.flyfishbc.com bcfishingreports.com |
Plan on $3500CAD for a complete rebuild. new water pump, fluids, injectors, machining etc.
I did one a few years back and was right around 3300. My brother did one this summer and hit 3800.... A used 13B-T might of been a better choice for him. __________________ Brad T 88 HJ61 "Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs... 78 BJ 40/42/60 |
You can buy a complete rebuild kit from 4wheelauto.com out of Edmonton Alta for $ 1350.00. Get the head shaved and valves done and new injector nozzels. If you do it your self should be less than 2000.00. Cheaper than a small block Chev.
waaz |
yup, then add new OEM head gasket, oil pump rebuild, thermostat, etc... There is NO way I could do a complete rebuild for $2000CAD
you can get the same rebuild kit out of Goeff Walsh in Oz for about $900CAD landed at your door (the last time I got one) __________________ Brad T 88 HJ61 "Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs... 78 BJ 40/42/60 |
Dude:
Was Geoff's kit of good quality? __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
Yes, except for the head gasket. Go with OEM. I also purchased a high nickle head from them complete with precups. It was a while ago but I think it was just over $1000.
I am sure it is close to the kit from 4 wheel auto (if not the same) __________________ Brad T 88 HJ61 "Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs... 78 BJ 40/42/60 |
The whole kit plus the head for 1000.00 can?
Did you do the teardown your self? Is this a complete rebuild or top end only? __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
Dude:
I was quoted 2380.00 us (labor only) by a reputable diesel shop here in town. GW's kit is about 750.00 US according to your quote so, that matches about right with the 3800.00 Can. Are the 3b's sleeved or non sleeved cylinders? Is it necessary to remove the engine for cylinder work? __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
#10 |
They are sleeved and I have only ever worked on the engine out of the truck. For me that was about the easiest part of the job. On a 60 we can do it in a couple of hours. On a 42 even quicker.
Nope, just the the head was0010 Itkemaits w alehoot las er.ie I n'dotht k inu youlcoged tht e oseesls vet ou tin theckru I. av hale yswaef ltht uattop he tac mnehiho s p.atThnd ahe tam cha s bftrieas ngan( mad inchg in cofrsou. e)ve Ethryg inseele wd dirsouveel..s. iItres lyalas eify ou yav hthe FSe anM a d odgoor te quenwr. ch I on d t'tnkhi w Ildouay pha tmut ichjun lstouab r.y Bue tholtoans dod t iuryolfsef iu yovehaim t e __________________ Brad T 88 HJ61 "Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs... 78 BJ 40/42/60 |
#11 | |
TLCA# 16387
My personal preference would be a 5 bearing cam and sleeved block ('85 - '86 or so). I concur with the rebuild costs quoted above if you do the actual assembly. __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
#12 |
I did a rebuild last year. I did all of the work myself (with friends helping) except for machining. Total cost; $3200 Cdn.
Machining: $770 Rebuild kit from Australia: $840 to my door (yes, it's the exact same as 4 wheel auto) Pre-cups: $430 Fluids: $100 Injectors: $160 Extra Toyota OEM parts: $945 The extra Toyota parts are: Head Gasket Front & Rear Main Seal Oil Pump Gears Oil Pump Relief Valve and Spring Thermostat w/ gasket Oil Cooler Gasket Clutch Pressure Plate Clutch Bearings Injector Gaskets & seats Unless you have a machine shop, or elect not to do replace any of the above parts you can't do it any cheaper. I got a deal on machining and a deal on the Toyota parts. I am very happy with the results. I went from 18 mpg to 26-30 mpg and WAY more power...relatively speaking (it IS a Landcruiser afterall). Now with 20K under it's belt, the turbo will be going on hopefully by Easter. My only advice would be to turbo it while the engine is out, WAY EASIER. HTH, Craig. __________________ Sadly no longer owning a 70 1993 HDJ81 TLCA # 13682 |
#13 |
I buy my rebuild kits from another manufacturer in Austrailia name of Engine Australia.
The kits seem to be of a higher quality than the G Walsh kits IMOP. __________________ Come and visit us in Duncan, BC www.raddcruisers.ca --> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included --> 12HT & H55F combos available - complete & running --> in stock and ready to go. |
#14 |
Lumpy, how many km's on the old engine before rebuild?
__________________ MOOSE SOLD HER - SOMEDAY SOON JDM's...THEY SAVED THE BEST FOR THEMSELVES!! |
#15 | |
__________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#16 |
I got the truck at 386,000 kms, and had it rebuilt at 394,000 kms. Old compression was 300, 290, 290, 280 lbs. When we broke the engine down we figured it was a long life of cold starts, possibly poor oil changing maintenance, and extended periods of idling which had glazed the cylindar walls. Now I'm at 420 lbs across the board and I'm told it's still breaking in. Craig. __________________ Sadly no longer owning a 70 1993 HDJ81 TLCA # 13682 |
#17 |
Lumpy:
Have any part numbers on those Toyota parts? Thanks guys for the info. I have rebuilt a couple of engines but I do not do machining nor have I ever worked with a diesel. I am mechanically inclined and have a lot of patience so I find that takes a great way into getting these done in a vehicle. Just curious, for those that have rebuilt petrols, which rebuild is easier? Same? The machine shop put it at 35 hours of labor to do the rebuild. Sound right? I would pull the engine because, well, that is the only way in my opinion. Thanks fellows. __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
#18 |
Jukelemon, where are you located? I could dig up the part numbers if you really needed them, but any Toyota dealer in Canada can get those parts.
I am also mechanically inclined but had never rebuilt an engine. I was amazed at the simplicity of the 3B. With the Field Service Manual and a couple of friends who pointed me in the right direction at times, it was remarkably easy. As for machining, 35 hours is crazy. Looking at my receipt, I got mine done in 18 hours. Try to find a shop that has done one before as the machinist's familiarity made it cheaper and gave me piece of mind. He also might want some photocopied pages from the FSM for torque speques and the like for reference (my guy wanted the torque specs for the rods for example, and had forgotten the exact number). Craig. __________________ Sadly no longer owning a 70 1993 HDJ81 TLCA # 13682 |
#19 |
This is all coming in pretty close to the rought guide of $1000.00 cdn per hole for a deep rebuild.
gb |
Loans | Pacotes Porto Seguro | Secured Loans | Loans | Comcast |
