Old 01-20-05, 05:06 PM   #1
Greg_B's Avatar
TLCA# 7091
Pusher Fuel Pump - Walbro
There has been discussion about pusher pumps lately for our diesel rigs. I am looking at putting one on a truck, and started researching. I found the following information, and wonder if anyone else has read the same, talked with any Walbo techs, or practices what is being recommeded (filter in front of the pusher pump).
I do understand the current generation of Walbro filters do have a filter built in, on the inlet side, and wonder if this is simply dated information.
Here is a link to the 6000 series pumps:
http://www.autoperformanceengineerin...6000_pump.html The diesel pump has a 420 micron filter, which as quite large. Indicates to me one would be fine putting the filters after the pump, as the pump would be built to handle anything under that size with no damage.
This is pulled of a Sami Diesel list.
gb
QUOTE
There has been some interest on the list in using a diesel fuel pump to prime the fuel system after changing filters. One suggestion has been to use the pump in a "flow thorough" configuration. The general fuel flow scheme was from tank to pump to filters to engine. In this arrangement, the pump would not run except when filling the filters or in emergency conditions. This concept requires that the fuel flows through the pump
with little pressure drop when its motor isn't running.
The notion of pulling unfiltered fuel through a non-running pump bothered me, but I had no data to support my concern. The pump generally thought of in this configuration is made by Walbro. To get to the heart of the matter, I had a long discussion with the Walbro Engineering Department. The results of that discussion are listed below:
PUMP FACTS
1. The Walbro pump is intended for continuous service and its service life should exceed 10,000 hours. It contains an inlet and an outlet valve. The valves are opened and closed by the action of a piston moving up and down in a cylinder in the motor. The valves are kept closed by springs. Other than the valves, springs, and piston, there are no moving parts in the pump. All in all, it is a very well made and long lasting pump.
2. If fuel flows through the pump while the pump motor is not operating, there will be a pressure drop across the pump caused by the energy necessary to keep the valves open. The pump IS NOT approved for such operation. Since it is not approved for such operation, the pressure drop across the pump has not been measured in that mode. It is expected that the pressure drop when operating in that mode will be different at different times in a random fashion by any number of factors which could affect the position of the valves.
3. Any debris getting under either valve would cause the pump to stop pumping any fuel at all. To protect against this problem, a 30-micron screen is installed in the inlet of the pump. In the marine pump, it can only be cleaned by partially taking the pump apart. Any debris caught by the screen will increase the vacuum across the pump (and system if the pump is not running). Note that the 30-micron screen is the same micron level as used in many Racor filters. Any debris passing the screen can cause the valves not to work and might damage them. The pump IS NOT approved to operate without a filter on its inlet side. If the pump is operated without such a filter, the WARRANTY IS VOIDED.
______________________________________________
CONCLUSIONS
1. Protecting the pump with a filter is mandated by this pump manufacturer, but it is often necessary, and generally good practice, to protect any pump with a filter on its inlet side. Not protecting any pump in this way should be done only with great care.
2. The Walbro pump can still be used to prime filters when it is installed on the engine side of the filter(s).
3. Unless the pump is used as a fuel pump all the time, it should have a bypass around it so that fuel will not flow through the pump when the pump is not running.
4. Unless the bypass around the injection pump can't handle the 7-psi maximum pressure of the Walbro, there is no reason that it can't runcontinuously as a fuel pump in cooperation with the normal engine-mounted lift pump. In this configuration, a bypass around the Walbro could still be of benefit.
__________________________________________________ __
From the conclusions, you can see that there are many configurations possible in the diesel piping. The object is to make sure that the installed piping really does what you want it to do. One of the most important factors in doing that is to get the requirements of the equipment from the manufacturer.
END QUOTE
Old 01-20-05, 05:23 PM   #2
lowenbrau's Avatar
TLCA# 5513
I wonder how this ( or any) electric pump will work in a 13bt or 3b rotary or any other application that spills the excess fuel to the tank? You will never build any significant pressure but that isn't an issue for the intended purpose as far as I can tell. The pump with just run at full flow all the time and recirculate your fuel over and over.
In a closed system like an inline 3B the pump will run up against a wall and keep pressure against your lift pump. I wonder how the seals will like that? I'm not sure its been done before. I think Mike McT does it on his HZJ75 but, again, its an open to the tank system.
Somebody should try it out and see.
Rocky Mountain Land Cruiser Association TLCA # 5513
'87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn
I support our Troopies
lowenbrau is offline   Reply With Quote
Old 01-20-05, 06:10 PM   #3
Greg_B's Avatar
TLCA# 7091
Mike Forbes (aka Stickboy) has a Walbro pushing the fuel on his 13BT powered FJ60. He has a number of filters in front that would lower the pressure.
Lots more reading here, that talks a little about the in-line and VE style rotory injection pumps, but not the question you raise Bruce; return line VS no return line. http://www.a1.nl/phomepag/markerink/...-lift-pump.txt
Old 01-21-05, 12:58 AM   #4
Stickboy's Avatar
Hi Greg/Bruce,
well this is interesting. my walbro crapped out. i think it's totally unrelated and am dealing with a warranty issue but non technically speaking my observations are:
1- without the walbro, no pump filter can go between the fuel feed pump and the tank.
2 - the walbro has relief that once it hits it wall (10psi rated) it'll shut down
3 - i have a pressure gauge on the Racor 645 (2 micron) before it goes into the IP, it has never read over 8 psi. i've done this under full throttle but never under a significant load (acrobatics required for that one....)
4- i checked the 420 micron filter after several thousand miles, clean as a whistle
5- i have no filter before the pump - no, no I guess
6- i've run about 1000 miles without a pump now flowing through it, no running problems, i don't know what's happening to the pump though
7- i guess i should put a bypass in
8- the pump runs intermittently, when it first crapped out i couldn't figure it out. there were 24v at the pump, everything seemed in order. i removed the inlet hose, nothing, i loosened the outlet hoseclamp a bit and...walla... i was covered in diesel, face and all..... it worked fine for about 2 mos.
9- i have power switched to the walbro and occasionally i kick it on and about 50% of the time it'll function.
honestly i have no idea. i've called advanced engineering and have played so much phone tag it's funny....
does anyone have contact info for Walbro direct?
my .02
1986 FJ60 - 13BT/H55F powered (BJ60T?)
1986 VW Turbo Diesel Jetta w/ straight veg. oil conversion
1992 Dodge Ram 250 - 5.9 diesel
All running 100% Homebrewed Biodiesel made from waste oil and homepressed mustard seed oil....
Stickboy is offline   Reply With Quote
Old 01-21-05, 05:20 PM   #5
Stickboy's Avatar
Greg/Bruce,
have you guys read this discussion...
-mike
Old 01-21-05, 10:40 PM   #6
lowenbrau's Avatar
TLCA# 5513
Interesting stuff. If the pump is happy cycling on/off in the inline 3B application it might be the right thing to do. On second thought maybe I should run a return line to the tank. It has benefits. The fuel warmes up, the injection pump runs cooler, and the fuel gets filtered over and over.
Old 01-22-05, 12:36 AM   #7
Island Moose's Avatar
Stickboy...sounds like a bad ground? Have you run the negative on the pump to a clean piece of frame?
MOOSE
SOLD HER - SOMEDAY SOON
JDM's...THEY SAVED THE BEST FOR THEMSELVES!!
Island Moose is offline   Reply With Quote
Old 01-22-05, 01:06 AM   #8
Stickboy's Avatar
yep clean fresh ground piece of metal with even a second 10g wire going to a bolt into fresh metal. i cannot make it act like a bad ground.... that was my first thought....
electrically i can't find any problems...
-mike
Old 01-22-05, 08:36 AM   #9
The addition of a pusher pump in series with the lift pump seems to be a relatively simple performance enhancer. I guess that is because of an increased fuel supply to the injectors at a higher pressure. Many diesels have an inherent weakness in that they operate with negative pressure and can ingest air especially though junctions etc, a pusher pump should negate this problem as the system may be operating under positive pressure or at the least, less negative pressure. When out of fuel the system can be recharged and bled more easily after re filling the tank.
Has any one measured the increase in fuel pressure and quantity?
Are the performance gains subjective, or are they measurable?
Would adjusting the injection pump to increase fuelling have the same effect?
Would fitting a pusher pump with a higher delivery pressure and flow rate have an even greater effect on performance?
Is there another type of pump that would accept not having a pre filter?
Some I have spoken to suggest that there is increased efficiency and this leads to better fuel consumption is this so?
1994 HDJ80 1HD - T Lockers CDL switch & 7pin mod 100 Front Pads Nato Pint Swivle Tow Hook
Gold Finger is offline   Reply With Quote
Old 01-22-05, 10:16 AM   #10
The Dude's Avatar
TLCA# 8113
I like the simplistity and availability of the AC delco unit that is used on the 6.2s and the 6.5s. A lot of guys are using these on their Duramaxs' (me included)
You could make a simply "loop" with a valve to regulate pressure to the injetor pump. All you would need is 1-2lbs of pressure at WOT.
A simply vaccum/pressure gauge could be used to see if the relief is set properly.
Brad T
88 HJ61 "Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs...
78 BJ 40/42/60
The Dude is offline   Reply With Quote
Old 01-22-05, 10:53 AM   #11
crushers's Avatar
that looks a lot like the one i installed in the LJ71...
mind you they all probably look the same...
it did make a noticable difference in the power...
Wayne in Ontario
Old 01-22-05, 11:24 AM   #12
Greg_B's Avatar
TLCA# 7091
Hi Dude.
Is the AC Delco one a rotory vane style or piston style (concern brought up in the link above about the rotory style emulsifying any water in the fuel and not allowing the sedimenter to do it's thing)
Old 01-22-05, 11:56 AM   #13
The Dude's Avatar
TLCA# 8113
It is a rotary vane style. If it fails, you can not "suck" diesel through it. I would not be too concerned about the pump emulsifying(which it doesn't really do, it just puts it into solution) the water. Run an emulsifying additive that encapulates the water( it actually changes the chemistry of the h2o) and you have no issues.
Brad T
78 BJ 40/42/60
Old 01-22-05, 01:21 PM   #14
Greg_B's Avatar
TLCA# 7091
Good clarification of words Dude, thanks. I use Howes in every tank on every truck, which is an emulsifier. That said, I have pulled some ugly looking crap out of the sedimenter of the BJ60 the last few weeks. I wonder if a vane type pump would have put this ugly crap into solution, not allowing the sedimenter to do it's thing.
gb
Car Loan | Mortgage Calculator | Mobile Phones | Free Ringtone | Loans
