Old 01-16-05, 05:04 PM   #1
coldtaco's Avatar
answer me this - cold question
Ok, I got a BJ70 with 13B-T. I have a second water temp gauge that is pretty accurate. Now, when it's like below -25C and I am idling the engine at around 1100rpm, I show a water temp of about 130F. Then when I start driving, the temp goes down. Why? Also, I have the radiator totally blocked off, the grill covered, and beneathe the engine covered from just behind the radiator to the transfer case mount. I know that the bottom engine cover does not prevent any cold from getting into the engine area, but it should help to reduce any wind chill and alot of cold air to come up around the engine while driving. What would be symptoms of the thermostat stuck open and closed?
coldtaco is offline   Reply With Quote
Old 01-16-05, 06:27 PM   #2
sounds like you need a new thermostat , buy a new OEM part . You should also have poor output from your heater if this is the case .
Daryl
74 fj/bj40
88 fj/bj62 , full OME lift kit , home brew turbo , 4 runner brakes .
fjbj40 is online now   Reply With Quote
Old 01-16-05, 09:42 PM   #3
Stone's Avatar
TLCA# 13772
Stuck open would be my guess. Don't quote me on this...but I think when I bought a thermostat from Toyota recently, they gave me a choice of a regular one or one with a higher temp rating.
I find it strange that your is stuck open as I believe Sheldon replaced the thermostate recently when he put in a new water pump on your engine. ?
Stone's Land Cruiser & Flyfishing Pics
Flyfishing British Columbia: www.flyfishbc.com bcfishingreports.com
Stone is offline   Reply With Quote
Old 01-16-05, 10:04 PM   #4
crushers's Avatar
hummm, as far as i know there is only one part number for the thermostate for 3Bs
Wayne in Ontario
Old 01-16-05, 11:44 PM   #5
Stone's Avatar
TLCA# 13772
I'll check it out tomorrow, Wayne...maybe I'm mixing it up with another place...
Wayne: Looked it up at NAPA online for now. According to their online catalogue, they have two thermostat choices listed for the 3B...a standard 180 degree model and a 192 degree model. Their website is www.napaonline.com, and the part number is BA 1430678 for the 192 degree model. Maybe I had priced out an aftermarket one before buying the Toyota OEM, but I'll call JP tomorrow and confirm/deny the existence of an OEM 192 degree thermostat. Cheers.
Old 01-17-05, 12:48 AM   #6
s79bj40's Avatar
for whatever thermostat you get you might try boiling it up before putting it in. I got a ginuwine toyota one from the local parts place, (they are cheaper than the aftermarket ones anyway) and it stuck closed on the first run, nearly cooked my engine (again). Stuck the old one back in and its still going great guns.
'83Hj47 4.0Id ToyHino
'79Bj40 3.0Id ToyHatsu
'02STGU 4.2Id-T Patrol
s79bj40 is offline   Reply With Quote
Old 01-17-05, 11:16 AM   #7
Island Moose's Avatar
Ditto on the thermostat, also check the connections on your water temp gauge.
MOOSE
SOLD HER - SOMEDAY SOON
JDM's...THEY SAVED THE BEST FOR THEMSELVES!!
Island Moose is offline   Reply With Quote
Old 01-17-05, 11:17 AM   #8
Stone's Avatar
TLCA# 13772
Wayne: Just checked with Gord at JP Toyota, and he says what you said...only one available is the 88*C model, last five digits of the part number is 03103. I must have talked to an aftermarket parts person before buying one and he gave me a choice and I'm mixing it up in my head.
Anyway, Stephan...I guess I do have the 88*C thermostat in my 13BT right now as that's the only model available here from Toyota. My temps still run fairly cool in our mild (compared to yours or Wayne's) weather...on the freeway, when it's about -2 to -8*C outside, the temp needle sits about a third of the way up the gauge and stays there.
Old 01-18-05, 12:48 AM   #9
70sguy's Avatar
Yes and Yes. Both new OEM, Tstat #90916-03103 88 degree Celcius
Also the Rad was pretty much new OEM too (not RB)
I think it is cooling down when you start driving because A/ the coolant is cycling through the rad faster, the fan is spinning faster with the revs and air is going to get pulled through the Rad no matter what you put in front of it.
Sheldon
93 1HD-T powered FZJ80-Extreme valve body-Walbro-ARB- Snork-OME- SOLD!
97 FZJ80 Antique Sage 40th, bone stock. 1HD-FT 5spd conversion starting soon
VW A4 Jetta TDI
My other diesel is a Locomotive
www.gscruiserparts.com
70sguy is offline   Reply With Quote
Gas Suppliers | Mobile Phones | Debt Help | Synchronization fast and easy | Property Search
