Guest
Posts: n/a
I am in the process of trying to install my new EGT,boost,and oil pressure guages.I have a couple of questions about my EGT gauge and my oil pressure. The oil pressure guage is mechanical so I am looking for a convenient place to take my measurement. After looking in the FSM it says that to check the oil pressure you use a mechanical gauge and use an existing location on the block beside the sender(round device threaded into the block with wire coming out?). On my 12-ht I cannot see a threaded hole beside the sender, not even a plug to remove. Has anyone installed a mech oil pressure gauge on either a 12-ht or a 2h motor and can give me a location of where to tap into. Beside the sender is a flat spot that might be used for a oil pressure port but it looks as if it was never installed.
As for the egt guage it uses 12 volts to take the temp readings and was wondering if I use a 24 volt relay tied into my ignition and 12 volts from my converter to power the type k probe will this work and give me an accurate reading. I am going to use the 24 volt relay method as well for the lighting if I cannot find 24 volt bulbs for the gauges. All my gauges are autometer if that makes a difference. One last thing can I take my boost reading from the tubing that goes between the intake manifold and the boost actuator or do I have to tap into the manifold from the turbo to the intake. Thanks guys for all the help real new at the diesel stuff. |
Diesel for blood
You have to remove the sender and screw the test gauge in there
you can install a "T" and install both the mech and the elec.
tie into the converter for the 12V __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
Guest
Posts: n/a
Thanks for the info, I had thought that would be the way to go but wasnt sure and i definately will be putting in a tee so the factory gauge still works as well.
TLCA# 16387
Isspro makes 24v gauges if you can exchange yours. It might make the install simpler and cleaner. My boost is off a "T" on the wastegate actuator.
__________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
Cell Phones | UK Hotels | Expired Pr Domains | News | Cheap Magazines |
