Old 01-02-05, 01:39 PM   #1 (permalink)
dieselcruiserhead's Avatar
TLCA# 9439
24V engine in a 12V truck
OK, sorry to harp on this. I think this thread could potentially be a good "FAQ" if we get some good answers, all on one single thread. Please post how you would deal with the wiring, what you would replace & what you wouldn't. If you have already done it, I'd love to hear how you did it, what you would do again etc.
My best plan that is the easiest in my eyes, is using a converter. Something like a hig draw 50 amp model, something of high quality that is reliable. For example I ran a surepower 24/12V with 12V "memory" and it was awesome. Run everything off that including headlights. Am I insane?
- Cummins 4BTswaps.com Forums
- Hazard Assembly Dirtbag Adventuring Community
- Diesel Conversion Website
TLCA# 9439 Since 1999, Wasatch Cruisers
'89 Toyota Pickup V6, OME, 33x10.5's
'69 FJ55 Project on locked FZJ80 Frame, Cummins 4BT, NV5600, Dana 300
dieselcruiserhead is offline   Reply With Quote
Old 01-02-05, 02:22 PM   #2 (permalink)
Island Moose's Avatar
Location: Tauranga New Zealand via Vancouver Island Canada
Assuming you convert to 2 batteries to match the 24 volt starter and glow plugs, and use a 24 volt alternator, you then would have to run 24 volts through the converter you mention into the stock 12 volt fuse panel to power the rest of the truck.
I would be much more tempted to install a single wire 12 volt alternator in addition to the 24v, tap one battery to the fuse panel at 12 volts, then use the second alternator to keep the tapped battery juiced up.
The trouble with a converter is that you're pissing away so much energy, even with the expensive ones.
The third option is to trade for a 12 volt starter and glow plug system, and forget about 24 volts altogether.
MOOSE
SOLD HER - SOMEDAY SOON
JDM's...THEY SAVED THE BEST FOR THEMSELVES!!
Island Moose is offline   Reply With Quote
Old 01-02-05, 02:26 PM   #3 (permalink)
Diescipel's Avatar
TLCA# 14854
I'm a total newb at all this, but por lo menos my BJ42 has 12v headlights, each one powered by each battery. Should be easy to wire that up so you don't draw so much current from the converter.
B
Brendan
1983 BJ42 bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
Diescipel is offline   Reply With Quote
Old 01-02-05, 02:36 PM   #4 (permalink)
beanz2's Avatar
I guess it depends a lot where you live and what access you have to parts, etc. Since I live in a warm climate and I have the 12V parts needed, I'd just as soon convert a 24V engine to 12V to keep things simple.
Those living in cold climates swear by their 24V systems, but you can't help seeing questions here and there about how hard 24V winches are to come by, where do you get 24V bulbs and CD players, etc. But I am sure the starter's cranking power and a 24V winch's power prove the system's worth.
Split 12V / 24V systems are possible, even some cruisers have that from the factory, so why not. For the price of a converter you get to keep all the engine accessories and keep the rest of the vehicle 12V. We have a good dealer of a 24V to 12 V Solar Converter on this board (Greg_B)
The engine choice makes a big difference in what you'll do too. A 13BT with its 24V glow screen may be better kept 24V as it would be too expensive to convert to 12V. A 1HD-T from an 80 series would only need a 12V starter as the rest is already 12V, and this may only need a starter motor swap from a Hilux minitruck.
For Toyota diesel engines the parts that usually are voltage specific are
- starter
- glow plugs/glow screen
- engine shut off mechanism (fuel shut off or EDIC)
- alternator
- AC clutch (?)
The gauge senders AFAIK aren't voltage specific.
Dave
beanz2 is offline   Reply With Quote
Old 01-02-05, 02:44 PM   #5 (permalink)
wesintl's Avatar
TLCA# 4180
what engine is it andre... I thought about buying a 3bt and swaping over my 12v 3B items to make it 12v...
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is online now   Reply With Quote
Old 01-02-05, 03:17 PM   #6 (permalink)
Supporting Vendor
tlcruiserman's Avatar
TLCA# 7932
If you are putting a 24v motor in a 12 system, keep all the 12volt stuff you can and swap out the rest. This should be pretty easy however you did not mention what you are swapping with what in the way of motors or what series you are doing this on. speaking from experience you will have a lot easier time in the long run using basically a 12volt system, this is because of all the stuff you must convert or find in 24v such as bulbs radios accessories all that stuff. So it really gets down to what parts on the engine are 24volts and what you can do about it. If you are talking about a 13bt or 3b then the following are all I can think of that you need to swap:
glow plugs
EDIC
Alternator
Starter
maybe tach pickup (but doubtful)
That should be it right?
Am I missing somethign on this thread?
Michael
tlcruiserman is offline   Reply With Quote
Old 01-02-05, 03:28 PM   #7 (permalink)
Stickboy's Avatar
Andre,
here's what i did in my fj60 with a 24v 13bt in it.
i kept the motor 24v (starter, glowscreen, alternator, vsvs, etc...)
i kept everything but the motor from the fj60 12 v.
i have an additional racor 645 heated fuel filter and walbro fuel pump - both 24v
all the 12v appliances are run off a solarconverters 12/24-20 wired in eq mode. this allows for the 12v draw to exceed 20a if needed (although it exceeds the eq rate of the converter). I have an ammeter run through a shunt on the low side neg battery terminal that measures all current flowing in the system. with all accessories running (stereo, headlights on high, heater on high, wipers, etc...) i pull about 20a, right at the alternators capacity (25a @ 24v).
i would say that i'm running a fine line of electrical demand and a larger alt would be nice but my system is functional. add a winch, driving lights, offroad lights, etc... and you might be lacking a little. i'm pretty basic in this truck.... for me it was a financial option to swap out to 12v. for some bizarre reason the 12v parts are priced like they are gold when they really aren't anything fancy.
i'm watching to see how stone's experiment with wiring his solar converter up to make it both a step down and eq converter works. I think i'll do it once he gives it a no problem setup.
i don't think there are any other converters out there that beat the solarconverters. most "good" converters run in the 80-85% range where as the solar conv runs at 96%. i have one that runs my house for the past 5 years with no problems and i know the off grid world uses the most quality products for longevity and that converter is the only one that people really use for step down operations. G&S, as you know, sells the custom converter with the leds showing the state of eq and if the batteries are within 5% or less of charge. Pretty slick setup.
my .03
mike
1986 FJ60 - 13BT/H55F powered (BJ60T?)
1986 VW Turbo Diesel Jetta w/ straight veg. oil conversion
1992 Dodge Ram 250 - 5.9 diesel
All running 100% Homebrewed Biodiesel made from waste oil and homepressed mustard seed oil....
Stickboy is offline   Reply With Quote
Old 01-03-05, 08:22 AM   #8 (permalink)
Mainer7's Avatar
i put my 13bt in a 12 volt 40. I kept only the starter as 24 volt, used a 12 volt alternator, and shutdown VSV from Greg and Sheldon. Used a heavy duty Series paralell solenoid switch and 2 batteries lots of cables/wires. Only running one of the glow screen elements with 12 volts.
'78 FJ40 13BT/H55F
Saginaw PS 4" Skyjacker - Old Man Emu shocks
33x10.50 Super Swampers - stock wheels
'88 22RE Pickup
Mainer7 is offline   Reply With Quote
Old 01-04-05, 05:08 PM   #9 (permalink)
TLCA# 9439
See my best idea is about the same as stickboys. This is not for any specific project just "hypothetical" for the guy who posted on pirate about the Chevy 5.3 versus 1HD-T. Cool about the solar converter. I ran a surepower but was not relying on it. I think in a perfect world I would leave the truck as is and try to figure out a 24/12V system like the Australian diesel 80 series, best of both worlds. I sure loved 24V when I had it though. I run the most badass 12V system I have ever owned today and don't get me wrong it's great but even at 35 amps in 24V I was in heaven. Ever used your starter motor to get you up and over an obstacle?
Anywhoo....
Old 01-04-05, 06:41 PM   #10 (permalink)
beanz2's Avatar
Aussie spec 80's have a 12V starting system I believe. But I wonder if the 12V starter motor can be rewound for a higher power?
Dave
Old 01-06-05, 10:20 AM   #11 (permalink)
Radd Cruisers's Avatar
Mainer7 seems to be thinking along the same lines as me, I beleive most are reluctant to go with the 24 volt system due to availability of parts.
We used a 12 volt starter and alternator off a Toyota pickup and Supra, it seems like everthing else is working fine on 12 volts including the fuel solenoid.
The 13BT or 3B out of a BJ42(which I think have runn thier course) are the only units with some specific parts that are hard to change over to 12 volt. Even then most can be converted rather easily.
The 1HZ being 24 volt was a fairly simple change over with the alternator and starter being items we could find at the wreckers, I guess the Air condition pump and sytem would be another hurdle.
I would try and retain the 24 volt starter in the case of the 1HD-T or even our next 1HZ conversion, lotsa compression in the 1HZ motor (600PSI?).
The 1HD-T or FT are going to be lower compression engines due to the turbo..
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
Radd Cruisers is online now   Reply With Quote
Old 10-13-05, 11:16 PM   #12 (permalink)
Wherlwind's Avatar
Has anyone come up with the definitive answer on this?
I am swapping my 2H into an FJ60 and am trying to decide if the best system is to keep the engine 24V , add a solar converter and run everything else off it at 12V. I had originally planned to swap my HJ wiring harness in and run everything 24V. It might be easier to go the converter route though.
Would I be able to run the FJs 12V AC off the converter too?
Wherlwind is offline   Reply With Quote
Old 10-13-05, 11:44 PM   #13 (permalink)
She idles just fine
dieseldog's Avatar
TLCA# 14999
My 24Volt BJ-42 has aftermarket AC running off of 12volts from my converter. Everything else is 24volts still.
I like Mainer's system. Many truckers had series/parallel switches back a few years ago so that they could start on 24volts and then everything else ran on 12volts. That's the ticket, IMHO.
Sparkplugs are Irrelevant.
1984 BJ42; 1988 BJ73; & 1993 KZJ70
2004 R1150RT-P; 2000 R1150GS; 1997 XR400R(sold to stinky); 2002 KL250G; 1984 CT110; 1971 CT90K3; 1970 CT90K2; 1974 ST90
In Search of More Gubs . . .
Mi devas ..i reven al la ŝipo kaj Mi estas estas vestita per ruĝa ĉemizo. Mi estas amor kun.
dieseldog is online now   Reply With Quote
Old 10-14-05, 06:57 AM   #14 (permalink)
cruiser_guy's Avatar
TLCA# 16387
I'm pondering this as well with the FJ45LV. The wiring on the LV is shot so I'll be rewiring it completely anyways. What are the thoughts of making it all 24v? The engine I'll be using will be a 3B from a Dyna or Coaster bus so probably 24v (if it's 12v then the truck will stay 12v).
www.wirrell.com
Old 10-14-05, 10:22 PM   #15 (permalink)
Wherlwind's Avatar
I'm pretty simple when it comes to electrical. Can you explain how that would work.Only the starter would be 24V but I would need to change alternator, glows and EDIC to 12V then wouldn't I ? Would you flip a switch to 12V after starting with 24V or what?
Maybe the no brainer for me would be to just go ahead and swap wiring harnesses. I have all the 24V parts I need except my HJ didn't have AC.For the AC I guess I could run the 12V AC from the FJ off a converter or change the AC amplifier for a 24V one right?
Old 12-15-05, 07:32 PM   #16 (permalink)
rutbeer's Avatar
Sounds more like he's running a dual battery 12V system, but with a trick relay that will combine both batteries for as long as the relay is engaged. The relay output is connected to the starter supply. I'm guessing though....
78FJ40 13B-T, 5speed, split, full floater 70 series, cable lockers,4 disk, a/c, 60 pwr steering, all toyota except the a/c.
www.importpurist.com
Oh, and a bitchin FJ45 that may or may not be for sale.
"Much like a cat or hot buttered toast, the correct side will always try to land down. If the bezel is on upside down, then the force of it trying to right itself may cause you to roll your cruiser unexpectedly."
rutbeer is offline   Reply With Quote
Old 12-16-05, 03:46 AM   #17 (permalink)
Latest guess on my system is that a starter relay activates a solenoid to combine the output of my 2 batteries to 24 volts for the starter. It's a one click start when it works. Everything else I've found or installed on my LC is 12 volts.
I live in a tropical country, but the one click start is so attractive that I'm trying to preserve my 24 volt starter.
Kalawang
LC80 Full time AWD
1HD-T 1990 model
4" Lift 33" Yoko Geo MT
Airtec Snorkel
Bullbar 9,000 Warn
PIAA CDL
Kalawang is offline   Reply With Quote
Old 12-16-05, 09:14 AM   #18 (permalink)
rutbeer's Avatar
Why even use an additional starter relay? Seems like you could run the starter wire to the special 24v combining relay which will deliver both 24V to the starter motor and to the starter's stock relay to kick it off. I still haven't found a diagram or picture of what the combining relay looks like, so I'm still speculating.
Old 12-16-05, 09:44 AM   #19 (permalink)
The relay is just a relay. The combining is done by the solenoid, as far as I understand it. I did use a direct connection for a couple of months sometime back, but have since returned to original wiring. Toyota designed this thing and I figure that they know better than I do.
Kalawang
LC80 Full time AWD
1HD-T 1990 model
Airtec Snorkel
Bullbar 9,000 Warn
PIAA CDL
Old 12-16-05, 01:17 PM   #20 (permalink)
rutbeer's Avatar
Ahhh...here you go. http://www.gas-turbines.com/products.../nt-sp9844.htm
Old 12-16-05, 01:22 PM   #21 (permalink)
rutbeer's Avatar
And here... http://www.jcwhitney.com/autoparts/P...12/24%20switch
Old 12-17-05, 09:08 AM   #22 (permalink)
rutbeer,
You might have done me a very big favor with those links. I've been having a struggle with my starting for such a very long time and the problem has come back again. I have replaced my Toyota starter relay with a Bosch, but the solenoid isn't available locally except as an experienced part and the landed cost from Japan looks to be about U.S. $ 500.00 so this alternative looks very attractive.
I just have to verify that my solenoid is truly defective.
Kalawang
LC80 Full time AWD
1HD-T 1990 model
Airtec Snorkel
Bullbar 9,000 Warn
PIAA CDL
Old 12-17-05, 09:41 AM   #23 (permalink)
Stone's Avatar
Added to FAQ list of links. Also updated the FAQ with a few more worthy threads. Thanks.
Stone is offline   Reply With Quote
Old 12-17-05, 02:43 PM   #24 (permalink)
rutbeer's Avatar
Yeah, I'm leaning in that direction myself. I still have to think through a lot of stuff on my conversion before I even pull the 2F. I'm thinking that I will try to get as many 12V parts as I can and then leave the starter 24V. The solar converter is tempting, but I'd rather leave the majority of my stock harness intact. I'm still learning a lot about diesel though and I had to admit my current ignorance on it. I tried to do a compression test on one of my motors and I'm just not sure I even did it right. Oh well, as a matter of course, I think it's wise to crack it open and have a look around while it's still out of the truck and easy to work on. I need to find a 12v cutoff for it and see how hard it will be to adapt a 12v starter to the 13bt block.
Old 12-17-05, 05:31 PM   #25 (permalink)
It's not all that big a difference between 12 and 24 volt starters, if I were realistic. I drove a 12 volt deisel for some years, and have had some input on a Rover deisel from a friend who owns one. For us here in a tropical country, it's 5 seconds on the heaters before cranking the starter.
What's less obvious is the drain on the one battery by the starter and the corresponding shorter life of that battery, by my experience. It takes a lot of amps to crank a deisel starter and I still have a clear memory of giving away batteries from my deisel to gas cars and watching the battery work perfectly for them whereas that same battery would be unable to crank mine.
You might also try looking into driving a 12 volt starter with 24 volts. My starter, according to Ellery and also according a stick on label on the starter itself, is a 12 volt starter but is cranked by 24 volts. I once tried to start my 1HD-T with 12 volts, but that was a failure. It might have failed to start because I didn't think to feed the heating coils first at the time, and I suppose I might try that someday. It takes a lot of cranking to start a deisel that isn't heated, but I did do a lot of cranking when I tried the 12 volt thing and the 1HD-T didn't start.
Back when I had a 12 volt deisel, one of the tricks I used to get it started when air got into the fuel lines because someone had run it into empty was to series a couple of batteries thereby feeding 24 volts to the starter. The thing cranked very fast when I did that and the car started one click. You have to remember to turn off your stereo first or you might burn it out. I only did the 2 battery thing when one battery wouldn't do and once the car had started, it wouldn't need a second battery to start unless some bonehead drove it to empty again. That didn't happen with me more that 3 times a year.
I much prefer to keep my LC in it's original state, but if push comes to shove, i.e., if I can't find the parts, I would convert to a 12 volt starter even if I have to accept the 5 second heating preliminaries.
Kalawang
LC80 Full time AWD
1HD-T 1990 model
Airtec Snorkel
Bullbar 9,000 Warn
PIAA CDL
Old 12-18-05, 05:56 AM   #26 (permalink)
Stand and deliver
roscoFJ73's Avatar
Dave
The only 24v aussie vehicles are buses,heavy transport and earth moving vehicles and of course JDM 4wds.
Even our army uses only 12v 4X4.
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 12-18-05, 10:17 AM   #27 (permalink)
Supporting Vendor
Greg_B's Avatar
TLCA# 7091
Easy as pie: Order the correct clocked solinoid from Toyota, and put in a minitruck motor...
Read general considerations of a 13BT into a 40 series:http://www.gscruiserparts.com/13bt_install.html
hth's
gb
