Guest
Posts: n/a
egt,boost ,oil pressure guages
Just wondering where you guys have taken your guage readings form. I have heard that egt should be taken re and post turbo? Which area is better and which is easier. Also where do I take boost from and should I get a mechanical oil pressure guage rather than an elec guage(24 volt system and all). Thanks for all the help guys as this is all new to me. If you have photos that is best as I am a see and do person way more.
they say pre turbo is best for readings but from my view if that sensor ever broke off there goes your $1000+ turbo...
i run all mine post turbo and as close to the turbo as possible. mech oil is good boost is in the pipe from the turbo to the throttle body. __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
Guest
Posts: n/a
[ boost is in the pipe from the turbo to the throttle body.[/quote]
So anywhere between the the turbo and throttle body is good? I am assuming that boost is the amount of pressure the turbo is forcing into the motor? I thoght that the boost was something to do with the operation of the wastegate.I now see that the wastegate controls the amount of boost. |
I don't know if diesels are different but in gas engines you can only get a true boost pressure reading when taken from the intake manifold after the throttle body , correctly known as manifold absolute pressure or map . I have personally seen this on the 6 turbo powered gas vehicles I have owned . No turbo diesel experience yet but soon to change .
HTH , Daryl __________________ 74 fj/bj40 88 fj/bj62 , full OME lift kit , home brew turbo , 4 runner brakes . |
Have my Egt probe post turbo,
But am putting a fitting preturbo so I know exactly what is happening. I can always put it back to post after I find out. I want to find out what I can get away with, with it post I am too careful cause I don't know the real reading, it can vary too much. Just an idea is put fitting in both places then you can compare difference. john __________________ 81 BJ60 (turbo & intercooler etc...) |
Guest
Posts: n/a
sounds like a good idea jzilla.
TLCA# 16387
My EGT is pre-turbo and I'm not worried about it breaking off. The boost gauge is off a "T" from the waste gate control signal.
If you put the EGT in pre turbo you'll want to pull the manifold to drill and tap it, just to make sure it's clean. A bit of steel shavings in the turbo bearings can ruin your whole day! __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
I have my EGT pre-turbo...on both the duramax and the 12H-t. I drilled them both on the truck, with the engine running. Scary as hell but worked both times. I got lucky on the HJ61 as I drilled dead center of the manifold only to find that it has a support inside that I was unaware of. This resulted in the probe being on a slight angle.
I also pulled manifold pressure off of a T to the wastegate. A mech oil gauge is a good idea. I have all Isspro mech gauges and I am very happy with them. A simple resitor in line and the EGT works on 24V. A change of lights is all that is needed for the mech oil and boost gauges. I mounted my guages in the overhead pod on the 61. I removed the altimeter and outdoor temp gauge. It was a PITA routing the lines down the A pillar but well worth the clean look IMO. I snap a picture tomorrow in the light if you like. __________________ Brad T 88 HJ61 "Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs... 78 BJ 40/42/60 |
#9 | |
cheers __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
#10 |
I run my EGT post turbo as close the the Turbo as possible, I run the boost gauge off of my cast runner from turbo to Thottle body (3B's with AXT). If you are running a 3B engine in anything and put a turbo on it I strongly suggest when you buy the boost and EGT gauges you also invest in a Water Temp Gauge, I think that is even more needed with the 3B then aftermarket oil pressure gauge. I run all mechanical gauges, if you are running on 24v system be careful which gauges you run because some still require 12volt power (higher end autogauge brand). The standard gauges I do with Turbo of 3B is EGT, Boost and Water Temp. Also if you are putting them in 24volt Cruisers you can hook the lights in series if you have two or more and still wire them into the dash lights.
G-day, Michael |
#11 |
Wayne, what brand where they?
#12 |
auto meter...
#13 | |
#14 |
Guest
Posts: n/a
Dude would love some photos if you can. You said you took the manifold(boost?)pressure off of a tee to the waste gate. Are you speaking of the rubber tube that goes to the wastegate actuator? also you used a resistor to reduce the voltage from 24 volt to 12 volt,As I pick up my gauges tommorrow I am assuming the egt sensor needs 12 volts to operate, where did you get the resistor from or will any electrical suppiler have these as well as the 24 volt lights for the other gauges?
I also wonder what the difference in temps would be going from pre to post turbo. |
#15 | |
TLCA# 16387
#16 |
personally, if you are running your engine that close to the melt down that you need the pyro before the turbo then change your driving habits... or have a spare engine sitting in the garage waiting to be installed...
this is not a dig at anyone, just common sense... cheers __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
#17 |
does the 13bt and 12ht have a throttle plate in the throttle body like the 3b?
If my memmory serves me correct I once looked at a 3bII and it did not have a throttle plate but a mechanical linkage running to the injection pump from the throttle body . Daryl __________________ 74 fj/bj40 88 fj/bj62 , full OME lift kit , home brew turbo , 4 runner brakes . |
#18 |
So what happened with those probes Wayne?
What did autometer say? Any warranty or anything? __________________ 81 BJ60 (turbo & intercooler etc...) |
#19 |
Interesting. I use the autometer z gauges. The EGT probe is definetely beefy and high quality. I have run both pre and post turbo. pre is nice because it tells you actual EGTs. Post is nice because it tells you more or less actual turbo temp. So they both have advantages and drawbacks. Ideally you would probably want both I'd suppose but once you got an idea of the difference between the two I'm sure you wouldn't need them both anymore. I have mine literally an inch or two from the turbo exhaust and it is a good location. And if it were to fall off then I would be OK as well...
Andre __________________ - Cummins 4BTswaps.com Forums - Diesel Conversion Website TLCA# 9439 Since 1999, Wasatch Cruisers '89 Toyota Pickup V6, OME, 32's '69 FJ55 Project on locked FZJ80 Frame, Cummins 4BT, NV5600, Dana 300 |
#20 |
The way I see it is that you would want your probe as close to what ever your trying to measure. Measure EGT on the collector and boost from the intake manifold. However this does not mean you would want to install a probe in a runner of a manifold unless you’re measuring just one cylinder. I haven’t heard of probes breaking from a quality source until Wayne.
My .02 -NS __________________ 86 BJ70 Turbo/Intercooled 33x9.50 BFG MT's OME ARB Bumper - 96 FZJ80 Locked Subtank OME '851/860 305 MT's Murdered Out Tornado Alley Cruisers |
#21 | |
Yup, that's what I did. I took the resistance of the EGT "box" and bought the same resistance resistor from my local electronics shop. I found the bulbs at the Volvo dealer for cheap.
Sorry, just been busy...I will try for those pics tomorrow. And as far as changing driving habits??? Why? That's why I have my probe pre-turbo to make sure I don't have a melt down... Quote:
#22 | |
auto meter warrentied them with no hassel at all. i was as surprised as the next guy, these are beefy probes... cheers __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
#23 |
Guest
Posts: n/a
Sorry for sounding so stupid but the egt "box" you are speaking of is just the packaging that it comes in correct? Iask this as I still have not gone down to pick up my gauges(too busy also) and am flying a little blind here
#24 |
Wayne any damage to your turbos?
Or is that the reason you checked? __________________ 81 BJ60 (turbo & intercooler etc...) |
#25 |
no damage to the turbo since it was post turbo installation. i was installing a new exhaust on the first one and i can't remember why on the second one...
#26 | |
TLCA# 16387
#27 |
Guest
Posts: n/a
Cheers, thanks for the info cruiser_guy.
