Swap Canadian Instrument Cluster with Kms for US cluster with Miles?
The odometer on my BJ42 is stuck at 359999 kms, and I would also like to get a cluster with the MPH in big numbers. What would it entail to swap a US cluster in that would read MPH and miles accurately?
Yes, I am on winter break and have little to do but tinker with my new toy. Thanks again, B __________________ Brendan 1983 BJ42 bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
just switch face plate, no biggie at all, use the BJ42 guages and lights. pull the hoods off the 2 bulbs and you wil have to actually use the dimmer switch...
__________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
isn't the speedo geared different for KM, vrs Miles? I don't know but would think so.......prolly I am wrong.
on the cluster lights, I have done the shield trick(on old 45), works good but the light is very anoying to the passanger. On my 82 fj40's I didnt feel like hacking up a spendy to replace cluster so I found some higher output bulbs, work great. and also, my odo(in my 82 fj40) went tits up last year, I discovered that a fj60-2 odo guts are the same and MUCH more plentifull then late fj40 odo's |
I'm wondering about the gearing too. But where does the 'gearing' happen--at the pickup for the speedo cable on the tranny, or in the instrument cluster???
Just ordered the bulb kit from 4wheelauto which includes the higher wattage bulbs for the instrument cluster... ...I think I'll leave my FJ60 Od alone, but the thought of a swap jumped into my head... B __________________ Brendan 1983 BJ42 bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
why is it bothering the passenger?
the cables ends are the same from 76-84... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
I guess it depends if the scale that's used in the MPH face is the same as the one used on the KMH face. My speedo goes from 0 to 160 km/h, so I figure if the MPH face goes from 0 to 100 mi/h then it would have the exact same gearing...no?
Oh, and in my BJ74 the "gearing" happens at the t-case...I'm trying to hunt down a speedo correction kit right now to compensate for going from the stock 29" tires to my current 255/85r/16. According to my WAAS enabled GPS, I'm off by about 14%. __________________ Stone's Land Cruiser & Flyfishing Pics Flyfishing British Columbia: www.flyfishbc.com bcfishingreports.com |
#7 | |
the removal of hoods makes it much brighter... cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#8 | |
Yup, the odometer will definitely be off if you just change the face. It will read faster because it's in kms...1.6x faster in fact.
#10 |
Stone, I'm thinking of having something made up as well to correct my speedo, since I went to 33's.
North Shore Off Road told me they can get a new speedo gear or something made up for about 100bucks, I keep forgetting to do that though. __________________ 81 BJ60 turbo, intercooler, snorkel, etc. |
#11 |
Jzilla: Really? I was looking at all the complicated solutions, contacting Marks in Oz and everything. If NSOR has a part then I would probably pick up a couple. Thanks for the tip...I'll try and call them tomorrow.
#12 |
you can also swap out the plastic drive gear for one of different teeth and that will do the trick, local pick and pull...
#13 | |
because the light is now VERY visible from the passanger seat, its kinda anoyoing. Going to a brighter bulb works almost as good and no light shining and no hacking.
#14 |
hacking...OUCH!!
i thought i did a very clean job when i do them... ;^) __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#15 |
Ratio converters are available for speedometer shops. I used United Speedometer Service to make a couple of ratio adapters. You can use their methods of testing your odometer against a measured mile or measuring the revolutions the cable makes as you push the vehicle a certain distance.
An idea I have in mind for the speedometers that read in kilometers: Do the ratio testing like the measured mile method and report the km readings as if they read in miles. It will be off by some 1.6 or whatever the km to mile conversion is, but then the ratio box takes care of the metric conversion too, so now your odometer reads in miles! But then you'd have a 160 mph speedometer ![]() Dave |
#16 | |
I have no issue cutting/hacking up an old cluster, but they don't grow the milliion mile late model 40 clusters on tree's.........at least not around here
![]() Quote:
#17 |
Stone let me know how it goes with NSOR,
thanks __________________ 81 BJ60 turbo, intercooler, snorkel, etc. |
#18 |
I think you should be able to trade one for the other without any problem.I have a pre metric speedo with MPH in large numbers and kmh in small and a post metric with KMH in large and mph in small and I've traded back and forth without any noticable difference. 100 mph in same spot as 160 kmh. pete
#19 | |
#20 |
thanks stone, looking forward to hearing about it.
You can always email me at johnzilla80@yahoo.com john __________________ 81 BJ60 turbo, intercooler, snorkel, etc. |
Libro infantiles | Mortgage Calculator | Personal Loans | Loans | Books |
